PSB HD8 and HD10 Ultra-Compact Powered Subwoofers Announced
The PSB HD8 and HD10 deliver powerful, high impact bass
with astonishing musicality in a small, space-saving footprint
PSB Speakers, long renowned for affordable excellence in loudspeaker designs, announces the addition of the PSB HD8 and PSB HD10 — the outcome of an 18-month endeavor to provide the performance of their award-winning subwoofers in a more broadly acceptable size.
The HD8 and HD10 are 10.5″ and 12″ cubes respectively. The HD models, which stand for High Density due to their condensed design, are PSB’s first ultra-compact subwoofers. These new designs not only needed to be compact but also to provide the deep bass punch, authoritative power and musicality for which all current PSB subwoofers are acclaimed.
The challenge of subwoofer design can be summed up quite simply yet completely with this simple phrase. “Small, Deep, and Loud: pick two.” Achieving all three goals from a single design package is on the face of things an impossible
task, one that requires overturning, or at least overpowering, the laws of physics.
PSB’s HD8 and HD10 do so with a singular combination of brute force and engineering finesse.
PSB resolves the engineering conundrum by creating highly specialized low frequency drivers of exceptionally high mass and extraordinary “pumping” ability plus tiny, exhaustively computer-modeled enclosures, and unique dual-opposed high-mass passive radiators.
Using dual-opposing, high mass, passive radiators, PSB was able to achieve unprecedented excursion–as much as two inches peak-to-peak–in order to preserve output down to 35Hz on the HD8 and 30Hz on the HD10. The uniquely progressive suspension preserves near-perfect motion, with low-distortion clarity, at all frequencies and drive levels. By arranging the dual passive radiators on opposing cabinet faces, unwanted vibrations are cancelled and more energy is sent into the room as deep bass. Furthermore, the HD8 and HD10 employ vibration-absorbing feet that keep them in place on any surface, even marble flooring.
The HD8 and HD10 employ sophisticated Class H amplifiers that produce 500 and 750 watts of continuous power respectively (and some 1,600 and 2,000 watts of peak dynamic potential) allied with PSB’s “smart bass” monitoring system to preserve accurate musicality at even the highest volumes and lowest frequencies.
Extra-heavy-duty aluminum cast woofer “baskets,” oversized magnet structures, and large-diameter, ultra-high power voice coils are three more elements that empower the HD8 and HD10 to deliver accurate and powerful low frequencies. Both models exploit intelligent amplification with sophisticated circuitry that matches each sub’s drivers, enclosure, and electronics for the most balanced system possible resulting in controlled, quick and high-impact sound that extends to the very lowest octaves, without boom or bloat.
Utilizing their 35 years of loudspeaker design expertise, PSB conducted exhaustive measurement and analysis, along with extensive listening tests to ensure both the highest technical performance and consummate musicality.
The result — unique for this category of subwoofers — is two ultra-compact models that not only play loud and deep but do so accurately, dynamically and musically to create the true “you-are-there” excitement of the original sonic experience.
The HD subwoofer’s controls include volume, crossover and continuously variable phase controls, Auto on/off, LFE in/out, LL Stereo in/out, HL Stereo in with 5-way gold-plated binding posts, and 12V Trigger.
Both models come in an elegant satin black finish and are currently shipping at the following suggested retail prices:
Model Price
HD8 $999
HD10 $1,499
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
2024 Black Friday tech deals you won't want to miss on hi-fi, headphones, and home theater gear this Holiday Season.
Escape into sonic bliss while traveling with some great ways to create the soundtrack for your summer of 2024.
Looking for the ultimate tech or hi-fi gift for Father's Day 2024? Upgrade Dad's lifestyle with gifts he'll enjoy all year and beyond.
Podcasts
On this episode Editor in-Chief, Ian White discusses his picks for the best wireless speakers of 2024 (so far) under $4,000.
Whether enjoying music at home or on-the-go, you don't have to spend a lot to experience high fidelity sound.
For $199, the PSB T4U TWM wireless earbuds calibrate their sound to match the listening capabilities of each ear.
Precision-engineered with dual 8” drivers and nCore amplification to deliver power and accuracy with minimal distortion.
PSB Alpha AM3 and AM5 are the powered and wireless versions of the Alpha P3 and P5, respectively.
