PSB Alpha AM3 & AM5 Powered Speakers Debut
PSB Alpha AM3 and AM5 are the powered and wireless versions of the Alpha P3 and P5, respectively.
PSB Alpha AM3 Powered Speakers with Laptop - Black without grills
Powered & Wireless Alphas
PSB Speakers just introduced active (powered) versions of their award-winning Alpha P3 and P5 (passive) bookshelf speakers, long revered as affordable audiophile speakers. The new Alpha AM3 and Alpha AM5 powered speakers combine the same drivers as the Alpha P3 and P5, with built-in 35-watt and 50-watt Class D amps, respectively. Plus, both new speakers are Bluetooth wireless enabled for streaming music with support for aptX. Simply pair and play, or used the wired inputs to connect to a stereo, TV or computer.
With similar designs, the differences between the Alpha AM5 and AM3 can primarily be found in the size of the cabinet, the amount of amplifier power and the size of the woofer. Using PSB’s proprietary Alpha drivers, the AM5 features a 5.25” woofer with textured polypropylene cone and a 50W x 2 amplifier. The AM3 utilizes a 4” woofer and a 35W x 2 amp. Both utilize a ¾” aluminium dome tweeter with Neodymium magnet and feature acoustically transparent detachable magnetic grilles. Although hard to tell from the photos, the Alpha AM5 is about 3-inches taller and deeper than the AM3.
PSB Alpha AM5 Powered Speakers with Turntable Black without grills
PSB Alpha AM5
Versatile Setup
The Alpha AM3 and AM5 active bookshelf speakers are effortless to set up and use and can serve as the foundation of a home entertainment system or be used as PC speakers. There’s no amplifier to hook up or apps to download. Connect to a computer or TV for room-filling, or stream wirelessly. Both models even feature several sound modes allowing listeners to accentuate dialogue, soundstage and more. Vinyl lovers will appreciate the dedicated RCA phono input. Where desired, use the sub output to add a subwoofer for even deeper bass.
PSB Alpha AM3 Powered Speakers Rear in White
PSB Alpha AM3 and AM5 share same back panel
Performance
PSB claims the Alpha AM3 and AM5 should standout from a crowded market of powered speakers, because they’ve been able to optimize amplification performance with digital signal processing (DSP). Not to mention, they got to apply what was already achieved with the Alpha P3 and P5 speakers. Therefore, the company believes the frequency response, bass extension and total output reveal a remarkable level of performance for such compact speakers.
PSB Alpha AM3
“Beyond the Alpha AM’s compact size, affordability and versatility of application is a sonic performance that clearly lives up to the PSB heritage. Like all PSB speakers, final voicing was performed by founder and Chief Designer Paul Barton at Canada’s famed National Research Council.”
Joe de Jesus, Lenbrook’s Product Manager for PSB Speakers
​Key Features
  • Qualcomm® aptX™ Bluetooth
  • ​Dedicated RCA phono input
  • 3.5mm analogue input
  • Optical input
  • USB DAC
  • USB power jack
  • IR remote control
  • Subwoofer output
Comparison
Alpha AM3Alpha AM5
Frequency Response56Hz-20Khz 55Hz-20Khz
On Axis @ 0° ± 3dB
LF Cutoff -10dB40Hz36Hz
RMS Power35 watts x 250 watts x 2
Tweeter3/4” (19mm)
Aluminium Dome with Ferrofluid and Neodymium Magnet
Woofer4” (100mm)5.25” (133mm)
Cone Rubber Surround Steel Basket
SIZE
(W x H x D)
5 1/8” x 8 5/8” x 6 7/8”
(130 x 220 x 174mm)
6 3/4” x 11 2/5” x 9 1/2”
(170 x 290 x 240mm)
Net Weight10 lbs (4.5 kg) /pair21.5 lbs (9.75 kg) /pair
Price & Availability
Both new powered speakers are available now in either Matte White or Matte Black finish at the following prices:
Competition
Learn more
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Devialet today announced Gold Phantom, which claims to be the most extreme self contained speaker ever made. It boasts a maximum volume of 108db...
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
2024 Black Friday tech deals you won't want to miss on hi-fi, headphones, and home theater gear this Holiday Season.
For 2025, the Audioengine A2+ now includes Bluetooth 5.3, 24-bit audio, and USB-C connectivity - still at an affordable price.
Digital Music Systems
The Audioengine B1 has been updated with Bluetooth 5.3, aptX Adaptive, and 32-bit Audio, but still has the same $189 price tag
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
