PS Audio Introduces StellarGold Preamplifier and DAC Separates
At $3,999 each, PS Audio’s two box solution has the latest innovations to take your digital music listening experience to the next level.
PS Audio StellarGold DAC and Preamplifier Silver Lifestyle
It’s been a busy month for PS Audio. Having just introduced their aspen FR10 loudspeaker, the Colorado-based manufacturer are ending 2023 with the introduction of the new StellarGold preamplifier and StellarGold DAC. Both will set you back $3,999 each. The duo is intended to work together, but each can swap into any system. Both are distinguished by a real-gold-plated accent line across the front panel.
Paul McGowan, PS Audio CEO noted, “our Stellar Series components have always delivered outstanding performance at price points that represent real value. The new StellarGold preamplifier and DAC take this design philosophy to a higher level than ever before.”
PS Audio StellarGold Preamp
PS Audio StellarGold Preamplifier Silver Angle
Available in silver or black, the StellarGold preamplifier (SRP: $3,999) is a flexible audio system control center with multiple balanced and single-ended inputs and outputs, all accessible via the preamp’s front panel menu system and included remote control.
Designed by renowned engineer Darren Myers, the preamp is fully balanced from input to output, and utilizes pure Class A analog amplification. The StellarGold preamp employs high-slew-rate, high-bandwidth JFET and BJT devices along with hand-selected internal components, and its two discrete audio amplification stages are based on a minimal global feedback design. The high-current Class A output stage can drive long cable lengths with ease. Great care and attention have been paid to the preamp’s power supply design, with an oversized transformer, multiple stage regulation, and other refinements.
The StellarGold preamplifier combines extraordinary resolution, tonal accuracy, spatiality and dynamic impact with flexible operation. It adjusts volume and balance via precision stepped attenuation, and also provides control of input selection, input naming, IR control, and other functions.
PS Audio StellarGold Preamplifier Back
Key Features
  • Class A pure analog amplification with high slew rate amplification stage
  • Fully balanced from input to output
  • JFET and BJT discrete architecture
  • 2 pairs of balanced and single-ended inputs and outputs
  • Volume and balance control via precision stepped attenuation
  • Firmware-upgradeable via USB port
  • Frequency response: 15 Hz – 150 kHz, +/- 0.1 dB
  • Remote control or front-panel operation; remote can be used to operate other PS Audio components
  • Available in silver or black
  • Dimensions: 17″ wide by 3.3″ high by 13″ deep, weight: 24.1 lbs.
Where to buy: $3,999 at psaudio.com
PS Audio StellarGold DAC Silver Angle
The StellarGold DAC (SRP: $3,999) was also designed by Darren Myers whose mission was to discover how far it might be possible to extend the already extraordinary capabilities of the latest technologies of the top-of-the-line ESS DAC platforms.
What makes the new StellarGold DAC unique is its use of multiple parallel DACs. Each channel of the StellarGold is built by paralleling 4 high resolution digital to analog converters, then feeding the combined output of these DACs into an all new discrete class A analog output stage. PS Audio claims the use of multiple high-precision DACs to form one ultra-linear channel has the advantage of lowering noise and channel crosstalk while at the same time increasing linearity, dynamic range, and resolution beyond what any single DAC technology can achieve.
The StellarGold DAC provides multiple I2S and coaxial digital inputs, plus USB and optical inputs, and balanced and single-ended outputs. Its built-in lossless volume control enables it to be used as a standalone preamplifier. The DAC is compatible with PCM to 768 kHz and DSD to 256 (11.2 MHz). The DAC provides user-selectable digital filters to enable sonic tailoring to the listener’s preferences.
PS Audio StellarGold DAC Back
Key Features
  • Four parallel DACs per channel for exceptional sound quality
  • Designed around ESS 9038 Pro technology
  • Fully balanced design
  • High slew rate, low-feedback, Class A output stage
  • Compatible with PCM 16- and 24-bit from 44.1 kHz to 768 kHz, DoP64 to DoP256, and DSD 64 to 256 (depending on input)
  • Adjustable volume control allows use as a standalone preamp
  • User-selectable digital filters
  • Dimensions: 17″ wide by 3″ high by 12″ deep, weight: 22.5 lbs.
PS Audio StellarGold Preamplifier Black Front
PS Audio StellarGold DAC Black Front
3 Comments
3 Comments
  1. ORT
    December 24, 2023 at 6:26 pm
    Am I the only one that thinks these two excellent pieces of equipment look like…Schiit?
    ORT
    • Ian White
      December 24, 2023 at 9:51 pm
      ORT,
      Not a big fan of the industrial design.
      IW
      • ORT
        December 24, 2023 at 10:38 pm
        Ian, same here. Schiit is nice stuff and I would suppose these PS Audio pieces are too but I prefer a more Vintage look or if possible, something mixed in with some inspiration (TUBES!!) from Lang’s “Metropolis”.
        I even gave my son my Valhalla 2.
        I just moved my Dual 1246 into my main record listening setup in place of my Pro-Ject Beatles ’64. I like both but the Dual is vintage sweetness.
        Looks matter. Which does not explain how I ever got married. 😉
        ORT
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
HDTV 4K & 8K TV
Samsung just unveiled pricing and availability details for its full line of Neo QLED TVs in both 4K and 8K resolution. Potential buyers may...
Discover the best affordable Hi-Fi brands of 2025 leading the stereo audio revival with premium sound at budget-friendly prices.
DAPs
With support for 32-bit PCM, DSD, Roon, LDAC, aptX HD, and a brand new docking cradle, the Astell&Kern PD10 DAP might replace your streamer.
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
On this episode Caleb Denison, formerly of Digital Trends, shares his thoughts on 2025 TVs along with the launch of his new YouTube channel,...
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
