CD Players
PS Audio PerfectWave SACD Transport Is Now Available
Looking for that final CD player or transport that can play every format including DSD and SACD? The new PS Audio PerfectWave SACD transport is shipping.
Contrary to what you might have read online, CD players are still in demand. Audiophile CD players and transports that can play every format including DSD and SACD are not as rare as you might think. The brand new PS Audio PerfectWave SACD transport offers every bell and whistle imaginable and it certainly won’t go unnoticed by the folks in Binghamton who just released their own mega-buck CD player. If McIntosh, Luxman, and PS Audio are still developing new high-end CD players — there is clearly a market for them.
PS Audio PerfectWave SACD Transport Front
PS Audio is now shipping its PerfectWave SACD Transport (PST), designed to deliver the ultimate in disc playback from SACD, CD and other optical disc formats. The new PerfectWave SACD Transport incorporates a wealth of engineering innovations to offer extraordinary sonic realism, combined with plug-and-play setup and convenient remote control operation.
The PS Audio PerfectWave SACD Transport is capable of playing stereo audio from most types of optical discs, including SACD, CD, CD-R, CD-RW and DVD-R*/-RW*/+R*/+RW* (*audio data file only). In addition, the PST will play the raw DSD layer of an SACD directly into a compatible PS Audio DAC via an I2S connection, to provide exactly the same audio heard by the mastering engineers in the studio.
The PST can also play MP3/ WMA/AAC (~48kHz/320bps) WAV/FLAC/AIFF(~192kHz/24-bit) DSD (~5.6mHz) and ALAC (~96kHz/24-bit) files from discs or from its USB input.
The PST employs PS Audio’s proprietary Digital Lens technology, which electrically isolates the mechanical transport/laser mechanism from the digital output stage by a unique combination of buffer memory and FPGA (Field-Programmable Gate Array)-based digital processing. This reduces jitter and timing artifacts and focuses the audio data into a single bit-perfect, timing-accurate stream to the DAC.
The PST incorporates a newly-developed galvanically isolated output stage, which feeds the output of the PST’s all-new drive mechanism to the Digital Lens using transmission of focused-beam, short-wavelength signals across space. This total physical and electrical isolation completely eliminates noise or ground contamination.
PS Audio claims remarkable image specificity and openness against a vanishingly quiet background, with a natural quality to vocals and instruments and unmatched musicality and fidelity.
PS Audio PerfectWave SACD Transport Back
The PS Audio PerfectWave SACD Transport offers a comprehensive selection of outputs, including an I2S output for PCM and DSD (raw), plus coaxial RCA and BNC for PCM and DoP (use both BNC outs for double-rate DoP), and balanced XLR (use both XLR outs for double-rate DoP).
The PST also has Ethernet and Wi-Fi connectivity for over-the-air firmware updates. The PST requires no set up – simply connect the desired digital audio output. In addition to its front panel controls and menu, the PST can be operated using its supplied full-function remote control.
Like every PS Audio product, meticulous attention has been paid to parts quality and construction. The PST’s clean, refined design matches other PerfectWave components.
PS Audio PerfectWave SACD Transport Angle
Price & Availability
The PS Audio PerfectWave SACD Transport is currently available for $6,499 at psaudio.com in silver or black.
Features:
  • Plays SACD, CD numerous additional disc and data file formats from discs or USB stickPlays the raw DSD disc layer via I2S connection for studio-master-quality audio.
    • MP3/WMA/AAC (~48kHz/320bps)
    • WAV/FLAC/AIFF (~192kHz/24bit)
    • ALAC (~96kHz/24bit)
    • DSD (~5.6MHz)
  • Exclusive Digital Lens technology reduces jitter and timing artifacts and delivers a bit-perfect, timing-accurate data stream.
  • Proprietary galvanic isolation output stage provides complete electrical and mechanically isolation to eliminate noise.
  • Remote control or front-panel operation.
  • I2S, coaxial RCA and BNC, and XLR digital audio connections; can be configured for double-rate DoP output.
  • USB input allows playback of audio and data files from a USB stick.
  • Plug-and-play operation with no configuration required.
  • Ethernet and Wi-Fi connectivity enable firmware updates.
  • Available in silver or black.
  • Unit dimensions: 14″ x 17″ x 4″, weighs 22 lbs.
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
CD Players
At $2,399, the Shanling ONIX Zenith XST20 SACD/CD Transport is here to breathe new life into the "dead" audiophile formats of SACD and CD.
The Best Audiophile CD Players of 2024 include Hegel, Luxman, Marantz, Rotel and more for the ultimate in compact disc playback.
CD Players
At $3,000, the Denon DCD-3000NE plays any disc including SACD, DSD, CD, MP3 and FLAC at up to 384kHz/32-bit resolution.
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
Fell Audio aims to attract British hi-fi buyers seeking retro aesthetics with value driven audio performance from its inaugural £1000 stack.
CD Players
Add CD playback to the Ruark R410, R610 and R810 music systems for only $350 with the new R-CD100 CD Transport.
CD Players
At $12,000, the new Marantz SACD 10 is the best CD/SACD player the company has ever made and it weighs 73 lbs.
