PS Audio PerfectWave DAC and Network Bridge
A hybrid DAC, music server and preamplifier resuscitates music collections by improving file quality and making them more accessible
PS Audio introduced the PerfectWave DAC (digital to analog converter), capable of accessing high-resolution digital audio data from multiple sources such as a CD transport, CD player, computer network or the Internet and converting it to natural sounding analog audio. When combined with the PerfectWave Network Bridge, the PerfectWave DAC (PWD) is turned into a high-end music server and preamplifier.
Settling for jitter-laden compressed digital music is not an option for some music enthusiasts. Seeking to even the music playback field, PS Audio created the PWD with Network Bridge to breathe new life into music collections by producing the highest fidelity audio playback possible, regardless of source or file type. Utilizing the onboard Digital Lens, the incoming stream is stripped of its clocks, the raw data dumped into a solid state memory and compared to the incoming stream until absolutely bit accurate, then re-clocked for an uncompromised, bit accurate, jitter-free signal. Streaming audio has sounded this good.
As a music server, the PWD can access and control any Digital Living Network Alliance (DLNA) compatible source such as a network hard drive (NAS) or stream directly off the Internet. As a preamplifer control center, the PWD connects directly to a power amplifier controlling both the volume and any of the seven connected sources. Powered by PS Audio's tagNplay controller, this system delivers ease of use and social fun for all.
Inputs for the PS Audio PerfectWave DAC include:
  • Two 12S over HDMI
  • One optical TOSLINK
  • One coax S/PDIF
  • One balanced AES/EBU
  • One 24-bit 96kHz USB
  • Network Bridge
Price and Availability
PS Audio's PerfectWave DAC/Bridge system is available now for $3,699.99.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
At $3,500/pair, the PS Audio FR5 stand-mount loudspeaker aims to capture the magic of the aspen Series in a smaller form factor.
At $3,999 each, PS Audio's two box solution has the latest innovations to take your digital music listening experience to the next level.
Can the new PS Audio aspen FR10 loudspeakers deliver flagship level performance for a third of price?
Digital Music Systems
Audiophile purist solution for digital music streaming supports DSD, 32-bit/352.8kHz PCM and is Roon Ready. The absence of a DAC at $1,999 is notable.
PS Audio's DirectStream MK2 DAC/Preamplifier up converts all digital audio signals to pure DSD and then to analog. Is this method better? Only your...
Book excerpt from Audiophile's Guide: The Stereo, explains how to think about budgeting for a high-end audio system.
PS Audio's flagship 600-watt hybrid tube/solid-state monoblock power amplifier is the last to be designed in partnership with legendary audio engineer Bascom H. King.
