PS Audio PerfectWave BHK 600 Mono Power Amplifiers Are Inflation Proof
PS Audio’s flagship 600-watt hybrid tube/solid-state monoblock power amplifier is the last to be designed in partnership with legendary audio engineer Bascom H. King.
PS Audio BHK 600 Mono Power Amplifier Black
Inflation and supply chain issues have impacted every company in high-end audio and there is no question that products have become a lot more expensive. We have seen some rather popular loudspeakers and turntables rise in price by almost 30% over the past 12 months; a change in price that has certainly impacted what some consumers are willing to spend. At the extreme top end of the market, products like the PS Audio PerfectWave BHK 600 Mono Power Amplifiers are designed for those who don’t to worry about spending $30,000+ on a single component (or a pair of amplifiers in this case).
PS Audio has just introduced a flagship 600-watt monoblock power amplifier for those with deep pockets and large loudspeakers. At $32,498 for a pair, PS Audio says their new PerfectWave BHK 600 Mono Power Amplifiers is the finest amplifier ever created by the company.
Could it be the perfect amplifier to complement PS Audio’s Aspen FR30 Loudspeakers ($28,499/pair)?
With 600 watts of power into 8 ohms (1,500 watts into 4 ohms), each BHK 600 is likely to need its own circuit breaker — probably rated 20 amp. That’s higher than the typical 15 amp breaker for home wall outlets, which means you’ll need an electrician for this install. Plus you may need an extra person or two. They’re 108 lbs each.
PS Audio BHK 600 Mono Power Amplifier Silver
The PerfectWave BHK 600 is fully balanced in operation from input to output, and can also be used in single-ended mode, offering a choice of balanced XLR or single-ended RCA inputs.
It features an input stage with two hand-selected vacuum tubes, operating in conjunction with a rectifier tube and an exclusive N-channel MOSFET output stage. The tube rectifier was chosen rather than a solid-state device because of its improved sonic characteristics that result from the reduction of switch-mode noise common to solid-state rectifiers.
The BHK 600 features a separate output-stage power transformer with a massive 1.6kVA capability – more than twice that of the PS Audio M300 mono amplifier – enabling the BHK 600 to drive even the most inefficient loudspeakers and difficult loads with ease.
PS Audio BHK 600 Mono Power Amplifier Silver Rear
The power supply has more than 300,000µf capacitance, and multiple N-channel MOSFET output devices for a high damping factor of greater than 100. The BHK 600 has two pairs of heavy-duty gold-plated copper binding posts, to facilitate speaker bi-wiring.
The amplifier is engineered for safe, reliable operation, with continuous microprocessor monitoring of power supply performance, bias levels and other parameters, and it features extensive protection circuitry. The BHK 600 can be left in Idle mode if desired, to assure optimum sonic performance at all times.
Like every PS Audio product, thorough attention has been paid to parts quality and construction. Though substantial in size and weight, the BHK 600 has a refined, understated appearance with angled and curved design elements that create a contemporary, yet classic look. The BHK 600 is available in silver or black.
Paul McGowan, PS Audio CEO noted: “We are honored to present the BHK 600 as a fitting tribute to the talents of Bascom H. King and his remarkable career. The BHK 600 is a statement product that conveys music with extraordinary clarity, resolution, and musical accuracy. But mostly, authority. In my nearly fifty years of high-end audio, I’ve never heard any amplifier take command as does the mighty BHK 600.”
Features
  • Vacuum tube input stage with vacuum tube rectifier
  • Fully balanced circuitry
  • RCA single-ended and XLR balanced inputs
  • 600 watts RMS into 8 ohms, 1,500 watts into 4 ohms, stable to 2 ohms for musical transients
  • >100 damping factor for exceptional loudspeaker control
  • Dual, solid copper-plated output binding posts facilitate bi-wiring
  • 1.6kVA output stage power transformer
  • Power supply with more than 300,000 µf capacitance
  • 12-volt input trigger for automated operation
  • 108 lb. (49 kg) each; 17.1″ wide by 11.2″ high by 14″ deep
Price & Availability
The PS Audio PerfectWave BHK 600 Mono Power Amplifier will be available in September 2022 at a US manufacturer’s suggested retail price of $32,498 per pair.
For more information: psaudio.com/products/bhk-mono-600-power-amplifier/
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Starting at $21,600, the high-end Burmester 232 Integrated Amplifier offers DAC and Phono pre-amp upgradability for $13,300 extra.
For $25K, TAD's Evolution Series 250-watt per channel stereo power amplifier promises even greater purity, responsiveness, and accuracy.
Goldmund's latest monoblock amp delivers 1050 watts RMS at 8 ohms for $260,000, yet it's one step below the top-of-the-line model.
At $3,500/pair, the PS Audio FR5 stand-mount loudspeaker aims to capture the magic of the aspen Series in a smaller form factor.
Using GaN technology, Starkrimson Mono Ultra Premium power amplifier boasts 250-watts of power at 8 ohms, 500-watts at 4 ohms.
The Marantz AV 10 Preamp/Processor and AMP 10 Power Amplifier are capable of delivering 15.4 channels of surround sound.
With 300-watts per channel RMS, Goldmund claims Telos 800 is one of the finest Stereo Power Amplifiers ever crafted.
