Preview: PS Audio’s Aspen FR5 Stand-mount Speaker
At $3,500/pair, the PS Audio FR5 stand-mount loudspeaker aims to capture the magic of the aspen Series in a smaller form factor.
PS Audio aspen FR5 Stand-mount Speakers White Lifestyle
PS Audio has introduced a new entry into its Aspen series speaker line, the FR5
Unlike the floor-standing FR10, FR20, and FR30 models, the FR5 is a compact stand-mounted speaker that is designed to deliver superior audio quality in a compact design that may be more suitable for small and medium-sized rooms.
What The FR5 Offers
The FR5 measures 14.5 inches high by 8 inches wide by 13 inches deep (28.25 inches high with optional stands). The drivers in the FR5 are purpose-designed and tuned for optimum performance in a two-way stand-mount configuration.
PS Audio aspen FR5 Stand-mount Speaker White Front No Grille
The Tweeter
The 2.5-inch planar magnetic ribbon tweeter is the same unit used in all aspen Series loudspeakers. It has a symmetrical push-pull design with a high-strength magnet and a diaphragm made from Teonex film, a material that provides exceptional clarity, transient response, and resolution.
Midrange/Woofer
The aspen FR5 features a newly-designed 6.5-inch cast frame midrange/woofer made from Curv woven polypropylene, a material that is drawn into thin monofilaments and woven and reinforced using a proprietary process. The high-excursion driver employs a split-gap magnet structure with dual Faraday rings and a custom suspension.
PS Audio aspen FR5 Stand-mount Speaker White Rear
Passive Radiator
For additional support, the FR5 includes a rear-firing 6 by 9-inch passive radiator. This extends low-frequency extension down to 30 Hz.
Tech Note: The FR5 drivers are mounted on a thermoset resin front baffle that adds rigidity and minimizes diffraction effects.
Enclosure
PS Audio’s aspen FR5 utilizes a new enclosure technology, with viscoelastic damping sheets between the bracing and cabinet side walls, and around the woofer. This minimizes unwanted enclosure vibrations and contributes to the FR5’s imaging and soundstage capabilities.
Crossover
The crossover uses air-core inductors, metalized poly capacitors, and wire wound resistors to ensure maximum sonic purity and seamless driver integration.
Additional Design Notes
The FR5’s minimal, but elegant design is complemented by its optional matching stand, which has an integrated wire management system and can be mass-loaded. The FR5 comes with magnetically detachable grilles.
From Paul McGowan, PS Audio CEO: “The FR5 was designed to bring the same level of uncompromising sound quality as all aspen Series speakers into any listening environment, and is ideal for living spaces where floorstanding speakers can’t be used. Although it’s small, the FR5 delivers powerful and dynamic sound with extended bass, and will play surprisingly loud even in larger rooms.
Comparison
PS Audio aspen Series Loudspeakers (FR5, FR10, FR20, FR30)
FR5FR10FR20FR30
MSRP (pair)$3,499$9,999$18,999$29,999
Speaker Type2-way
Stand-mount
3-way
Floorstanding
3-way
Floorstanding
3-way
Floorstanding
Color OptionsSatin White
Satin Black
Satin White
Satin Black
Satin White
Satin Black
Satin White
Satin Black
Enclosure TypeSealed
Passive Radiator
(1) 6×9″ oval rear-firing
Sealed
Passive radiator
(3) 6×9” oval rear-firing
Sealed
Passive radiator
(2) 10” side-firing passive radiators
Sealed Two-piece
Sealed upper cabinet mid-tweeter module
Passive radiator lower cabinet
(4) 10” side-firing passive radiators
High-Frequency Transducer 1 x 2.5-inch planar magnetic ribbon tweeter with Teonex diaphragm1 x 2.5” planar magnetic ribbon tweeter with Teonex diaphragm1 x 2.5” planar magnetic ribbon tweeter with Teonex diaphragm2 x 2.5” planar magnetic ribbon tweeter with Teonex diaphragm
Midrange Transducer 1 x 6.5” cast-frame, Curv woven polypropylene, split-gap magnet structure with dual copper Faraday rings1 x 8” planar magnetic with Teonex diaphragm1 x 10” planar magnetic with Teonex diaphragm1 x 10” planar magnetic with Teonex diaphragm
Low-Frequency Transducer2 x 6.5” woofers, cast frame, non-woven carbon fiber PMI foam sandwich cone, advanced magnet structure2 x 8” woofers, cast frame, carbon fiber Rohacell sandwich cone, 12 lbs advanced magnet structure4 x 8” woofers, cast frame, aluminum cone, 12 lbs advanced magnet structure
Crossover Frequency1,750 Hz 550 Hz, 1,750 Hz – Linkwitz-Riley 4th order acoustic400 Hz, 2500 Hz – Linkwitz-Riley 4th order acoustic00 Hz, 2500 Hz – Linkwitz-Riley 4th order acoustic
Sensitivity (2.83v @ 1m)83.5 dB86.5 dB87 dB88 dB
Nominal Impedance6 ohms
(5.6 ohms minimum)
4 ohms
(3.3 ohms minimum)
4 ohms
(3.5 ohms minimum)
4 ohms
(3.6 ohms minimum)
Recommended Amplifier Power50-150 watts50-125 watts50-300 watts100-600 watts
Frequency Response35Hz-20kHz (-6dB) half-space;
30Hz (-6 dB) in-room
32Hz-20kHz (-6dB) half space;
25Hz (-6 dB) in-room
23Hz-20kHz (-6dB) half space;
20 Hz (-6dB) in-room
28Hz-20kHz (-6dB)
Dimensions14.5″ x 8″ x 13″ (speaker only),
optional stand, 28.25 x 11.75 x 14 inches
41.5” x 11.75” x 16.25” with base (8” width not including base)50.5” x 16” x 18.75″60.5” x 16” x 25.75” with base (10” width not including base)
Weight26.6 lbs. (12.1 kg)
stand, 13.7 lbs. (6.2 kg)
75 lbs (34.1 kg)133 lbs (60.3 kg)230 lbs (104.5 kg)
PS Audio Designer’s Intro
Chris Brunhaver, PS Audio Loudspeaker Engineer
Initial Impressions
The time for the release of the PS Audio aspen FR5 is interesting as it follows the recent release of the Monitor Audio Studio 89. The Studio 89 is priced almost $1,000 less per pair, but packs in a lot of tech and design elements that could be stiff competition for the FR5.
In addition, there are other strong contenders including the Focal Aria Evo X No.1, DALI RUBIKORE 2, or KEF R3 Meta.
PS Audio aspen FR5 Stand-mount Speakers in White and Black
Price & Availability
The Aspen FR5 will be available in August 2024 at a suggested retail price of $3,499 USD per pair from PS Audio or Authorized Dealers
Tip: The optional stands will be available at $500 USD per pair also from PS Audio and authorized dealers.
Related Reading
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
On this episode Caleb Denison, formerly of Digital Trends, shares his thoughts on 2025 TVs along with the launch of his new YouTube channel,...
HDTV 4K & 8K TV
DTS:X is an immersive surround sound format that is both similar to and different from Dolby Atmos. Find out how DTS:X and its variations...
Does it make sense to spend more than most audiophiles spend on their entire system on a little box that makes your power clean?
HDTV 4K & 8K TV
The well known TV reviewer and tech journalist extraordinaire has announced the launch of a new company, CD Creative Media LLC and a new...
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Discover the best affordable Hi-Fi brands of 2025 leading the stereo audio revival with premium sound at budget-friendly prices.
