PS Audio’s New aspen FR10 Loudspeakers are $9,999 a pair
Can the new PS Audio aspen FR10 loudspeakers deliver flagship level performance for a third of price?
PS Audio aspen FR10 Loudspeakers White Lifestyle without grilles
PS Audio today announced its third and least expensive floorstanding loudspeaker in its aspen series. At $9,999/pair, the new aspen FR10 loudspeakers are smaller and lighter than the FR20 ($18,999) and FR30 ($29,999) for easier placement in a room.
Paul McGowan, PS Audio CEO noted, “The aspen FR10 embodies more than 50 years of experience in audio in learning what works in a loudspeaker, and what it takes for a speaker to ‘disappear’ in a listening room and deliver a magical musical experience. Our goal with the aspen FR10 was to offer no-compromise full-range loudspeaker performance in a smaller, more affordable form factor that fits easily into smaller and medium-sized rooms.”
PS Audio aspen FR10 Loudspeakers White Front and Back
aspen FR10
The slim 3-way floorstanding tower features PS Audio’s acclaimed push-pull planar magnetic midrange and high-frequency driver technologies, complemented by ultra-low-distortion, linear-magnet woofers, high-excursion passive radiators, and a host of additional refinements.
All the drivers in the FR10 are custom-designed from the ground up. The 8-inch planar ribbon midrange and 2.5-inch planar ribbon tweeter employ a push-pull design with an identical symmetrical motor structure on either side of their driver diaphragms. This inherently linear configuration provides lower distortion than conventional single-sided magnet structures, along with higher efficiency.
The midrange and high-frequency drivers employ high-strength magnets and diaphragms made from Teonex® film, a thin, highly stable material that provides exceptional transient response and resolution, with a fast, clean decay. The drivers are housed in a sealed sub-enclosure to ensure maximum clarity and freedom from internal cabinet colorations.
PS Audio aspen FR10 Loudspeaker Rear Inputs Black
The PS Audio aspen FR10 utilizes dual 6.5-inch cast-frame woofers with a non-woven carbon fiber PMI foam sandwich cone, for an articulate response that complements the speed and transparency of the planar-magnetic midrange and high-frequency drivers. The woofers utilize a split magnetic gap with dual copper shorting rings, and have a large 3/4-inch peak-to-peak linear excursion for low distortion and a dynamically responsive bass output. The woofers are augmented by three flat-piston carbon fiber passive radiators. The FR10 offers wide range frequency response from 32 Hz – 20 kHz (- 6 dB, half-space; 25 Hz – 6 dB in-room).
The FR10’s slim enclosure measures 41.5 inches high by 8 inches wide (11.75 inches wide with its stand) by 16.25 inches deep. It’s available in a striking new matte finish in either black or white, and comes with magnetically detachable grilles. The aspen FR10’s room-friendly design makes it easy to set up and enjoy, and the FR10 comes with a handy setup booklet and CD to get the most out of the speaker. The FR10 has a visually distinctive “floating” appearance, with a curved bottom and an anodized aluminum base that is supplied with mounting feet that can be used with either removable stainless-steel spikes, or a soft rubber foot underneath.
How do they sound?
Having not heard these yet, we can only share PS Audio’s claims. They say the aspen FR10 deliver authoritative bass, an inviting midrange, smooth, extended highs, wide dynamic range, and palpable imaging on a wide and deep soundstage. Ultimately, they’re designed to appeal to the most demanding audiophiles and music aficionados craving extraordinarily low distortion, killer bass, and seamless tonality.
PS Audio aspen FR10, FR20 and FR30 Loudspeakers in white
Comparison
FR10FR20FR30
MSRP$9,999/pair$18,999/pair$29,999/pair
Color OptionsSatin White,
Satin Black
Pearl White,
Sable Black
Pearl White,
Sable Black
Enclosure TypePassive radiator (three 6×9” oval rear-firing)Passive radiator (two, 10” side-firing passive radiators)Two piece – Sealed upper cabinet mid-tweeter module, Passive radiator lower cabinet (four 10” side-firing passive radiators)
High Frequency Transducer2.5” planar magnetic with Teonex diaphragm2.5” planar magnetic with Teonex diaphragm2 x 2.5” planar magnetic with Teonex diaphragm
Mid Frequency Transducer8” planar magnetic with Teonex diaphragm10” planar magnetic with Teonex diaphragm10” planar magnetic with Teonex diaphragm
Low Frequency Transducer2 x 6.5” woofers, cast frame, non-woven carbon fiber PMI foam sandwich cone, advanced magnet structure2 x 8” woofers, cast frame, carbon fiber Rohacell sandwich cone, 12 lbs advanced magnet structure4 x 8” woofers, cast frame, aluminum cone, 12 lbs advanced magnet structure
Crossover Frequency550 Hz, 1750 Hz – Linkwitz-Riley 4th order acoustic400 Hz, 2500 Hz – Linkwitz-Riley 4th order acoustic400 Hz, 2500 Hz – Linkwitz-Riley 4th order acoustic
Sensitivity (2.83V @ 1M)86.5 dB87 dB88 dB
Nominal Impedance4 ohm (3.3 ohm minimum impedance)4 ohm (3.5 ohm minimum impedance)4 ohm (3.6 ohm minimum impedance)
Recommended Amplifier Power50-125W50-300W100-600W
Frequency Response32 Hz-20 kHz (-6dB) half space, 25 Hz (-6 dB) in-room23Hz-20kHz (-6dB) half space, 20 Hz (-6dB) in-room28Hz-20kHz (-6dB)
Dimensions (HxWxD)41.5” x 11.75” x 16.25” with base (8” width not including base)50.5” x 16” x 18.75″60.5” x 16” x 25.75” with base (10” width not including base)
Net Weight75 lbs (34.1 kg)133 lbs (60.3 kg)230 lbs (104.5 kg)
Price & Availability
The PS Audio aspen FR10 loudspeakers are available now for $9,999/pair at psaudio.com in satin white or satin black.
1 Comment
1 Comment
  1. Mel
    December 20, 2023 at 3:59 am
    I wonder why they rate their frequency response at -6dB instead of -3dB. They don’t want to be compared to competitors, or show better numbers for less educated, or just a technical reason?
Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Podcasts
In celebration of Shure's 100th Anniversary, company historian Michael Pettersen reveals how music, entertainment and culture have been shaped by Shure.
HDTV 4K & 8K TV
The well known TV reviewer and tech journalist extraordinaire has announced the launch of a new company, CD Creative Media LLC and a new...
On this episode Caleb Denison, formerly of Digital Trends, shares his thoughts on 2025 TVs along with the launch of his new YouTube channel,...
HDTV 4K & 8K TV
With a 120 Hz OLED panel, perfect blacks and an affordable price, LG's B4 may be the value pick for price-conscious TV buyers right...
Does it make sense to spend more than most audiophiles spend on their entire system on a little box that makes your power clean?
Podcasts
Nick Brown, SVS VP of Marketing reveals some surprising ways to get better sound from your hi-fi and home theater system, and gear you...
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
