ProMounts Announces Nationwide Distribution of Its Product Lines
December 21, 2005 — Culver City, CA — ProMounts, Inc. announced today that it has secured nationwide distribution of its entire product line to be exhibited in Booth 21661 at CES, 2006 in Las Vegas, including the new UA-PRO 100 and UF-PRO mounts.
“Ingram Micro and SED will be distributing ProMounts products nationwide,” noted Larry Lacross, Vice President of Sales and Marketing. “In addition, a strong nucleus of Cedia distributors is in place to support the Pro AV channel in every major region in the US. Thunder Marketing will distribute ProMounts products in Canada. ProMounts products can also be found on the shelf in DataVision, a premier retailer serving New York City. Numerous OEM arrangements have been signed as well.”
The UA-PRO 100 is the first small LCD articulating mount in the industry with a fully polished chrome finish, full wire management along with flat, tilt, pivot and landscape/ portrait adjustability, with a single touch. The UA-PRO 100, manufactured from high quality, heavy gauge steel construction that supports up to 30 lbs., features unmatched durability and ample space for wire management to make installation of the mount a snap.
Applications for the UA-PRO 100 are literally anywhere a small LCD screen needs convenient mounting: the office, the kitchen, bathroom, medical suite, student rooms, and dorms. The UA-PRO 100 is available in a modern fully polished chrome finish. Mounting hardware for different wall types — and theft-resistant security fasteners are included. The UA-PRO 100 comes in both clamshell and retail packaging with a full lifetime warranty. Suggested retail price is $149.00
The ultra-flush, universal design UF-PRO allows vertical and horizontal adjustment of a monitor after installation, and fits over 95% of current flat plasma and LCD screens made today, including most 37″ to 60″ screens. The new UF-PRO is manufactured from high quality, heavy gauge steel construction that supports up to 175 lbs. It is the thinnest, flattest universal versatile flush mount available in the market, measuring only 0.98″ from the wall, with up to 3″ of vertical adjustment available after initial installation.
The UF-PRO is available in either a black or silver finish, with only three main parts needed for easy installation. Horizontal and vertical position adjustments allow perfect positioning of the screen regardless of the distance of wall studs. Mounting hardware for different wall types and theft-resistant security fasteners are included. Suggested retail price is $199.00.
ProMounts, Inc., www.promounts.com, is the new leader in commercial and residential mounting products. ProMounts offer the flushest mounts in existence, manufactured from the highest quality materials available, featuring unmatched durability and ample wire management. ProMounts is excited to introduce V-BAR technology, which for the first time ever allows vertical and horizontal adjustment of the monitor, after installation.
ProMounts is located at 5741 Buckingham Way, Unit C, Culver City, CA 90230,
Tel: 310-645-6400, Fax: 310-868-2751, email: info@promounts.com. Digital images are available at www.promounts.com. PR and media contact is Al Abrams, Abrams Creative, 818-343.6365, Fax: 818-343-6366, e-mail: abrams@publicist.com.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
