projectiondesign avielo radiance RLS DLP Projector
World's First Remote Light Source (RLS) 1080p Projector
projectiondesign's patent-pending avielo radiance RLS projector puts the lamps, thermal management and maintenance away from the projector head to a rack-mount unit up to 100ft (30 meters) away. Light gets carried to the projector head on a rugged line called a Liquid Light Guide (LLG). The flexible LLG uses a water-based liquid to transfer the light to the projector head, so one can project from virtually anywhere and do the required maintenance in rooms separate to the projection environment. These qualities make it ideal for installations in home theater rooms where background noise needs to be eliminated and silent and in spaces where real-estate is premium. All maintenance can be performed remotely in the rack-mounted enclosure situated up to 100 ft (30 meters) from the projector head using a Liquid Light Guide. avielo by projectiondesign sees this technology as the way forward for projection. All technology incorporated inside this projector is designed, developed and manufactured in Norway.
The avielo radiance RLS builds upon the successful avielo radiance, the avielo radiance RLS features full HD 1080 resolution, high quality 10-bit video processing, creating a captivating image in a projector that can be easily placed near the viewer without disturbing fan noise.
Recommended image size: up to about 280cm wide. Resolution: 1920 x 1080 pixels. Technology: DLP®
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
