Proficient Audio AW8070V Outdoor Speakers Announced
AW8070V Makes It Easy For Installers Doing Larger Sound Systems With A Single Amplifier
Designing outdoor audio systems for large properties just became a lot easier, thanks to the introduction of Proficient Audio’s AW8070V.
This speaker is designed for use with 70-volt audio systems. A 70-volt system allows a single amplifier to power many speakers. It also permits speakers to be “daisy-chained,” or connected to each other rather than requiring a separate cable from each speaker to the amplifier. All of these characteristics greatly simplify the design of indoor or outdoor sound systems for large properties.
The AW8070V employs a rugged, weather-resistant ABS housing and a powder-coated perforated aluminum grille. The speaker contains two 1-1/4-inch aluminum-dome tweeters that pivot to direct the sound where desired. The dual tweeters provide coverage over a larger area than a single tweeter can, without requiring the installer to mount two speakers in each coverage area. An 8-inch polypropylene-cone woofer provides the bass. A tilting bracket with theft deterrent security bolts secures the speaker to a wall, eave, fence, or post.
Thanks to the AW8070V’s transformer tap switch, the installer can adjust the level of each speaker in a system individually even if all are powered from the same amp. Four settings (8, 16, 32, and 64 watts) are available, and there’s also a 4-ohm transformer bypass setting that allows the speaker to be used with conventional audio systems.
The AW8070V retails for $435 each and is available in black or white. It is rated to handle up to 90 watts of power, with sensitivity of 89 dB and frequency response of 70 Hz to 20 kHz. It measures H 9 x W 16 x D 9 inches.
“The AW8070V is a more economical way to go when you need really big coverage,” said Keith Marshall, President of Proficient Audio. “It lets you run speaker cables practically as long as you want, attach as many speakers as you need, and power the whole system with a single 70-volt amplifier, so it eliminates most of the problems of using conventional audio gear in large backyards and estates.”
Be sure to visit our online AW8070V Newsroom at: www.proficientaudio.com/news/AW8070V
For more information and specifications on the AW8070V and other Proficient Audio products, visit www.proficientaudio.com.
AW8070V
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
