Procella Audio P8 Bookshelf Speakers
Procella Audio revealed a set of improvements to the THX Approved P8 loudspeaker that elevate its acclaimed performance. The P8 now uses a new 1.5 inch Neodymium compression driver mounted on a custom Procella constant directivity waveguide and a new 8 inch woofer driver, all made specifically for Procella Audio. With these pro audio components, the P8 achieves improved high-frequency extension, higher power handling, lower distortion and even better dispersion control around its crossover frequency. The new version of the P8 is shipping now worldwide, and its price remains unchanged at a suggested U.S. retail price of USD $2,599.00 each.
The Procella P8 is a high-output screen channel or surround channel speaker, designed for high-resolution, wide dynamic range playback of 24 bit/96KHz recordings and soundtracks. It is capable of THX reference level (105 dB continuous) at a distance of 4 meters. Its Identical Voice design and crossover makes the speaker ideal for use in systems with Procella P815 and P6 loudspeakers, achieving flat phase response and ultra-low group delay for optimized three-dimensional room response, and symmetrical coverage of high frequencies to all seats in small and large rooms alike. With a shallow depth of just 7.9″ and a back baffle angled at 7.5 degrees, the speaker is ideal for wall mounting. The speaker is THX Approved for integration into professional rooms, including THX Certified Screening Rooms and THX pm3 Studios (professional Multichannel Mixing and Monitoring).
“These new components make the speaker
capable of more output at both frequency
extremes, increasing both its accuracy and
its maximum output.”
— Anders Uggelberg, Founding Partner and
Lead Designer of Procella Audio
With a 1.5 inch voice coil and a 1 inch throat, the new compression driver has very high efficiency and low distortion, particularly in comparison to dome tweeters. Mounted on a Procella-designed constant directivity waveguide, it delivers smooth high-frequency response throughout the listening area, and it provides greater extension of the upper highs to 20 KHz. The new 8″ woofer, which can be identified by its round basket shape, has increased output capability in the mid-bass area near its recommended subwoofer crossover point of 80 Hz, as well as higher power handling overall, further improving the P8's dynamic range and maximum output. A new crossover design completes the upgrades, working in combination with the new drivers to improve the radiation pattern of the loudspeaker in the critical midrange around its crossover point, producing even greater coherency of sound.
Highlights
  • Neodymium 1.5 inch compression driver mounted on Procella-designed constant directivity waveguide improves high-frequency extension
  • 8 inch woofer driver increases the power handling and output of the P8, especially at low frequencies around the recommended subwoofer crossover point
  • New version of the P8 is shipping now worldwide with no price increase, making the speaker an even greater value
About Procella Audio
Manufactured in Sweden and distributed globally, with offices in Los Angeles, Sydney and Stockholm, Procella Audio was launched in 2006 by two former Directors of DTS Europe, who created the first Procella speaker system for a 32 seat preview theater at the DTS Europe headquarters outside London. Procella loudspeakers deliver a powerful and dynamic cinema audio experience for the world's finest home theaters, professional studios and screening rooms.
Hisense S5 DecoTV Front Lifestyle
Hisense’s S5 DécoTV proves not every TV needs to be enormous, blindingly bright, or pretending to be a gaming rig—just a smart, good-looking 32-inch...
LG Micro RGB Evo TV 2026 LG Micro RGB Evo TV 2026
LG previews its Micro RGB evo MRGB95B 4K TV ahead of CES 2026, marking a rare LCD shift with bold color claims, AI processing,...
2026 Samsung R95H 4K TV Angle 2026 Samsung R95H 4K TV Angle
Samsung expands its Micro RGB LED TV lineup for 2026, adding 55–100″ models alongside the 115″ flagship as competition in RGB-based TVs heats up.
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
