Preview: Pro-Ject’s XA B Transparent Acrylic Expands Their Balanced Turntable Lineup
At $1,499, the Pro-Ject XA B turntable comes with a Pick it PRO Balanced cartridge for ‘True Balanced’ vinyl playback.
Pro-Ject XA B Acrylic Balanced Turntable Angle Lifestyle
Pro-Ject Audio’s latest X Series turntable, model XA B, aims to deliver the highest quality audio with a premium aesthetic, right out of the box. In addition to offering a ‘True Balanced Connection’ via the 5-pin DIN output, the turntable features a plinth constructed of transparent acrylic, a material that has existed in Pro-Ject’s repertoire for decades.
At $1,499, the XA B is sandwiched between Pro-Ject’s X1 B ($1,299) and X2 B ($1,799) which we reviewed back in February. All three models are fully balanced turntables but there are some key differences.
Pro-Ject Pick-it Pro Balanced Cartridge Lifestyle
What’s New
  • 5-pin DIN balanced output (no RCA output, but DIN > RCA/ground cable included)
  • Balanced MM cartridge (new cable & balanced phono pre required for balanced operation)
  • 10” aluminum armtube & wider plinth to accommodate that length
  • Different isolation feet
  • Different platter (die-cast TPE-damped aluminum like Debut PRO)
  • Includes Record Puck E
Pro-Ject XA B Turntable Feet Exploded
Design
In turntable design & manufacture, thoughtful selection of materials is critical. Each material has its own resonant frequency that must blend well with the other materials involved. In the XA B development process, measurement and critical listening revealed that acrylic alone can potentially over-damp sonics. This is why Pro-Ject made the decision to utilize a livelier-sounding 10-inch one-piece aluminum tonearm, die-cast aluminum platter, Pick it PRO Balanced cartridge and purpose-selected isolation feet.
Together with the acrylic plinth, Pro-Ject says these materials render music in a lively, dynamic and detail-rich manner. With the simple addition of the proper cable and any of Pro-Ject’s Phono Box S3 B, Phono Box DS3 B, Tube Box DS3 B or Phono Box RS2 balanced phono preamps, listeners can take the plunge into the world of balanced vinyl playback.
The following are balanced cable types that would do the trick: 5-pin DIN > Mini XLR or 5-pin DIN > XLR (depending on the phono preamp).
Pro-Ject XA B Turntable Top
Pro-Ject XA B Acrylic Balanced Turntable Rear Angle Lifestyle
Pro-Ject XA B
Comparison
X1 BXA BX2 B
MSRP$1,299
$1,099
$1,499$1,799
$1,599
PlinthMDFAcrylicMDF (50mm)
Speeds33/45rpm, 45/78rpm
(flat, round belts)
33/45rpm
(electronic speed change)
33/45rpm,
45/78rpm
(flat, round belts)
Speed variance±0.30% (33rpm),
±0.25% (45rpm)
0.30% (33rpm),
0.20% (45rpm)
±0.25% (33rpm),
±0.20% (45rpm)
Wow & flutter±0.15% (33rpm),
±0.13% (45rpm)
0.13% (33rpm),
0.12% (45rpm)
±0.12% (33rpm),
±0.10% (45rpm)
Platter1.5 kg (20mm) resonance-free acrylic record platter1.7 kg (30mm) die-cast aluminum platter2 kg, (30mm) resonance-free acrylic record platter
Tonearm8.6” one-piece carbon-wrapped aluminum10″ one-piece aluminum arm tube9” one-piece carbon-wrapped aluminum
Effective tonearm mass10 g10 g13.5 g
Dimensions (WxHxD lid closed)415 x 135 x 335 mm
(16.34 x 5.31 x 13.19 inches)
460 x 130 x 340 mm
(18.11 x 5.12 x 13.39 inches)
460 x 150 x 340 mm
(18.11 x 5.91 x 13.39 inches)
Weight7 kg (15.43 lbs)8 kg (17.64 lbs)10 kg (22.05 lbs)
Outputs5-pin mini XLR output,
RCA phono
5-pin DIN balanced output5-pin mini XLR output,
RCA phono
Isolation feetAdjustable TPE-damped isolation feetSpecial TPE-damped height-adjustable metal feetAdjustable TPE-damped isolation feet
CartridgeSumiko Rainier MMPick it Pro Balanced MM cartridgeSumiko Rainier MM
Included15V 0.8A DC power supply, dust cover, DIN > RCA cable, felt mat15V/0.8A DC universal power supply
Pro-Ject XA B Turntable Tonearm Side
Pro-Ject XA B
Initial Thoughts
The XA B is the least expensive acrylic turntable among over a dozen balanced Pro-Ject Turntables priced up to $13,999. With a street price just $100 less than the X2 B, consumers have an interesting choice. However, Pro-Ject says the XA B’s longer 10-inch tonearm reduces tracking errors while delivering different sonics than a MDF base.
Pro-Ject XA B Turntable Front
Price & Availability
The Pro-Ject XA B Turntable is expected to be available in the U.S. beginning October 15, 2024 for $1,499 at Crutchfield and other authorized retailers.
For more information: pro-jectusa.com
2 Comments
2 Comments
  1. HW
    August 12, 2024 at 12:22 am
    Couldn’t a different name other than XA be chosen? AR had the XA turntable. Pro-Ject already has X1, XA should be X2 and X2 should be X3.
    • Ian White
      August 12, 2024 at 1:28 pm
      HW,
      I’m sure Pro-Ject has its reason for the name. Very few consumers outside of the audiophile kingdom (under the age of 50) will remember the venerable AR XA table. Sadly. Pro-Ject’s customer base is generally younger so the branding seems to be working.
      Best,
      Ian White
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Think you’ve seen it all? These 25 essential American films are the ones every true movie lover should own.
Over-Ear Headphones
Can the Meze Audio POET combine the sound quality of the ELITE series with the compact design of the LIRIC series, thanks to its...
$449 or $599, find out which Sumiko moving magnet phono cartridge is right for you?
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
