Pro-Ject Unveils X8 Turntable, Phono Box DS3B & Phono Box S3B Balanced Phono Preamps
Noise issues? The Pro-Ject X8, Phono Box DS3B, and Phono Box S3B Balanced Phono Preamps might be the solution you’re looking for.
Pro-Ject X8 Turntable with Phono Box S3 B
Almost 22 years ago, I invested in a very expensive turntable and felt that I had reached vinyl nirvana. I paid a professional $200 to properly install the cartridge, setup the table which had a finicky suspension system, and help me mount the turntable shelf to the wall.
My building at the time was a pre-war in downtown Toronto that needed an upgrade on the electrical front. Noisy to say the least.
No matter what I tried, my turntable setup always sounded noisy; ground loop issues, constant hiss, and it became a a source of depression (first world problems). Why bother spending almost $8,000 on such a system if it sounded terrible.
A local dealer suggested that I have my arm and table modified so that I could run a fully balanced rig; which also included upgrading to a balanced phono stage. I sold a few other items to facilitate the changes.
Extreme? Perhaps.
But when I listened to the same records that mattered to me — I was stunned by the differences in clarity, noise floor, and overall dynamics of the sound.
Does a balanced setup always sound better? Not necessarily and I’m not convinced that every manufacturer who markets “balanced” is really offering that.
Pro-Ject knows what it is doing and the prices on these new phono stages are quite sensible.
Sumiko and Pro-Ject USA are proud to announce the new Phono Box DS3BPhono Box S3B and X8 Turntable from Pro-Ject Audio Systems. The new products aim to offer listeners a truly balanced experience, resulting in dynamic sound, less noise and improved signal to noise ratios.
Pro-Ject Phono Box S3 B Silver Front
Pro-Ject Phono Box S3 B Silver Back
Pro-Ject Phono Box DS3 B Silver Front
Pro-Ject Phono Box DS3 B Silver Back
The Phono Box S3B and Phono Box DS3B round out Pro-Ject’s complete line of balanced phono stages, both offering a versatile MM/MC phono stage which features dual-mono circuitry, a fully symmetrical and discrete gain stage and
balanced inputs and outputs.
As the majority of Pro-Ject turntables offer a completely balanced signal from the
cartridge to the junction box, a truly balanced signal results in lower noise, and the sort of quiet, deep background typically only experienced in esoteric high-end systems.
Previously only available in more costly phono preamps, the balanced inputs allow the quietest connection between a moving coil cartridge and the phono stage, the new phono boxes uphold the reputation of high value, high performance the Pro-Ject brand is known for.
The new X8 Turntable is a true high-end solution with major technical features adapted from the Xtension 9 and 10 models.
The X8 includes a TPE damped mass-loaded platter, which is precision machined and balanced out of a single piece of aluminum, partially supported by opposing neodymium magnets which decreases the load on the main bearing.
This massive, perfectly balanced platter works in concert with the precision ceramic inverted main bearing to create a smoothly rotating base for your vinyl with perfect speed stability.
Sumiko Phono Cartridge
Pro-Ject X8 Turntable Belt
Pro-Ject X8
Price & Availability
Like all Pro-Ject Audio Systems products, the new models are handcrafted in Europe and will be available in the US in limited quantities via select Authorized Pro-Ject Dealers beginning April 2022.
Pro-Ject Phono Box S3 B Silver Inside
Pro-Ject Phono Box DS3 B Silver Inside
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
Are you one of those people who hates having to install a phono cartridge? The Waiting for Ideas PP-1 might be exactly what you're...
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
Audio Cables
At £1,000, Chord Company's PhonoARAY can minimize external interference and ground issues that may affect turntable performance.
Upgrade the sound of your turntable with our favorite MM and MC phono cartridges you can buy in 2024 without breaking the bank.
Looking for your first high-end audiophile turntable but don't want to spend more than $3,500 for something that will be your deck for many...
Our favorite audiophile turntables in 2023 include Pro-Ject, Rega, Technics, Orbit and more.
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
