Pro-Ject’s T1 EVO Series Turntables Make It Easier to Connect and Start Listening to Your Records
Starting at $449, Pro-Ject’s T1 Evo Series turntables come in three variations with or without Bluetooth and a built-in preamp.
Pro-Ject T1 Evo Turntable Lifestyle
2024 has been a busy year for turntable maker Pro-Ject Audio Systems. Since August, they have released the XA B Transparent Acrylic, the Debut PRO B, and Debut EVO 2. As a follow-up, Pro-Ject has announced the latest edition of T Series turntables, the T1 EVO, T1 EVO Phono, and T1 EVO BT
All of the EVO T1 models include several improvements such as a classic groove-slayer in the Ortofon OM10 MM phono cartridge, a larger Debut-sized sub-platter as well as electronic speed change for all 3 models.
Pro-Ject T1 Evo Turntable Colors
The precision-machined chassis remains free of resonant hollow spaces.
The high-mass tempered glass record platter is anti-resonant & great for rotational stability as well as providing a pleasing visual appeal.
The T1 EVO series incorporates an 8.6” 1-piece aluminum arm tube with high-quality bearings.
For added use flexibility, there are three models to select from as mentioned at the top of the article.
The T1 EVO is a conventional turntable that requires connection to a traditional phono input connection on an amplifier, stereo, or home theater receiver. If that is not possible, you need to place an external phono preamp between the turntable and the audio system.
The T1 EVO Phono takes it up a notch by providing the built-in MM phono preamp that’s also defeatable if you prefer a traditional connection.
The T1 EVO BT has a built-in phono preamp and is also equipped with Bluetooth (BT 5.0, aptX HD) that enables listeners to wirelessly play vinyl records on Bluetooth headphones, speakers, and compatible audio systems.
Ortofon OM10 cartridge on Pro-Ject T1 Evo turntable
Shared Features
No matter which model you choose, the T1 EVO series turntables some with a pre-installed OM10 MM cartridge.
Electronic speed change is included in all models (push-button control, no belt handling).
Pro-Ject T1 Evo turntable speed switch
The T1 EVO’s motor drives a belt attached to a larger anti-resonate subplatter (Debut-sized!) which rotates in a bearing assembly machined to tolerances within 0.001mm. It’s comprised of a stainless steel spindle in brass bushing. The full platter is 8mm-thick and is made of tempered glass.
The CNC-machined plinth (available in gloss black, satin white, or satin walnut laminates) uses no plastic and is carefully manufactured to eliminate resonant hollow spaces that would otherwise detract from the sound quality.
Pro-Ject T1 EVO Tonearm
The tonearm is 8.6 inches and is made of one-piece aluminum. It features a  low-friction, no-vibration tonearm bearing.
For added stability, the T1 EVO models all come with vibration-absorbing isolation feet.
To round out the look of the T1 EVO  Series as well as provide protection when vinyl records are played, Pro-Ject provides a transparent dust cover with adjustable hinges.
Pro-Ject T1 EVO Turntable Walnut Dustcover Open
Shared Specifications
  • Speed: 33 & 45rpm (electronic speed change)
  • Speed Variance: 0.7% (33rpm), 0.6% (45rpm)
  • Wow & flutter: 0.25% (33rpm), 0.23% (45rpm)
  • Signal to Noise Ratio (SNR): 65dB
  • Effective Tonearm Length: 218.5mm
  • Tonearm Overhang: 22.0mm
  • Effective Tonearm Mass: 8.0g
  • Counterweight: 5-10g (pre-adjusted)
  • Tracking Force Range: 0-5g (set at 1.75g)
  • Power Supply: 110-240V 50-60Hz 15V DC (800mA)
  • Power Consumption: 4.5W max
  • Dimensions (WHD): 415 x 100 x 335mm (16.34 x 3.94 x 13.19″)
  • Mass (weight): 3.8kg (8.38 lbs) net
OM10 Cartridge Specifications
  • Cartridge Type: MM (Moving Magnet)
  • Stylus Type: Elliptical
  • Channel Separation (1kHz): 22dB
  • Frequency Response:  20Hz to 22kHz
  • Tracking Angle (vertical): 20 degrees:
Initial Impression
Pro-Ject seems to be on a roll in 2024 with new turntable product releases. With the new T1 EVO series, Pro-Ject is offering three models with the same core features and cartridge with connectivity options that can suit your needs, and at an entry-level price point. One of these turntables may be just the right solution for you – definitely worth checking out.
Pro-Ject T1 Evo Turntable Black Front
Price & Availability
T1 EVO turntables are handmade in Europe and some with gloss black, satin white, or statin walnut finish and will begin shipping in the U.S. market in late October, retailing for:
Accessories Included:
  • Dust Cover
  • Felt Mat
  • Power Supply
  • Connect it Phono E RCA line or line/ground cable
Related Reading
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
Pro-Ject's Artist Series of turntables has expanded with a new offering paying homage to the legendary band from down under. The price might leave...
Are you one of those people who hates having to install a phono cartridge? The Waiting for Ideas PP-1 might be exactly what you're...
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
Audio Cables
At £1,000, Chord Company's PhonoARAY can minimize external interference and ground issues that may affect turntable performance.
The Best Audiophile CD Players of 2024 include Hegel, Luxman, Marantz, Rotel and more for the ultimate in compact disc playback.
Upgrade the sound of your turntable with our favorite MM and MC phono cartridges you can buy in 2024 without breaking the bank.
