Pro-Ject Unveils Power Box RS2 Phono For Turntables & Phono Preamplifiers
A LPSU for Pro-Ject and 3rd party turntables and phono preamps? The Pro-Ject Power Box RS2 Phono is coming.
Pro-ject X8 Turntable with Power Box RS2 Phono
Unlimited Power. Mace Windu underestimated the importance of it and look how that turned out. One of the key components of any piece of hi-fi, video hardware, or computer system is its power supply. The largest manufacturer of audiophile turntables has a new accessory for not only its own turntables and phono pre-amplifiers – but 3rd party products as well. The Pro-Ject Power Box RS2 Phono is here and the Pro-Ject Debut PRO we just sent back is grumbling.
Why would you need an external linear power supply for your turntable or phono preamp?
Better speed stability, surge protection, less background noise, and an improvement in overall detail and resolution. Does it always work?
Having tried a number of liner power supplies with desktop headphone amplifiers, DACs, and my Roon Nucleus Music Server — my answer would be that the results were inconsistent.
I certainly heard less noise through my desktop active loudspeakers, but the resolution didn’t take a radical jump and there was not a massive increase in the size of the soundstage which is a purported benefit.
Pro-Ject X8 Turntable with Power Box RS2 Phono Front Black
In the case of the Power Box RS2 Phono, it would make sense that it would improve the performance of a turntable by providing a more stable power supply for the motor improving the speed stability.
The Pro-Ject Power Box RS2 Phono’s built-in transformer has a much higher power reserve compared to the standard power adapter and is able operate with flexibility given its low output impedance and large filtration capability.
A linear power supply consists of a massive toroidal transformer which avoids penetration of any interference that may affect the audio component. With a linear power supply, background noise is all but eliminated and sound-staging is improved, enhancing detail resolution and overall audio performance.
Pro-ject Power Box RS2 Phono Preamplifier Rear
Features:
  • All-in-one power supply for turntables and phono preamplifiers
  • Compatible with any Pro-Ject 15V DC turntable or any other with a 15V DC input
  • Compatible with Pro-Ject phono preamplifier (18 – 20V) (will work with 3rd party phono preamps at either 18V or 20V DC at up to 1.5A)
  • Cleaner power from non-switching power supply
  • Soft-start system avoids current inrush
  • Toroidal transformer
  • Mains-isolating transformer with copper shield
  • Secondary voltage rectification with precise regulation
  • High filtration capacity
  • Low ESR capacitors
  • Low noise components with surge protection
Price & Availability
The Pro-Ject Power Box RS2 Phono is manufactured in Europe and will be available in black of silver aluminum housing through Fine Sounds Dealers beginning in October 2022 for $1,199.00 USD.
For more information: pro-jectusa.com
Related reading:
4 Comments
4 Comments
  1. Steven Denfeld
    September 28, 2022 at 9:07 pm
    This maybe had me until I saw the $1200 price tag. That’s getting into elitist snake oil territory there, especially when Pro-Ject’s own High Power-it would likely provide most of this unit’s benefit at a fraction of the cost.
    Bravo to that opening sentence in this write-up, though!
    • Ian White
      September 29, 2022 at 12:55 am
      Steven,
      Do what must be done.
      Interesting side story: The original price was $699 USD and it changed 24 hours later to $1,199 USD.
      Ian White
      • Steven Denfeld
        September 29, 2022 at 4:51 pm
        That’s bizarre. $700 makes more sense to me.
        • Ian White
          September 29, 2022 at 9:57 pm
          Steven,
          At $700, I was inclined to get one for my Pro-Ject phono stage. At $1,199…I’m inclined to buy a Moon by SimAudio LP110 V2 and Sumiko Wellfleet cart and call it a day.
          Ian White
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
Pro-Ject's Artist Series of turntables has expanded with a new offering paying homage to the legendary band from down under. The price might leave...
Are you one of those people who hates having to install a phono cartridge? The Waiting for Ideas PP-1 might be exactly what you're...
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
Audio Cables
At £1,000, Chord Company's PhonoARAY can minimize external interference and ground issues that may affect turntable performance.
Upgrade the sound of your turntable with our favorite MM and MC phono cartridges you can buy in 2024 without breaking the bank.
Looking for your first high-end audiophile turntable but don't want to spend more than $3,500 for something that will be your deck for many...
Our favorite audiophile turntables in 2023 include Pro-Ject, Rega, Technics, Orbit and more.
