Pro-Ject MaiA DS3 and Stereo Box S3 BT Integrated Amplifier and Receiver Unveiled
Pro-Ject are expanding their range of electronics with the new MaiA DS3 and Stereo Box S3 BT Integrated Amplifier and Receiver.
Pro-Ject MaiA DS3 and CD Box DS3 Lifestyle
Pro-Ject has had a very busy 2022 with an expanded range of turntables, phono cartridges, loudspeakers, and electronics. The Debut PRO and X2 B turntables have secured some serious bragging rights offering superb vinyl playback in the $1,000 to $2,000 price range.
On the amplifier side of the ledger, Pro-Ject have been very aggressive introducing new models that support digital streaming including hi-resolution PCM and DSD playback, whilst still offering dedicated CD players and streamers that can be integrated into any type of system.
Another advantage for Pro-Ject is their ability to manufacture almost everything in-house, which allows them to minimize already high shipping costs, and keep production costs lower. Their ability to manufacture very high quality components in rather large quantities is unmatched in the high-end audio category.
MaiA DS3 Stereo Integrated Amplifier Front
Fine Sounds Americas and Pro-Ject USA are proud to announce the
new Pro-Ject MaiA DS3 and Stereo Box S3 BT integrated amplifier and receiver models that are available now.
The MaiA DS3 Stereo Integrated Amplifier is a compact, high-fidelity amplifier and receiver for up to (9) analog and digital audio sources.
MaiA DS3 Stereo Integrated Amplifier Rear
Boasting 150 watts of power per channel into 4 ohms, this dual-mono design features a built-in phono stage (MM/MC), DAC, headphone amp, Bluetooth receiver and a wide range of digital and analog for various uses.
The internal DAC supports up to 32-bit/192kHz PCM and DSD256.
The internal phono stage supports both MM/MC carts which is not something you see on every integrated amplifier in 2022; the MM stage offers 40dB of gain (47k ohms) and you get 60dB of gain (100 ohms) with the MC stage.
Bluetooth codec support includes BT 5.0, aptX, aptX HD, and A2DP.
Available in a black or silver aluminum chassis, the design is sleek and rugged. Optional magnetic wooden side panels are available separately in walnut, rosenut and eucalyptus.
Pro-Ject Stereo Box S3 BT Integrated Amplifier
The Stereo Box S3 BT is an ultra-compact stereo integrated amplifier and receiver with dual analog inputs and an aptX capable BT 5.0 audio input for connection to Bluetooth devices.
Pro-Ject Stereo Box S3 BT Integrated Amplifier Rear
The (2) pair of RCA line inputs and (2) channels of 40 watts into 4 ohms are packaged beautifully in a protective aluminum casing, available in both black and silver.
The unit includes isolated speaker outputs as well as a stereo preamp output for driving a subwoofer or larger amplifier.
Like all Pro-Ject Audio Systems products, the new models are handcrafted in Europe and will be available in the US in limited quantities via select Authorized Pro-Ject Dealers beginning November 2022.
Suggested MSRP as follows:
Pro-Ject’s Colorful Audio Hi-Fi Set Is Ideal For Your Office or Bedroom
Pro-Ject Premieres New E1 Turntables for 2022
Pro-Ject Debut PRO Turntable Review
1 Comment
1 Comment
  1. Eugene Niemierzycki
    May 14, 2023 at 5:46 am
    Such confusion with model letters and numbers and of course price points. I have an old transport and DAC with useless remote! I do believe Pro Ject makes pretty good equipment but this confusion with the model numbers is a complete turn off. I’d look elsewhere where I don’t have to go back end forth trying to figure out if equipment is an integrated, a DAC or a Transport! Very poor marketing for such a fine hi-fi manufacturer!
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
At $1,499, the Rotel DX-5 is a compact sized 25-watt per channel stereo integrated amplifier with Bluetooth, HDMI-ARC and Roon.
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
Rega's forthcoming Brio MK7 Integrated Amplifier will be available this month and is creating a stir with its internal DAC for only $1095.
Pro-Ject's Artist Series of turntables has expanded with a new offering paying homage to the legendary band from down under. The price might leave...
Advance Paris brings its range of affordable hifi components to the U.S. market, which feature blue VU meters and tube amplification.
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
Looking for your first high-end audiophile turntable but don't want to spend more than $3,500 for something that will be your deck for many...
