Pro-Ject Debut Reference 10 Arrives at Bristol 2026 While New U.S. Distribution Signals Strategic Shift
Pro-Ject unveils the Debut Reference 10 and names a new U.S. distributor. With pricing updates and tariff shifts looming, what changes for buyers?
Pro-Ject Debut Reference 10 Turntable Lid Open
Big moves are unfolding for Pro-Ject Audio Systems on both sides of the Atlantic this weekend. At the Bristol Hi-Fi Show 2026, the Austrian analog specialist is set to unveil the Debut Reference 10, a new flagship for its long-running Debut turntable range. At the same time, the company has confirmed a major shift in its U.S. strategy with the appointment of a new exclusive distributor, effective March 1, 2026.
The Debut Reference 10 moves the series further upmarket with a 10-inch tonearm built from a carbon-fibre and aluminium sandwich construction, positioning it as the most technically ambitious model yet within the Debut lineup. It signals that Pro-Ject is not content to let its entry-level reputation define the brand’s ceiling; the original Debut PRO was awarded our Editors’ Choice Award twice in the turntable category and was replaced by the Debut PRO B in 2024.
Equally significant is the U.S. announcement. Pro-Ject Audio Systems, part of the Vienna-based Audio Tuning Group, has named Stereo Distribution LLC as its new exclusive American distributor. The move formalizes a new structure for the U.S. market and confirms that the previous Pro-Ject alignment within the McIntosh Group ecosystem, alongside brands such as McIntosh, Sumiko, and Sonus faber under the Bose Luxury Group umbrella is no longer in place.
Debut Reference 10 Specifications
Pro-Ject Debut Reference 10 Turntable Front
Pro-Ject Audio Systems positions the Debut Reference 10 as the most advanced model in its long-running Debut lineup, and the engineering choices reflect that step up.
At its core, the turntable is fitted with Pro-Ject’s Pick it Pro Balanced cartridge and includes a Mini XLR balanced output. That combination allows for a true balanced signal path from cartridge to phono stage, which can reduce noise and improve signal integrity over longer cable runs. However, it does require a compatible balanced phono preamp to take advantage of the connection. Without one, you will not unlock the full benefit of the balanced design.
The Debut Reference 10 uses a 300 mm acrylic platter, chosen for its inherent resonance resistance. This sits atop a diamond cut aluminum sub platter, adding mass and rotational stability. The platter bearing consists of a high precision stainless steel axle seated in a bronze bushing, designed to maintain smooth rotation and long term durability.
pro-ject-debut-reference-10-turntable-corner
The chassis is constructed from hand painted MDF and supported by three height adjustable, damped aluminum feet. These feet are designed to provide stable leveling while helping to reduce the risk of acoustic feedback, particularly in environments where speakers share the same surface or room structure.
This is a belt driven turntable with the motor fully decoupled and suspended within the base to minimize vibration transfer into the platter and tonearm assembly. Electronic speed control allows convenient switching between 33 and 45 RPM, while manually moving the included round belt enables playback of 78 RPM records.
A Puck E record weight is included in the box, designed to help secure records more firmly to the platter surface for improved contact and stability during playback.
pro-ject-debut-reference-10-tonearm
The 10 inch one piece carbon aluminum tonearm measures 254 mm in effective length and has an effective mass of 16.6 g. It supports both adjustable azimuth and vertical tracking angle (VTA). By loosening two grub screws, users can continuously adjust tonearm height to accommodate cartridges of varying body heights or different platter mat thicknesses. This level of adjustability is not always standard in this price category and allows for more precise cartridge alignment.
Performance specifications are competitive for the class. Wow and flutter is rated at ±0.16 percent at 33 RPM and ±0.14 percent at 45 RPM. Speed drift is specified at ±0.4 percent at 33 RPM and ±0.5 percent at 45 RPM. Signal to noise ratio is listed at 68 dB.
Physically, the Debut Reference 10 is not some oversized statement deck. It measures 462 x 145 x 345 mm, which translates to roughly 18.2 x 5.7 x 13.6 inches (W x H x D), and tips the scale at 6 kg, or about 13.2 pounds net. Manageable, solid, and realistic for the kind of racks and consoles most people actually own. In the box, you get the essentials: a dust cover, a dedicated 78 RPM belt, and a 7-inch single adapter.
pro-ject-debut-reference-10-turntable-adjust
pro-ject-debut-reference-10-turntable-rear
The Bottom Line
Now here’s where it gets interesting.
The U.S. Supreme Court issued a ruling this morning related to tariffs that could have a meaningful impact on imported audio products. Could that work in favor of American buyers when this table finally lands? Possibly. But it’s far too early to know how that decision will ripple through distribution, freight, and final retail pricing. Anyone pretending they have clarity right now is guessing. It’s basically a mess.
And all of this unfolds against the backdrop of a bigger shift.
So while the Debut Reference 10 is the headline product, the more consequential story may be the business side. New flagship table. New U.S. distributor. Potential tariff recalibration. That is a lot of moving parts for one weekend and it suggests that the next chapter for Pro-Ject in the U.S. will look different than the last.
A new U.S. price list is expected shortly, and dealers are reportedly receiving updated pricing ahead of the March 1, 2026 transition. From what we understand, most existing Pro-Ject retailers should not see negative disruption as the new distribution structure takes effect. That said, whenever a brand shifts logistics, and billing systems, there is always the potential for short-term hiccups. It comes with the territory.
The current U.S. website, www.pro-jectusa.com, will be discontinued after March 1, 2026. Moving forward, product information will live on the global site at www.project-audio.com, aligning the U.S. more closely with the brand’s international presence.
Heinz Lichtenegger, CEO of Audio Tuning and the driving force behind Pro-Ject Audio Systems, has built the company over decades into one of the most dominant analog brands in Europe. With that kind of track record and with the U.S. market representing significant growth potential, there is little incentive to let this transition stumble. There is simply too much at stake, both commercially and reputationally.
Price & Availability
The finish is satin black, understated and safe. UK pricing is set at £999, with Australia confirmed at AU$2349. U.S. customers will have to wait a bit longer, and pricing is still to be announced.
For more information: project-audio.com
5 Comments
5 Comments
  1. Antonio
    February 23, 2026 at 5:05 pm
    I really like the look of this table but I wonder if Pro-Ject is going to be silly about the pricing.
    When you get over $2,000 — might as well buy a VPI, Clearaudio, or Rega.
    Why would Bose Luxury Group not continue their business relationship with Pro-Ject?
    • Ian White
      February 23, 2026 at 6:23 pm
      Anton,
      Not sure yet. They plan on updating all of their USD pricing for everything within a week so we’ll know then. It might be over $2,000 — just letting you know.
      I would buy this over a Planar 3 if you’re upgrading the cartridge. I’m not a fan of the Pro-Ject carts which are made by Ortofon. I would prefer a Sumiko on this table.
      I don’t think the McIntosh Group relationship with Pro-Ject extended beyond U.S. distribution. It was much tighter with Sumiko which had the rights to REL Acoustics at one point. I think Sonus faber/McIntosh appeal to a different buyer than someone looking for a $700 turntable and $500 phono stage. Pro-Ject does make more expensive products, but McIntosh has its own turntables made by others and someone dropping $50K on their amps and a preamp is not buying this table.
      I plan on reviewing it regardless of the price — and even if it’s over $2,000.
      IW
      • ORT
        August 8, 2026 at 11:52 pm
        “Silence! Foul Temptress!” Verily this ‘table doth speak to me across the void of several months…I am a literal Enthusiast and admirer of both Pro-Ject and its founder, Heinz Lichtenegger. He has always been a gentleman and a great help to me in my journey back into le bassin à effet miroir en vinyle.
        ORTson “I will eat no whale before its time Welles
        • Ian White
          August 8, 2026 at 11:57 pm
          ORT,
          They still make nice decks. Just had to fire some people on these shores who were not getting the job done.
          Do you know who makes even nicer stuff? Mrs. Lichtenegger. I have her latest $5K tube phono preamp. It does not suck. Review in a month.
          IW
          • ORT
            August 9, 2026 at 2:43 am
            Thx! I look forward to reading it!
            ORT
Sonus faber IsoAcoustics GAIA Titan Neo Loudspeakers Isolation Feet
A/V Furniture & Accessories
IsoAcoustics GAIA-TITAN Neo series of speaker isolation feet are designed for extra large speakers weighing 320 to 620 lbs each.
2026 Pro-Ject Audio Debut Carbon The Original Turntable Satin Black 2026 Pro-Ject Audio Debut Carbon The Original Turntable Satin Black
Pro-Ject revives the Debut Carbon for $649 with a carbon tonearm and Ortofon-made cartridge. Is it worth saving $50 over the EVO 2?
2026 Acoustic Energy 500 Series Loudspeakers 2026 Acoustic Energy 500 Series Loudspeakers
Acoustic Energy redesigns its 500 Series with Corinium drivers, new cabinets, and four models starting at £650. Is the upgrade worth it?
2026 Schiit Magni 6 Headphone Amplifier 2026 Schiit Magni 6 Headphone Amplifier
Splurge Audio Video Hi-Fi Tech Gifts 2026
148 years have elapsed since Edison's Phonograph was patented, and we decided to look back at some of the turntables that had the most...
Is the Pro-Ject Harley-Davidson Turntable serious hi-fi or expensive motorcycle merch? Its hardware suggests this isn't merely a branding exercise.
Is the Acoustic Signature Merlin NEO Germany’s Most Compelling New Turntable arriving in the U.S. for $4,999.
Technics x Aimé Leon Dore SL-1200M7ALD lands at $2100. Just hype or a smart play on vinyl’s billion dollar comeback?
Technics SL-1500CS upgrades the popular SL-1500C with Delta Sigma Drive motor control. Does this precision boost make it the new direct drive leader in...
