Pro-Ject Wants You To Touch Your Debut PRO S Turntable
The $1,200 Pro-Ject Debut PRO S Turntable offers a more hands-on approach to playback and cartridge swapping.
Pro-Ject Debut Pro S Turntable Subplatter
That felt somewhat odd just writing, but we actually understand where Pro-Ject is coming from in regard to the table. The new Pro-Ject Debut PRO S has been officially launched in Europe but N. American audiophiles will have to wait until October for the launch on this side of the pond.
We were more than just a little impressed with the Debut PRO, and our review makes it quite clear that this is the turntable to buy in 2022 if your budget is between $800 and $1,100 USD.
What we really love about the Debut Pro lineup is the scalability of the tables; you can easily change out the cartridge, add a better platter mat, or add an isolation platform from Pro-Ject or even IsoAcoustics.
Sumiko offers a number of higher-end cartridges like the Wellfleet that would certainly raise the performance of the Debut PRO and PRO S tables.
The Pro-Ject Debut PRO S tips the scales at 15 pounds and looks like a rather solid deck that comes equipped with a dustcover. The supplied head shell/cartridge is manufactured by Ortofon but we don’t know if N. American consumers will get the same setup at launch.
We offer that information because the Debut PRO comes with a pre-installed Sumiko Rainier in N. America and a totally different cartridge from Ortofon in Europe.
The Skinny
The manual controls invite the listener to interact with the turntable. The audible reward follows from the tactile experience. There are no unnecessary switches, LEDs nor labeling to distract from the essentials here.
A tad heavy on the philosophy but there are some technical differences between the turntables that require some explanation.
Pro-Ject Debut Pro S VTA Setting
The Debut PRO S utilizes Pro-Ject’s latest s-shaped 10″ aluminum tonearm design which is precision-machined and includes a CNC-milled bearing block for a new degree of resolution.
Another difference is that the tonearm allows for different head shells, which also makes it easier to experiment with different cartridges. There are a number of cartridges pre-mounted in head shells from Ortofon, and Nagaoka that would make a lot of sense in a $1,200 turntable.
Tack on azimuth & VTA adjustment and you have full control over over the setup parameters of your cartridge.
As usual, the deck is handmade in Europe using top-quality materials. The full satin black finish (including hand-painted parts) makes Debut PRO S a rather striking looking deck.
In-House CNC-Machined Aluminum Components
Take a closer look and you’ll find no hollow spaces nor plastic parts. Only high-quality aluminum parts are implemented to ensure optimal sound quality.
Pro-Ject Debut Pro S Turntable Sideview town
10″ Aluminum S-Shaped Tonearm
Pro-Ject’s latest s-shaped aluminum tonearm design ensures excellent damping and 10″ effective length enables perfect tracking of the record groove with minimal tracking error (including in the inner grooves). Compared to a straight tonearm, the s-shaped design requires more material and thus increases effective mass, accommodating cartridges that might be on the heavier side.
Pro-Ject Debut Pro S Turntable Backview
Adjustable VTA & Azimuth
Both azimuth and vertical tracking angle (VTA) are adjustable. Tonearm height can be easily changed by loosening the two grub screws at the rear of the armboard (then retightened!). For azimuth, there’s a single grub screw near the gimbal that allows for armtube rotation. Such versatility allows for endless experimentation with varying cartridges & records mats so that you can achieve the sonics that best suit you.
Built-In Speed Controller & Stabilizer
Platter speed is electronically controlled with the utmost precision ensuring speed accuracy & stability. Toggle between 33 & 45rpm with the flip of a switch. The supplied round belt for 78rpm records deepens the versatility of Debut PRO S.
Coupled with the diamond-cut aluminum sub-platter, platter speed is very accurate; The sub-platter also increases the mass of the drive system resulting in additional damping of noise and unwanted resonance.
Pro-Ject Debut Pro S Turntable ALU Subplatter
TPE-Damped Die-Cast Aluminum Record Platter
The die-cast aluminum platter is machined and balanced to perfection. Pro-Ject add a TPE-ring to the underside of the high-mass platter that increases damping and rotational mass, further improving speed stability.
Features
  • Pick it S2 C integrated cartridge/headshell
  • 10″ s-shaped aluminum tonearm
  • Precision aluminum platter with TPE damping
  • Fully adjustable VTA
  • Nickel-plated aluminum bearing block
  • Motor suspension with TPE damping
  • Height-adjustable TPE-damped metal feet
  • Precision belt-drive with electronic speed control
  • 8x coats hand-painted satin black MDF chassis
  • Premium semi-symmetrical phono cable
  • Gold-plated RCA connectors
  • Dustcover included
  • Handmade in Europe
Pro-Ject Debut Pro S Turntable Black
Specs
  • Speed: 33, 45/(78) (electronic speed change)
  • Drive principle: belt-drive w/ electronic speed control
  • Platter: 300mm, die-cast aluminum platter with TPE damping and felt mat
  • Platter bearing: high-precision stainless steel axle in bronze bushing
  • Wow & flutter: 33: +/-0.16%; 45: +/-0.14%
  • Speed drift: 33: +/-0.40%; 45: +/-0.50%
  • Signal to noise: 68dB
  • Tonearm: 10″ aluminum with SME-type headshell connection
  • Effective arm length/mass: 254mm/8g
  • Overhang: 16mm
  • Included accessories: 15V DC / 0.8A power supply, dustcover, 78rpm round belt, 7″ singles adapter
  • Power consumption: 4W (0W standby)
  • Dimensions (WxHxD): 462 x 145 x 345mm
  • Dimensions (standard): 18.19 x 5.71 x 13.58
  • Mass (weight): 8kg (15.43 lbs) net
For more information: Pro-Ject Debut Pro S Turntable
3 Comments
3 Comments
  1. ORT
    October 3, 2022 at 4:01 pm
    I don’t really get Pro-Ject doing this. I am not a fan of those weird looking cartridge setups. I’ve got one on my 50th Anniversary Sgt. Peppers Essential III. It looks stoopid but since I do not change things that I am worried I will screw up, I just do my best not to look at that hideous cartridge/needle.
    It is F U G L Y.
    If I had known how much it would piss me off, I would NOT have bouoght this ‘table. This is pretty much why I still have not bought the George Harrison ‘table by Pro-Ject. UGH. That cartridge is cheap and fugly looking. I do NOT think I should have to upgrade it right off the bat and to be honest, I may never change it on my Sgt Pepper ‘table.
    Why does Pro-Ject do this? A beautiful table made fugly by that cheapass cartrdige thingy. 😉 They did this to further upset me and along with that hideous platter, it is a sure bet I will NEVER buy one.
    ORT
    • Ian White
      October 3, 2022 at 4:09 pm
      ORT,
      It’s geared towards the “DJ” millennials who want to touch and feel everything.
      Not my personal cup of tea but it’s big in Europe.
      IW
      • ORT
        October 3, 2022 at 6:13 pm
        Ewwwwwwwwwwww…That explains it, thanks!
        Next up…Tomorrow! Tomorrow! It soon will be tomorrow and it’s FOCAL!
        ORT
QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Topping E50 II DAC on Desktop Topping E50 II DAC on Desktop
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
AZLA TRINITY Earphones USB-C Version AZLA TRINITY Earphones USB-C Version
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
WiiM Sound Lite Smart Speaker in white WiiM Sound Lite Smart Speaker in white
WiiM's original smart speaker sheds features to hit a lower price point ($229) for those who can live without a touch display and voice...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Thorens taps Chicago’s MoFi Distribution for a real North American comeback, finally giving its Swiss classics the Windy City muscle they’ve been missing.
Andover Audio’s new $729 SpinPlay all-in-one record player combines true hi-fi sound, IsoGroove tech, and Bluetooth connectivity—outclassing Crosley-style decks.
Technics ends the SL-1200/1210G run with two Grand Class Master Edition turntables in black or silver with even better performance and fancy gold accents.
Michell Audio launches Revolv and Gyro turntables, modernizing classic designs with premium materials, upgraded chassis, and high-end performance. You'll still need a tonearm.
Pro-Ject’s Elvis Turntable lights up your vinyl like the King’s stage — all hips, LEDs, and no chance of leaving the building unnoticed.
Kanto Audio’s Obi3 Turntable offers vinyl and Bluetooth playback with an Audio-Technica cartridge and switchable preamp for just $199, challenging pricier entry-level competitors.
A new turntable, phono stage, cartridge or speaker could be the upgrade you've been looking for or the perfect gift for any vinyl lover.
The Lenco LBT-515 is a direct-drive turntable with Ortofon 2M Blue, adjustable tonearm, built-in preamp, and Bluetooth 5.3 for wired or wireless playback.
