Preview: Pro-Ject Debut EVO 2 Turntable
At $699, the Pro-Ject Debut EVO 2 turntable features a balanced output option, new aluminum platter and Pick It MM EVO cartridge.
Pro-Ject Audio Systems Debut Evo 2 Turntable (2024 model) colors
Pro-Ject Audio Systems has announced the latest edition to the Debut Series, Debut EVO 2. Advancing the design of its predecessor (Debut Carbon Evo), Debut EVO 2 now uses the same tonearm bearing block from the Debut PRO B; but the biggest change is the switch from a steel platter to the aluminum platter utilized in the aforementioned Debut PRO B deck that was just introduced.
The incorporation of the Pick it MM EVO phono cartridge, improved motor isolation and a new satin red wine finish sets the Debut EVO 2 makes the new deck a rather interesting option below $700 USD.
Pro-Ject Audio Systems Debut Evo 2 Turntable with Pick it MM EVO phono cartridge
Pro-Ject Audio Systems Debut Evo 2 Turntable with Pick it MM EVO phono cartridge (satin wine red finish)
Before you get too excited about the balanced output “capabilities” there is some additional information that you need to know.
The new model is balanced-capable with the following requirements: a moving coil cartridge (or Pro-Ject’s Pick it PRO Balanced MM), an RCA > mini XLR cable, as well as any Pro-Ject phono preamp with a mini XLR input (Phono Box S3 B, Phono Box DS3 B, Tube Box DS3 B).
I evaluated the merits of the balanced output option in my recent review of the Pro-Ject X2 B Turntable which you can read here.
The Debut EVO 2 still features customers’ favorite elements from the Debut Carbon EVO. An 8.6” carbon-on-aluminum arm tube, low-friction precision tonearm bearings, a sophisticated DC/AC power generator and height-adjustable metal feet.
Pro-Ject Audio Systems Debut Evo 2 Turntable Side
Pro-Ject Audio Systems Debut Evo 2 Tonearm Gimble
Tonearm Gimble
Initial Impressions
Pro-Ject has been rather active in 2024 adding 3 new models which support balanced operation and whilst we agree with them that the benefits in terms of sonic performance can be significant — that upgrade requires additional expenditures that may not be within the budget of those shopping for a $700 turntable.
Is it a path worth taking? We think listeners should see how much they love the sound with the new Pick It MM EVO cartridge first within the context of their existing system before taking the plunge.
Pro-Ject’s aforementioned phono pre-amplifiers that offer balanced inputs/outputs are very solid performers at their respective price points but users should remember that the integrated amplifier or line stage on the other end must offer balanced inputs as well to make this a wise upgrade path.
Pro-Ject Audio Systems Debut Evo 2 Turntable Back and Bottom in Satin Red Wine Finish
Back and bottom view of Pro-Ject Audio Systems Debut Evo 2 Turntable in Satin Red Wine Finish
Comparison
Carbon Debut EVODebut EVO 2
MSRP$599$699
Speeds33, 45, 78 rpm33, 45 rpm
Drive principlebelt drive with electronic speed controlbelt drive w/ electronic speed control
Platter1.7 kg (3.75 lbs) 300 mm steel platter with TPE damping & felt mat1.7 kg (3.75 lbs) 300 mm die-cast aluminum platter with TPE damping & felt mat
Platter bearingStainless steel axle in bronze bushingStainless steel axle in bronze bushing
Wow & flutter (33 rpm)±0.17% ±0.16%
Wow & flutter (45 rpm)±0.15%±-0.14%
CartridgePre-adjusted Ortofon 2M Red cartridge or Sumiko RainierPre-adjusted Pick it MM EVO cartridge
Speed drift (33 rpm): ±0.5%±0.40%
Speed drift (45 rpm): ±0.6%±0.50%
Signal to noise: 68 dB68 dB
Tonearm8.6” one-piece carbon tonearm8.6” one-piece carbon tonearm
Effective arm length / mass218.5 mm / 6.0 g218.5 mm / 10.0 g
Overhang18.5 mm18.5 mm
Included accessories15V DC 0.8A power supply,
dust cover,
7‘‘ singles adapter,
78 rpm round belt
dust cover,
7‘‘ singles adapter
Dimensions (WxHxD)415 x 113 x 320 mm
(16.34 x 4.45 x 12.60″)
415 x 113 x 320 mm
Weight6 kg (13.23 lbs) net6 kg (13.23 lbs) net
Pro-Ject Audio Systems Debut Evo 2 Turntable Front in Satin Red Wine Finish
Price & Availability
The Pro-Ject Debut EVO 2 Turnable is expected to start shipping October 8, 2024 for $699 at Crutchfield in select colors (high gloss white, red or satin steel blue). A total of 10 different finishes will be offered including satin walnut, but some colors won’t be available until December 11, 2024.
For more information: pro-jectusa.com
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
Pro-Ject's Artist Series of turntables has expanded with a new offering paying homage to the legendary band from down under. The price might leave...
The Best Audiophile CD Players of 2024 include Hegel, Luxman, Marantz, Rotel and more for the ultimate in compact disc playback.
Looking for your first high-end audiophile turntable but don't want to spend more than $3,500 for something that will be your deck for many...
Our favorite audiophile turntables in 2023 include Pro-Ject, Rega, Technics, Orbit and more.
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
From $6,000, the Pro-Ject Classic Reference turntable combines a vintage look with high-end construction and performance for audiophiles.
