Pro-Ject’s Colorful Audio Hi-Fi Set Is Ideal For Your Office or Bedroom
The Pro-Ject Colorful Audio Hi-Fi System includes a turntable, cartridge, integrated amplifier and speakers for under $2,000.
Pro-Ject Colorful Audio System Yellow Angle
With companies such as Victrola, Andover Audio, and +Audio having success marketing integrated turntable systems, Pro-Ject Audio Systems must have taken notice as they have decided to jump into the game with the introduction of its Colorful HiFi Set
However, instead of designing a system from the ground up, Pro-Ject has assembled key components from its existing product line that offer great performance for the money.
The Pro-Ject Audio Systems Colorful Audio HiFi Set Includes the following components.
Debut Carbon EVO Turntable
Pro-ject Debut Carbon Evo Turntable
Pro-Ject Debut Carbon Evo Turntable in Satin Walnut
Turntable Features
  • Drive Type: Belt
  • Speeds: 33, 45/(78): Electronic speed change.
  • Included Accessories: 15V DC / 0,8A power supply, dust cover, 78 RPM round belt, 7-inch single adapter
  • Power consumption: 4W / 0W standby
  • Dimensions Dustcover Closed (WHD): 16.34 x 4.45 x 12.6-inches (415 x 113 x 320mm)
  • Dimensions Dustcover open (WHD): 16.34 x14.37 x 15.9-inches (415 x 365 x 405mm)
  • Weight: 13lbs 4oz (6kg)
$599 at Amazon | Product Page | Best Affordable Audiophile Turntables
Tip: In Europe the Carbon EVO comes with an Ortofon 2M Red Cartridge, but in the U.S. (and in this package) a Sumiko Rainer Cartridge is provided.
Sumiko Rainier Phono Cartridge
Sumiko Rainier
Cartridge Features
  • Stylus: 0.3 x 0.7mil Elliptical
  • Cantilever: Aluminium Pipe
  • Coils: High-Purity Copper
  • Load Impedance: 47kΩ
  • Frequency Response: 15Hz to 25 kHz
  • Channel Separation: 25dB @ 1kHz
  • Vertical Tracking Angle: 25°
  • Tracking Force Range: 1.8g – 2.2g
  • Replacement Stylus Options: RS Rainier, RS Olympia, or RS Moonstone (Interchangeable)
$149 at Amazon
Speaker Box 5 S2
Pro-Ject Speaker Box 5 S2 Bookshelf Speakers
Speaker Features
  • Tweeter: 1-inch (25mm) silk dome with Neodynium magnet
  • Woofer: 5-inch (130 mm) fiberglass cone
  • Recommended amplifier power: 10 to 150 Watts
  • Frequency response: 55 Hz – 20 kHz
  • Nominal impedance: 8 Ohms
  • Sensitivity (1W/1m): 88 dB
  • Dimensions (WHD): 6.3 x 10.7 x 8.5-inches (160 x 271 x 215 mm)
  • Weight: 10lbs 13oz (4.9 kg)
More Details
MaiA S3 Integrated Amp with Bluetooth
The MaiA S3 provides system amplification as well as the needed connections for the turntable and the speakers. In addition, it also provides connections for additional sources as well as wireless Bluetooth reception for compatible devices such as smartphones.
Pro-Ject MaiA S3 Integrated Amplifier Front
Amplifier Features
  • Power Output: 2x 23W / 40W at 8 / 4ohms (1% THD)
  • Frequency Response: (20Hz – 20kHz):<-0,5dB @4ohm
  • Channel Separation: – 69dB at 10kHz
  • S/N  Ratio: 97dB (101dB-‚A‘ weighted) @4ohm
  • THD: < 0,04% at 10W / 4 ohms
  • Headphone Amplifier: 2x 75mW at 32ohm (1%THD)
  • Headphone Output: ¼-inch (6.3mm) jack (16 – 600 ohms impedance)
Pro-Ject MaiA S3 Integrated Amplifier Rear
  • Analogue Inputs: 3x pair RCA, 1x phono MM (RCA)
  • Digital Inputs: 1 x Digital Coaxial, 2 x Digital Optical (Toslink)
  • Wireless Input:  Bluetooth 5.0 with aptX HD
  • D/A-converter: Cirrus Logic CS4344 24bit/192kHz
  • Variable Output: 1x pair RCA
  • Speaker connectors: 4mm banana plugs, spades connectors, or naked wire
  • Control: Wireless Remote provided, Onboard controls for power, volume, and source selection.
  • Dimensions (WHD): 8.1 x 2.17 x 6.9 -inches (206 x 55 x 176mm)
  • Weight: 2lbs 6 oz (1070 g) without external power supply
More Details
Connect It LS S2 Speaker Cables
Pro-Ject Connect Speaker Cables
  • Length: 3 meters
  • Assembly: Solid-Core twisted
  • Conductor: High-purity oxygen-free copper
  • Gauge: 4 x 0.96 mm²
  • Dielectric: Polyethylene
More Details
Damp It Speaker Isolation Pods (x8)
Pro-Ject Damp-it
  • Special absorber feet for effective decoupling
  • Prevents transmission of mechanical vibration
  • Optimized to absorb frequencies from 20-500 Hz
  • Made from high-tech TPE (thermoplastic elastomers)
  • Especially made for bookshelf speakers, disc players, turntables, tube amplifiers, and more…
More Details
Colors!
Pro-Ject Colorful Audio System Blue
In addition to the high-performance audiophile components you would expect from Pro-Ject, the HiFi system is offered in six color finishes that can complement just about home decor:
  • Walnut
  • White
  • Black
  • Steel Blue
  • Golden Yellow
  • Fir Green
Availability and Pricing
All of the components of the Colorful HiFi Set are made in the EU and are available in select markets via Authorized Pro-Ject Brick and Mortar and Online Dealers for $2,000.00.
For more information: USA Product Page
Pro-Ject Colorful Audio System Black
Pro-Ject Colorful Audio System White
Pro-Ject Wants You To Touch Your Debut PRO S Turntable
Pro-Ject Unveils Power Box RS2 Phono For Turntables & Phono Preamplifiers
Pro-Ject Introduces X1 B And X2 B Balanced Turntables
Pro-Ject Debut PRO Turntable: Review
Pro-Ject Premieres New E1 Turntables For 2022
Skullcandy Method 360 ANC Wireless Earbuds inside case in-hand in bone (white)
Earbuds & In-Ear Headphones
In-Wall Speakers
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
DAPs
With support for 32-bit PCM, DSD, Roon, LDAC, aptX HD, and a brand new docking cradle, the Astell&Kern PS10 DAP might replace your streamer.
Loudspeakers
KLH Audio and Victrola now exist under the same umbrella keeping two legacy American Hi-Fi brands alive.
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
Pro-Ject's Artist Series of turntables has expanded with a new offering paying homage to the legendary band from down under. The price might leave...
Incorporating the Apple H2 chip, Bluetooth, spatial audio, wireless charging and more, the Beats Powerbeats Pro 2 wireless earbuds offer a lot for just...
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
