Pro-Ject’s Classic Reference Turntable Goes Back to the Future: Preview
From $6,000, the Pro-Ject Classic Reference turntable combines a vintage look with high-end construction and performance for audiophiles.
Pro-Ject Classic Reference Turntable Front View Angle
If the recently released Pro-Ject Signature 12.2 Flagship caused heart palpitations after you read through the technical explanation and saw the price — the new Pro-Ject Classic Reference will not require a defibrillator. You might even be safe with some kishka and gravy.
2024 has been a busy year for turntable maker Pro-Ject Audio Systems. Since August, they have released the XA B Transparent Acrylic, the Debut PRO B, Debut EVO 2, T1 EVO, T1 EVO Phono and T1 EVO BT.
Pro-Ject claims that the Classic Reference combines technical excellence and luxury like no other turntable and is built on the foundation of the VPO 175 and Classic EVO turntables.
Pro-Ject Classic Reference Turntable Lifestyle
The Classic Reference includes the EVO 9 AS HG tonearm. High-precision ABEC 7 bearings are housed in an aluminum gimbal for frictionless, resonance-free operation.
The internally-damped S-shaped aluminum arm tube accommodates a removable headshell so that cartridges can be swapped as desired. In addition, flexible high-purity copper tonearm wire is used. Each lead is fitted with a gold-plated connector clip.
The Classic Reference is available with the limited edition VPO 175th Anniversary MC cartridge which was fine tuned together with members of the Vienna Philharmonics and built in Europe by Ortofon according to Pro-Ject’s specifications.
The high-mass aluminum alloy record platter is damped with TPE (Thermoplastic Elastomer), which eliminates unwanted resonance. The Clamp it record clamp and Leather it record mat are included in-purchase for additional resonance control.
The platter rotates on a precision machined & balanced aluminum sub-platter. This provides better rotational stability and also adds mass to the drive system.
The tonearm is mounted to an aluminum alloy top plate supported by TPE pods sandwiched between it and the MDF plinth.
The record platter rotates on an aluminum sub-platter which is belt-driven by the AC motor.
The Classic Reference includes full-sized Balanced XLR outputs in addition to RCA unbalanced outputs with ground. This means you have the option of connecting The Classic Reference to any phono stage with corresponding inputs.
Pro-Ject Classic Reference Turntable Connections
Although The Classic Reference comes with a power supply, there is also another power supply option you can take advantage of. Pro-Ject’s Power Box RS2 Phono can provide linear power to The Classic Reference (15V) as well as a Pro-Ject phono stage (18-20V).
Its two outputs are specifically engineered to power Pro-Ject turntables and phono preamps simultaneously. The linear power supply contributes to improved overall sound quality.
In addition to the sonic improvements, Power Box RS2 Phono also offers users a cleaner cable solution (only one wall wart is needed for the PSU).
Comparison
Pro-Ject Classic Reference (Left) Signature 12.2 (Right) Turntables
Classic Reference Signature 12.2 Flagship
Price $5,999 (Silver with Gloss Black Plinth)
$6,999 (Brass with Acacia Plinth)
$14,999
Speed Options33, 45 (78) rpm (electronic speed change)33 & 45rpm (electronic speed change)
Drive MechanismBelt driveBelt drive with Flywheel
Platter300mm aluminum with TPE damping ring10.55kg (magnetically decoupled)
Motor Control SystemNot IndicatedPrecision Generator
Mains BearingStainless steelCeramic (ball/plate) Cl
Wow & Flutter0.03% (33rpm),
±0.04% (45rpm)
±0.01% (33rpm),
±0.01% (45rpm)
Speed Variance±0.08% (33rpm),
±0.10% (45rpm)
±0.09% (33rpm),
±0.08% (45rpm)
Signal-to-noise ratio (SNR)73dB75dB
TonearmEVO 9 AS HG Built for Signature 12.2
Effective Arm Length230mm (9 inches)304.8mm (12 inches)
Effective Arm Mass24.2g21.7g
Overhang18mm (0.71 inches)13.2mm (0.52 inches)
Power Consumption5W15W/0.5W standby
Power Input15V/ 0.8 A DC, universal power supply15V/ 1.6 A DC, universal power supply
Dimensions (WHD – closed cover)462 x 138 x 335mm
18.19 x 5.43 x 13.19 inches
580 x 220 x 480mm
22.83 x 8.7 x 18.9 inches
WeightN/A37 kg / 81 lbs 10 oz
Included AccessoriesSingle Adapter
Allen Key 1.5 mm (Azimuth Setting)
Allen Key 2 mm(Cartridge Installation)
Allen Key 3mm (Shortened, VTA Setting)
Drive Belt for 78 RPM Record Playback
Counterweight No. 27 (33), Evolution (For Cartridge Wight 6.5 – 11 grams)
Counterweight  Mo. 26 (32), Evolution Line (For Cartridge Weight 9 – 16g)
Two-Point Cartridge Alignment Protractor
Connection Cable (Connect IT E RCA)
Instructions
White Cotton Gloves
Cotton Cloth
Connection Cable (Connect IT E RCA) Universal Power Supply
Single Adapter
Allen Key 2 mm (Cartridge Setting, VTA Locking Screw)
Allen Key 3mm
Counterweight
Counterweight Insert 30mm
Counterweight Insert 45mm
Cartridge Alignment Tool (Pro-Ject Align IT)
White Cotton Gloves
Cotton Cloth
Connection Cable (5 Pin DIN to RCA)
Record Puck Universal Power Supply
Cartridge Not IncludedNot Included
Pro-Ject Classic Reference Turntable Angle Black
The Bottom Line
17 years into the vinyl revolution, music listeners have a plethora of high-end turntable options that range from the state-of-the-art $128,000 Nagra Reference, Kuzma Stabi R, Rega Naia, Technics SL-1300G, and more affordable Pro-Ject Debut Pro B, and U-Turn Audio Theory — with another 200 models from other brands that we could mention.
So where does that place the Pro-Ject Classic Reference in the overall mix?
Spending anywhere between $6,000 and $7,000 for a turntable that does not even come with a cartridge is a rather sizeable investment and there are a number of tables from VPI, Clearaudio, Rega, Thorens, Kuzma, AVID, MoFi, and Technics that have be considered viable alternatives.
Pro-Ject are not the only high-end turntable manufacturer who design and make their own components internally — but they might be the only one who can produce a table of this level of quality whilst selling another 100,000+ tables, and thousands of components, and OEM products for another 5 or 6 major manufacturers at the same time.
They can make almost anything in-house and keep the prices below that of their competition.
The build quality of their tables seems to have taken another step forward in 2024 and there is a classical elegance to this deck that really stands out in a rather crowded marketplace.
If its performance matches the rather striking industrial design, this might be one to consider if your budget stretches that far — just leave room for a high-end cartridge that can show off its capabilities.
Price & Availability
The Classic Reference is handmade in Europe and is available for special order only. Select between silver with a gloss black plinth ($5,999) or brass with an Acacia plinth ($6,999).
For more information: pro-jectusa.com
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
