In-Wall Speakers
Pro Audio Technology’s SR-2408iw Architectural Speakers Offer Full-Range Flexibility: CEDIA 2023
The SR-2408iw is a compact, high-output, and aimable loudspeaker that offers full-range performance ideal for high-end home theater and mega-yacht installations.
Pro Audio Technology SR-2408iw In-wall or on-wall loudspeaker
Pro Audio Technology, a leading supplier of high-output loudspeakerssubwoofers, and DSP loudspeaker controllers, announces the SR-2408iw thin-profile high-output loudspeaker for in-wall and in-ceiling installations where space is limited but performance is crucial.
This speaker works for in-wall installations that need high output and versatility suitable for retrofit or new construction. With its slim 4-inch deep and all-aluminum construction, it is used in high-end home theaters, commercial venues, and even yachts.
The SR-2408iw can be used as a main, side, rear, surround, or as height channel speakers for Dolby Atmos and other immersive audio setups.
Pro Audio Technology SR-2408iw In-wall Speaker Pair
Tip: The angled waveguide is great for residential rooms or yachts where space is limited and aiming speakers is particularly challenging.
Featuring a 1.5-inch ring radiator tweeter, two high efficiency 4-inch midrange drivers, and an 8-inch long-throw woofer, the SR-2408iw is a very high-output yet versatile loudspeaker suitable for in-wall and in-ceiling installations where space is limited but performance is crucial.
The SR-2408iw can be configured with 0-degree straight-firing axi-symmetric, or 40-degree asymmetric waveguides which aim the sound at a 40-degree angle to the loudspeaker main axis.
This allows the sound to be “aimed” at the reference listening position while the speaker is mounted flush in a 2 x 4 architectural wall. The angled waveguide is ideal for residential rooms or yachts where space is limited and aiming speakers is particularly challenging. In more spacious installations, it can also be adapted using PRO’s pivot bracket allowing the installer to mount it to a surface and aim it at a specific listening position.
Despite its 4-inch depth, the SR-2408iw is capable of reproducing 45Hz – 22kHz, allowing the SR-2408iw to serve as full-range speakers in surround and distributed audio applications. An optional, paintable perforated metal grille is available.
“The SR-2408iw in-wall loudspeaker was initially developed to be installed on a world-renowned VIP’s mega-yacht. However, it benefits a much broader audience in that it meets the speaker aiming requirement in Dolby-certified DCI theaters,” said Paul Hales, Pro Audio Technology CEO. “The all-aluminum construction makes it suitable for any environment – including marine – and allows us to achieve surprising fidelity and output from a speaker only 3.5-inch deep.”
Specifications:
  • APPLICATION: Compact high-output aimable in-wall loudspeaker with frameless perforated grille
  • LF SECTION: 1 x 8″ professional grade subwoofer with 4″ voice coil
  • MF SECTION: 2 x 4” midrange drivers with 2.5 inch voice coils
  • HF SECTION: 1.5″ professional-grade compression driver on PRO Theorem wide dispersion Axi- symmetric waveguide
  • CROSSOVER: Tri-amplified
  • POWER HANDLING: 500W LF / 400W MF / 120W HF
  • SENSITIVITY: 92dB LF / 99dB MF / 108dB HF / 110 HF 40-degree
  • POWER REQUIREMENTS: Single and bi-amplification via PRO Amplified Loudspeaker Controller
  • WIRING REQUIREMENTS: 6 conductors
  • FREQUENCY RANGE: 45Hz – 22kHz, – 6dB
  • MAXIMUM OUTPUT: 119dB
  • NOMINAL IMPEDANCE: 8-ohms LF / 4-ohms MF / 8-ohms HF
  • DIMENSIONS: 26.375″ H x 10.25″ W x 3.8” D
  • WEIGHT: 18 lbs.
The SR-2408iw is available now and is on display and demo at CEDIA Expo and Commercial Integrator Expo 2023 in the Pro Audio Technology booth (1543).
For more information: proaudiotechnology.com
Continue reading more stories from CEDIA Expo 2023.
HumminGuru EZ Record Washer Package
HumminGuru’s EZ Vinyl Record Washer targets Spin-Clean with a more refined manual cleaner—effective, easy to use, and price will determine its appeal.
Hisense PX4-PRO UST Projector Hisense PX4-PRO UST Projector
Hisense previews the PX4-PRO UST projector ahead of CES 2026, promising 200-inch images, higher brightness and contrast, built-in Atmos audio, and a flexible alternative...
Hisense XR10 High-end Lifestyle 4K Laser Projector Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Pro Audio Technology SR28212ai Speakers V2 Pro Audio Technology SR28212ai Speakers V2
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
Displace Pro TV 2 OLED on stand Displace Pro TV 2 OLED on stand
Need to mount a TV to the wall without drilling, screws or wires? Displace TV offers two ways to do it, with an added...
LG Sound Suite Soundbar System Lifestyle LG Sound Suite Soundbar System Lifestyle
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
In-Wall Speakers
KEF expands its Extreme Home Theater line with the THX-Certified Ci5120QLM-THX and Ci3120QLM-THX in-wall speakers, priced at $1,699.99 and $1,299.99 each.
Denon's latest A/V Receiver offers 11.4 channels of amplification and 13.4 channels of audio processing as an AV preamp. Coming early 2024.
In-Wall Speakers
Theory Audio Design shows that you can put together a fine-sounding home theater system - or whole home music system - for a whole...
At Audio Advice Live 2025, hear Focal's $150K+ home theater, $69K wireless speakers and its full line of headphones. Prepare to drool.
In-Wall Speakers
The Focal Utopia CINEMA LCR and Subwoofer are designed for luxury home theater set-ups in large spaces.
Our favorite in-ceiling and in-wall speakers and subwoofers for distributed audio and home theater will be heard, but not seen.
Ask an Expert
A professional installer reveals everything you need to know about installing in-ceiling speakers for Dolby Atmos height effects or music.
