In-Wall Speakers
Pro Audio Technology’s SR-2408iw Loudspeakers Deliver Big Sound in Tight Quarters – CEDIA 2022
The Pro Audio Technology SR-2408iw In-Wall/In-Ceiling Speaker is designed to deliver high performance in tight spots.
Pro Audio Technology SR-2408iw In-Wall Speakers
Pro Audio Technology, a leading supplier of high-output loudspeakers, subwoofers, and DSP loudspeaker controllers, announces the SR-2408iw thin-profile high-output loudspeaker for in-wall and in-ceiling installations where space is limited but performance is crucial.
This speaker works for in-wall installations that need high output and versatility suitable for retrofit or new construction. With its slim 4-inch deep and all-aluminum construction, it is used in high-end home theaters, commercial venues, and even yachts.
The SR-2408iw can be used as a main, side, rear, surround, or as height channel speakers for Dolby Atmos and other immersive audio setups.
The SR2408iw features a 1.5-inch ring radiator tweeter, two high-efficiency 4-inch midrange drivers, and an 8-inch long-throw woofer.
The SR-2408iw can be configured with 0-degree straight-firing axisymmetric, or 40-degree asymmetric waveguides which aim the sound at a 40-degree angle to the loudspeaker main axis.
This allows the sound to be “aimed” at the reference listening position while the speaker is mounted flush in a 2 x 4 wall.
Tip: The angled waveguide is great for residential rooms or yachts where space is limited and aiming speakers is particularly challenging.
In more spacious installations, the SR-2408iw can also be adapted using PRO’s pivot bracket allowing the installer to mount it to a surface and aim it at a specific listening position.
Despite its slim 4-inch depth, the SR-2408iw has a frequency response of 45Hz to 22kHz
An optional, paintable perforated metal grille is available.
From Paul Hales, Pro Audio Technology President, and Product Designer: “The SR-2408iw in-wall loudspeaker was developed to meet the speaker aiming requirement in Dolby-certified DCI theater that is to be installed on a world-renowned VIP’s mega-yacht…The all-aluminum construction makes it suitable for the harsh yacht environment and allows us to achieve surprising fidelity and output from a speaker only 3.5-inch deep.”
SR-2408iw Specifications
  • Speaker Design: Tri-amplified, In-wall, Sealed Cabinet
  • Tweeter: 1 x 1.5-inch ring radiator
  • Midrange: 2 x 4-inches
  • Woofer: 8-inch long throw woofer
  • Impedance: 8ohms LF/ 4ohms MF / 8ohms HF
  • Frequency Response: 45Hz to 22kHz
  • Sensitivity: 92dB LF / 98dB MF / 108dB HF / 110 HF 40-degree
  • Crossover: Tri-amplification (refer back to speaker design)
  • Max Peak SPL: 119dB
  • Power Handling: 500W LF / 400W MF / 120W HF
  • Amplifier Power Range:  250W – 1000W LF / 125W – 500W MF / 125W HF
  • Terminals: Euroblock
  • Cabinet Depth: 4-inches
  • Cutout (W x H): 10.25 x 26.375-inches
  • Grille Dimensions (WHD): 11.6 x 27.6 x 0.18-inches
  • Weight: 18lbs
  • Grill Color: White (paintable)
Availability and Pricing
Pro Audio Technology is making the SR-2408iw available to the general public via authorized US and international distributors.
For more details, including exact pricing, contact Pro Audio’s VP of sales Mark Goldman at: mgoldman@proaudiotechnology.com
Pro Audio Technology Launches The Intelligent SR-28212ai Loudspeaker
Pro Audio Technology Introduces New MA Modular Amplifiers
Theory Audio Design Unveils Next Generation Amplified Loudspeaker Controllers: CEDIA 2022
Theory Audio Design’s Iws12-6 & Iws12-9 In-Wall Subwoofers Are Going To Shake Your Foundation: CEDIA 2022
Theory Audio Design: 6 Questions For Paul Hales
Discover More New Products from CEDIA 2022
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
At only $1,995, Strato M is Kaleidescape's lowest cost movie server/player, but there is a catch.
Sony just unveiled two new entry-level Dolby Atmos-compatible soundbars for those who want to beef up their TV sound without breaking the bank.
These Quadraphonic albums have been digitized from analog four-track Quad mixes and are now available on Blu-ray discs.
Close To Perfect, Expanded Atmos Mix Takes Yes Surround Sound To Immersive Heights.
HDTV 4K & 8K TV
Philips has teamed up with Roku to deliver a budget priced 65-inch OLED TV (model 65OLED974/F7) that's only $1,299 at Sam's Club.
The Arendal Sound 1961 loudspeaker line is not ready to be retired. Check out all 6 speakers and 2 subwoofers priced under $2000/pair.
