Pro Audio Technology LFC-10sm Subwoofer
Pro Audio Technology LFC-10sm subwoofer
Offers visceral bass performance in a compact enclosure for space-conscience home theater installations
Pro Audio Technology (PRO) recently released the LFC-10sm subwoofer, a compact, high-output low-frequency speaker ideal for size-constrained home theater installations or larger systems featuring multi-subwoofer configurations.
The LFC-10sm subwoofer enclosure measures only 14 x 26 x 12 inches, which allows it to be easily located within cabinetry, or even placed discretely in-room. Surprisingly, PRO claims maximum output levels greater than 110dB.
Pro Audio Technology LFC-10sm subwoofer driver
PRO equipped the LFC-10sm with a sophisticated 10-inch woofer featuring a highly rigid glass-fiber reinforced diaphragm driven by a massive magnet, and an over-sized surround for extra-long linear excursion. The subwoofer’s over-sized, front-firing free-flow port also enhances the LFC-10sm’s low-frequency extension and output, while giving integrators much more freedom in terms of cabinet or room placement.
Additional installation flexibility is provided by PRO’s PMA digital processor / amplifier, which delivers either 450 or 1000 watts of power depending on the installation needs, and provides a fully DSP optimized signal to the sub. The PMA power source also allows for in-room performance calibration via a powerful suite of controls, including parametric EQ and delay.
“Owing to its exceptional components and meticulous engineering, the LFC-10sm delivers output levels and muscular yet musical bass that belies its modest size,” said Paul Hales, Pro Audio Technology founder. “It provides all of the visceral slam that customers and integrators expect from PRO subwoofers in a housing that can easily be integrated into virtually any room.”
Price and Availability
The Pro Audio Technology LFC-10sm subwoofer is available now.
Specifications
  • Application: Compact format subwoofer
  • LF Section: 10” ultra-long throw woofer
  • Crossover: 8th order acoustic via DSP
  • Power Handling: 1000W
  • Sensitivity: 90dB
  • Power Requirements: Requires amplification via PRO power amplifier
  • Frequency Range: 22Hz – 80Hz
  • Maximum Output: >110dB
  • Nominal Impedance: 4-ohms
  • Dimensions: 26” H x 14” W x 12”D
  • Weight: 57 lbs.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
At $43,600, Grimani Systems' Psi v3 is four subwoofer system that goes in each corner of a home theater for generating up to 115...
Daily Deals
Our favorite subwoofers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Customers in Australia can now purchase direct from RSL Speakers and get free shipping, faster delivery and a 30-day in-home trial.
At $35,000, the new McIntosh PS1K subwoofer combines 1,000-watts of Class D power with dual 13-inch drivers.
At $699, the Acoustic Energy AE Sub is 12-inch subwoofer packing 250-watts of power with low bass extension down to 26Hz.
The Audioengine S6 Compact Subwoofer is their smallest, but a perfect match for your desktop home office audio system.
Those who want to fill a large living room or home theater with deep gut-wrenching bass will rejoice at the news of a new...
The REL Classic 99 subwoofer carries on the vintage design of the previously released Classic 98 but with a larger 12-inch driver and increased...
