Pro Audio Technology Celebrates Its 20th Anniversary With 5 New Models: CEDIA 2024
Priced from $4,800 to $9,000 each, PRO Audio Technology’s versatile new line of loudspeakers can handle near sound reinforcement levels while sounding like true high fidelity.
Pro Audio Technology Celebrates 20 Years
Pro Audio Technology (PRO), founded in by Paul Hales, is a leading supplier of high-output loudspeakers and DSP loudspeaker controllers for elite private screening rooms. For 2024 it is celebrating its 20th anniversary by bringing a new line of loudspeakers to the CEDIA Expo being held in Denver, Colorado from September 5-7 2024.
What’s New
The five new multi-purpose loudspeakers are designed to fill a void at the premium end of the market for high output, yet compact and flexible audio solutions for installed and portable commercial and residential installations, DVLED (more commonly referred to as video wall) installations.
The speakers are designed to have lively dynamics, a high maximum output level, and refined acoustic performance. For the past 20 years, PRO has focused on designing and manufacturing a complete range of loudspeakers and DSP-amplified loudspeaker controllers that address the needs of high-end residential installations, bringing cinematic sound into the home – most commonly into upscale private screening rooms.
The new PRO loudspeakers were designed from top to bottom including ergonomic handles, multiple fly points, industry-standard mount points, and pole cups. Optional PRO SplitYoke Multipurpose Mounting Brackets can be used to install all PRO Commercial loudspeakers easily on the wall, ceiling, floor, and other surfaces. And the PRO SplitYoke Bracket Kits works with all five models – no need for additional accessories.
Add the PRO Caster Kit designed for the CF-212.3 full-range speaker, or CLF-212 subwoofer and the models become portable in an instant. Once the wheels are installed, simply roll it into place, connect the speaker wires to an external Theory loudspeaker controller and it’s ready to play.
This is especially ideal for DJs, outdoor events, corporate venues, hospitality, and more where big, clear, full-range sound is required. All-weather versions of each model are also available.
From Paul Hales, founder and product designer for Pro Audio Technology: “I am very proud to be celebrating PRO’s 20th anniversary, and what better time to release the next generation of PRO products?… The new loudspeakers are specifically designed to fill a niche at the premium end of the residential and commercial market with a family of products that are flexible, compact, easy to install, and can handle near sound reinforcement levels while sounding like true high fidelity.
Here is what know about the five new speakers so far.
CF-28.2
Pro Audio Technology CF-28.2 Loudspeaker
CF-28.2
The CF-28.2 incorporates a dual 8-inch 2-way multi-use loudspeaker with an 80° x 60° elliptical horn. For installations integral pole cups and ergonomic handles are included. In addition an PRO SplitYoke Multipurpose Mounting Bracket Kit for horizontal and vertical surface mounting is available.
CF-46.2
Pro Audio Technology CF-46.2 Loudspeaker
CF-46.2
The CF-46.2 is a quad 6-inch 2-way multi-use loudspeaker with an ultra-slender profile providing 120-degree conical coverage. For installations integral pole cups and ergonomic handles are included. In addition an PRO SplitYoke Multipurpose Mounting Bracket Kit for horizontal and vertical surface mounting is available.
CF-112.2
Pro Audio Technology CF-112.2 Loudspeaker Trio
CF-112.2
The CF-112.2 is a single 12-inch 2-way multi-use loudspeaker with an 80° x 60° elliptical horn. For installation integral pole cups and ergonomic handles are included. In addition an PRO SplitYoke Multipurpose Mounting Bracket Kit for horizontal and vertical surface mounting is available.
CF-212.3
Pro Audio Technology CF-212.3 Loudspeaker Pair
CF-212.3
The CF-212.3 is a full-range multi-use loudspeaker with a built-in subwoofer. The speaker includes dual 12-inch and dual 8-inch drivers within a 3-way multi-use design. The CF-212.3 has a rugged, refined enclosure that is only 10 inches deep. For installations integral pole cups and ergonomic handles are included.
In addition an PRO SplitYoke Multipurpose Mounting Bracket Kit for horizontal and vertical surface mounting is available. A Caster Kit is also available for portability.
CLF-212
Pro Audio Technology CLF-212 Loudspeaker Pair
CLF-212
The CLF-212 high-output, compact bass-reflex subwoofer with dual 12-inch 1,400-watt woofers. To make sure that the frequency of the frequency range of the CLF-212 is compatible with the rest of the speakers it is sonically matched to CF-46.2, CF-28.2, and CF-112.2. The CLF-212 includes integral pole cups and ergonomic handles for ease of installation.
Pricing & Availability
Attendees of the 2024 CEDIA EXPO will be able to see and hear all five new speaker and subwoofer models in booth 1943.
In addition, in-room HPA 202, there will be a 20th-anniversary get-together from 4 to 6 pm (MT).
PRO Audio Technology loudspeakers are built to order in the USA. Contact Pro Audio Technology or Authorized Dealers for details. Pricing as follows:
  • CF-28.2: $4,800 each
  • CF-46.2: $5,000 each
  • CF-112.2: $4,800 each
  • CF-212.3: $9,000 each
  • CLF-212: $5,800 each
All five new PRO loudspeakers will be available in Q4 2024.
Related Reading
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
Just add in-ceiling speakers to Q Acoustics 300A Ceiling Amplifier to bring streaming music and Amazon Alexa into any room.
At $1,199, the Onkyo TX-RZ30 9.2 Channel A/V Receiver includes Dirac Live, Dolby Atmos, THX Certification, IMAX Enhanced, and more.
Audio Cables
At $160 to $500, this hybrid HDMI cable uses copper and optical to deliver 48 gbps of performance in long lengths up to 20...
Those who want to fill a large living room or home theater with deep gut-wrenching bass will rejoice at the news of a new...
Digital Music Systems
At $2,499, the NAD M10 V3 (3rd gen) streaming amplifier adds a MM phono input along with Dirac Live Room Correction and Bass Control.
In this episode the eCoustics teams reveals its Best in Show product awards from CEDIA Expo 2024 across 17 different categories.
Part 3 of 3 from CEDIA Expo 2024 highlights Ascendo, Theory Audio, Bowers & Wilkins, L-Acoustics, TCL, JVC and Grimani Systems.
