PrimaLuna EVO 300 Hybrid Integrated Amplifier “Floyd” Version Can Be Had Soon…
The PrimaLuna EVO 300 Hybrid Integrated Amplifier Floyd Design combines a solid-state power amplifier and tube pre-amplifier.
We got word of the new PrimaLuna EVO 300 Hybrid Integrated Amplifier Floyd Design which looks rather interesting but we had to do some digging and reach out to Upscale Audio for some clarification.
PrimaLuna’s distribution in North America is handled by Kevin Deal (Upscale Audio), who is both fantastic to deal with when it comes to new product information, but also a great retailer. Upscale Audio is one of the premier high-end dealers in N. America and Kevin really knows the tube business better than most. If he doesn’t have it or have the ability to help you — you’re possibly out of luck.
PrimaLuna EVO 300 Hybrid Integrated Amplifier Floyd Design Front
The EVO 300 Hybrid is a solid-state integrated amplifier with a tube pre-amp section that is going to retail for possibly $7,295 USD (subject to change). In Europe retail will be €6.975, including VAT.
Durob Audio Head Designer, Jan de Groot, is responsible for the design of the new “Floyd” version which incorporates their MOSFET power stage and PrimaLuna tube pre-amp design.
There is no phono section from what we can tell based on the supplied images.
Kevin Deal, Founder of Upscale Audio (Authorized PrimaLuna USA retailer) had the following to say:
I will say there has never been an amp design like this one. From what I can see anyway. Never had I seen a dual-mono tube front end with two power supplies just like our preamps and a third transformer for the power amp.  Heady stuff.
50 samples of the EVO 300 Hybrid have been shipped to distributors and Upscale Audio currently has a handful on the bench in California before they are formally introduced but it certainly looks like an interesting product; it will be curious to see how it fits into the rest of their lineup which has some excellent products that are less expensive like the EVO 400 Tube Integrated Amplifier which retails for $4,995 ($5,248 with the optional phono stage).
Time will tell how this much more expensive integrated amplifier compares.
Specifications:
  • Power 8 Ohm >100 Watts per channel (typical 115 Watts)
  • Power 4 Ohm >150 Watts per channel (typical 170 Watts)
  • Frequency Response 10 Hz – 80 kHz +/- 3 dB
  • THD < 0.2% 100W @ 8 Ohm
  • S/N Ratio -105dB (A-Weighted)
  • Input Impedance 34k Ohm
  • Input Sensitivity 415 mV
  • Total Gain (Pre + Power Amp) 37.2 dB (7dB + 30.2dB)
  • Power Consumption 99 Watts (no signal in); 645W@4R
  • Weight
    • Net weight: 59.5 lbs / 29 kg
    • Shipping Weight: 68.3 lbs / 25 kg
  • Dimensions 15.9″ x 15.2″ x 8.1″ / 405 x 385 x 205 mm (L x W x H)
  • Shipping Dimensions 22.7″ x 18.4″ x 12.4″ / 578 x 468 x 316 mm (L x W x H)
  • Inputs 5 pairs Stereo RCA, 1 pair Home Theater Input
  • Outputs Speaker Taps, Tape, Stereo/Mono Sub, Headphone
  • Tube Complement 6 x 12AU7
  • Damping Factor 160 (1 kHz)
For more information: primaluna.nl
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
Rega's forthcoming Brio MK7 Integrated Amplifier will be available this month and is creating a stir with its internal DAC for only $1095.
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
We've been listening to a lot of integrated amplifiers over the past 12 months, and these 4 are some of the best below $3,000.
SV-500 MK Adds HDMI ARC and Bluetooth 5.0 Connectivity and outputs 50 watts per channel for $1,500.
Priced from $10,000, the Feliks Audio Envy Meisterwerk headphone amplifier features all analog circuitry with 300B vacuum tubes.
At only $64.99 each, the Apos Ray 6SN7 Select vacuum tubes may deliver the dynamics and authentic sound you've been seeking.
At $9,999, the Unison Research Simply 845 Integrated Tube Amplifier makes a strong case to be the last amp you'll ever buy.
