Pragmatics Environmentally Conscious 12-Channel Audiophile Quality Amplifier
Santa Clara, CA — September 10, 2007 — Pragmatic Communication Systems, Inc. has always made it its mission to introduce energy efficient and compact products into the market. There is no better example of that philosophy than the MCA-1248, a 12-channel audiophile quality amplifier. The MCA-1248 multi-channel amplifier produces a big, luxurious sound yet is so efficient that it doesn’t require a heat sink or ventilating fan. The small yet powerful package delivers a true high fidelity performance that surpasses the quality of amplifiers ten times its size and weight. At only ten pounds and a two-rack unit height, it is by far the most compact and efficient amplifier in its class.
In fact, MCA-1248’s biggest competitor weighs in at a whopping 72 pounds. Its staggering weight is due, in part, because it loses large amounts of energy to heat. In order to contain the heat, the amplifier must have more aluminum in its heat sink. In addition, it also contains more copper, sheet metal and iron. So not only will the competitor’s amplifier cost you more on energy bills, but you will also squander money away in its hardware.
The robust design of the MCA-1248 provides extremely clean, state-of-the-art power. It produces unexpected sound depth and musical clarity. The unit accepts any volume controlled line level input and uses a quiet and efficient 110 V AC power supply. It also features advanced protection circuitry guards against system damage from overload, overheating or short circuits.
There are a number of applications for the MCA-1248. It is ideal for multi-room audio, bi-amplified speakers and home theater systems. It can power six rooms with ease and produces a signal-to-noise ratio and dynamic range of greater than 100 dB. It maintains continuous power of 48 watts per channel with peak power of 90 watts per channel.
Pragmatic offers high quality digital amplifiers that possess numerous advantages over other options in the market. A Pragmatic amplifier boasts high efficiency and clock frequency. It also has very linear gain and phase characteristics with a flat frequency response from 20 Hz to 20 kHz. There is no ripple in the pass band and very low change in distortion versus out power levels (usually between 0.01 and 0.05%). It maintains very low and uniform distortion on all frequencies and very high signal-to-noise ratio and dynamic range.
Pragmatic Communications Systems, Inc. is a Silicon Valley based company established in 1994 to design, develop and produce a variety of innovative products for wireless audio, video and data communications. The majority of the company’s products up until 1997 were designed for industrial and commercial applications, after which Pragmatic branched into the consumer market. The success of the older products led to a strong and dynamic technology base, which helps fulfill Pragmatic’s mission to use its technologies to provide solutions to long unresolved technical problems with designs that are both compact and energy efficient. This belief has been applied to a new generation of Pragmatic products such as DMSTM, CATSTM, True MusicTM wireless hi-fi system, and True ViewTM wireless video system.
All the products mentioned can be found on the Pragmatic website at http://www.pragmatic1.com/
Note: Image shown is both front and back of amplifier.
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
