Headphones
Polk Audio UltraFit 1000a, 2000a, 3000a Android Headphones
Polk Audio recently introduced three new Performance UltraFit headphones, each of which are Made for Android. They offer complete control over calling and music listening functions, such as volume, track skip, and more, via in-line or on-ear single-button remote control and microphone. In addition, each of the three new headphones are designed for individuals looking for superior audio quality, durability and style in the headphones they use while training, practicing or generally engaged in an active lifestyle.
UltraFit 1000a, In-Ear Headphone ($69.95): (photo above) High performance digital sound; in-line 3-button remote control and microphone; Securefit support; two ultra-flexible, tangle-free planar audio cables; Strainguard; Moisture Shield; 3.5mm connector. Available in black/red and white/gray. Zippered, vented protective case; 41-inch cable; 14-inch cable; three pair StayFit silicone tips.
Polk Audio UltraFit 2000a
UltraFit 2000a, On-Ear Headphone ($69.95): High performance digital sound; built-in 3-button remote control and microphone; Securefit support; ultra-flexible, tangle-free planar audio cable; Strainguard; Moisture Shield; airframe design; reflective wraparound headband; 3.5mm connector. Available in black/red and white/orange. Zippered protective case; one pair silicone ear pads; two pair foam ear pads; one pair cold-weather shearling ear pads.
Polk Audio UltraFit 3000a
UltraFit 3000a, In-Ear Canal Headphone ($99.95): Ultra high performance digital sound: in-line 3-button remote control and microphone; Securefit™ support; two ultra-flexible, tangle-free planar audio cables; Strainguard; Moisture Shield; 3.5mm connector. Available in black/red, white/gray and white/orange. Zippered, vented protective case; 41-inch cable with in-line Apple control, 14” cable, three pair StayFit silicone tips; two pair StayFit 3-flange silicone tips, three pair memory foam tips.
Availability
Polk Audio’s new selection of Made for Android Performance UltraFit headphones starting shipping in late December 2012.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
