Polk Audio SurroundBar 9000 Instant Home Theater
Polk Audio just introduced their top-of-the-line reference SurroundBar 9000 Instant Home Theater (IHT), illustrating how a sleek new single-cabinet multichannel speaker can deliver a home theater experience that belies its price point. A wireless subwoofer (included) features an array of proprietary Polk Audio technologies to create a truly enveloping listening experience.
The SurroundBar 9000 IHT is self-powered, delivering 45 Watts of discrete peak power to each of its eight drivers (five 2-1/2″ midrange drivers and three 1/2″ silk dome tweeters). Add to that the system’s 150 Watt, 8-inch wireless subwoofer—which can be located as far as 50 feet away and connects to the system automatically upon powering on—and the SurroundBar 9000 IHT as a whole is capable of delivering 510 Watts of total peak power: 25 times as much as the typical TV speakers it is designed to replace.
The 9000’s Optimized Center Array (OCA) design results in unprecedented clarity and intelligibility of center channel audio over a very wide listening area. Outer and inner driver pairs reproduce center channel information from 80 to 400Hz, and 80 to 650Hz respectively. Translated into plain English, this benefit allows listeners sitting far to the side to hear dialogue and other critical sonic details with the same balance and impact as those listeners situated in the center “sweet spot.”
Unique to the SurroundBar 9000 is Polk’s new Full Complement Bass design. All five 2-1/2″ drive units reproduce the summed L/C/R/SL/SR channels over the 80Hz to 200Hz passband, resulting in deep resonant bass that is experienced in every listening area in the room.
Polk’s patented SDA (Stereo Dimensional Array) Surround technology also works to eliminate crosstalk between channels, ensuring that left and right ears independently hear the sound intended for them, creating a lifelike three-dimensional sound experience that closely replicates the way the listener experiences sound in the real world. A proprietary Polk technology, SDA creates a 360-degree soundfield that envelopes the listener without the need for side and rear-channel speakers.
Polk Audio’s SurroundBar 9000 IHT features dual tuned ports designed to provide optimal blending between the midrange drivers and the subwoofer, no matter where the sub is located in the room,
and no matter if the bar itself is shelf- or wall-mounted.
The SurroundBar 9000’s cabinet measures just 3-3/4 by 44-5/8 by 2-1/4 inches—the perfect visual complement to a 50-inch flat panel display, although the SurroundBar 9000 IHT will sound just as
impressive with any size screen. And with two digital optical inputs (in addition to two analog audio inputs), combined with internal Dolby Digital and DTS processing, the 9000 IHT is designed to deliver more dynamic, high-impact sound from digital audio sources, straight out of the box.
[youtube id=”msPaIx1l0dA” width=”610″ height=”373″]
One key to the stunning performance of the SurroundBar 9000 is Polk Digital Logic technology, which relies on proprietary digital signal processing to optimize the system’s acoustical performance
in the typical room, without the need for complicated setup menus and baffling instruction manuals.
The SurroundBar 9000 IHT is Energy Star certified, and comes with a backup remote control, which can easily be programmed to understand the customer’s own TV remote control. Each system
also features built-in keyhole slots for mounting, which ensure a wide range of placement options.
“Nobody knows sound bar design better than Polk, but even we are blown away by the output of the SurroundBar 9000, says Polk Product Line Manager Al Baron. “The combination of simplicity and sonics is easily the best we’ve seen from us or any manufacturer in the field. We’ve elevated driver design to new heights with this model, and it includes all of the technologies that have made our Instant Home Theater line such a success, including SmartBar programming, which enables the SurroundBar to easily learn power on/off, volume up/down and mute from your existing TV remote control. It makes operation as simple as can be.”
Price and Availability
The Polk SurroundBar 9000 Instant Home Theater is available now for $799.95.
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
New Polk Audio Reserve Series loudspeakers are aimed at the next generation of audiophiles looking for affordable high-end sound.
Looking for an affordable subwoofer this holiday season? The Polk Audio Monitor XT10 retails for $299.
Podcasts
A/V Industry veteran, Philip Jones of Sound United and co-owner of ProjectorReviews.com shares his passion for hi-fi and home theater, along with some interesting...
Loudspeakers
We are very sad to report the passing of Al Ballard, longtime Polk Audio VP of Marketing and industry marketing icon.
What you need to know about understanding frequency response curves of loudspeakers.
Daily Deals
The Polk Audio Labor Day Sale in on! Save up to $1,000 on Polk Reserve and Legend Series loudspeakers which is a huge savings.
The Polk Audio MagniFi Mini AX packs in features and big sound in a very small package. We think it's better suited for a...
Get big sound for your TV viewing with a soundbar that is only 14.5-inches wide! Find out how Polk Audio MagniFi Mini AX makes...
