Platin Monaco 3.1 or 5.1 Plus Axiim Link Wireless Home Theater Systems
Convenient to setup THX Tuned wireless speaker systems in 3.1 or 5.1 configurations require a WiSA Ready TV.
Platin Monaco 5.1 Wireless Wisa Speaker System
WiSA Certified & Tuned by THX
Platin Audio just introduced the Tuned by THX™ Monaco 3.1 Wireless Home Audio System for $699.  The package includes three individual speakers and a subwoofer. All are wireless and stay connected via included Axiim LINK Wireless Audio Transmitter which requires connection to a WiSA Ready* TV (currently only 2019-2020 LG TVs**). WiSA Ready compatible devices currently only include late model LG OLED TV, LG NanoCell TV, Xbox One, Xbox One S, and Xbox One X. So without one of the aforementioned products, sadly the Platin Audio wireless speaker system won’t work.
In addition, Platin Audio offers a Monaco 5.1 speaker system which adds two wireless surround sound speakers for only $100 more. It was released late last year. Both systems use the same satellite speakers, center channel and subwoofer.
Because all speakers are wireless, setup should be super simple. Just plugin each speaker to a wall power outlet, plug the Axiim Link into the TV’s USB port and then use the Axiim LINK mobile app to make sure they’re all connected. The app also provides users with enhanced tuning features such as preset and user adjustable equalization and speaker trim.
Platin MW30 Wireless Wisa Speaker Rear View
Platin MW30 Wireless Satellite Speakers
The Monaco wireless speakers have been Tuned by THX to deliver an improved audio experience. THX has worked with Summit Wireless and WiSA engineers to create a set of high-accuracy filters and functionality within the Rx (wireless receiver) modules to provide the manufacturer with advanced loudspeaker tuning capabilities.
Platin Axiim Link Wisa Transmitter
Axiim Link – WiSA Wireless Audio Transmitter
All WiSA Ready and WiSA Certified components work together seamlessly to deliver wireless, multi-channel audio capabilities and authentic concert and theater-quality sound that dramatically increases the enjoyment of movies and video, music, sports, gaming/esports, and more.  As a result, consumers can expect a reliable and superior experience without a complicated setup or running speaker wires around the room. Plus, any WiSA Certified wireless speakers can be used interchangeably or added later, such as from Klipsch or Enclave. The included Axiim Link WiSA Transmitter, which is also sold separately for $229, supports up to 5.1 surround sound when connected to LG TVs and up to 7.1 when connected to Xbox One.
“THX is pleased to partner with WISA on this Tuned by THX Platin Monaco 3.1 speaker system to ensure consumers experience exceptional audio with their favorite content, whether movies, music or games. This Monaco system was calibrated by our THX engineers as a continuation of our partnership with WISA to bring great wireless audio systems to market at various price points.”
Peter Vasay, vice president, home products, THX Ltd.
Features
  • Tuned by THX™ to verify the system has been calibrated for maximum audio quality
  • Wirelessly streams, immersive, 3.1 or 5.1 High-Resolution Audio
  • Uncompressed, 24-bit, 48 kHz quality, better than MP3 and CD
  • Less than 5.2 millisecond latency for picture-perfect lip sync
  • One microsecond synchronization between speakers for amazing accuracy and clarity
  • 10-band system and per speaker EQ, volume adjust per speaker, bass management, audio mixing
  • Works with Xbox One, Windows 10 PC, MAC, 2019-2020 LG OLED and NanoCell TVs, USB audio sources
  • Setup in minutes, not hours
  • No Wi-Fi required
Platin Monaco Wireless Wisa Subwoofer
Platin 100-watt RMS wireless subwoofer
Price & Availability
* WiSA Ready TVs, gaming PCs and console systems are “ready” to transmit audio to WiSA Certified speakers when a WiSA USB Transmitter is plugged in and a user interface is activated through an APP or product design like LG TVs.
** Platin Audio products are not compatible with these LG TVs models sold by Costco: OLED65E9AUA, OLED77C9AUA, OLED65C9AUA, OLED55C9AUA and NanoCell 75SM8670AUA, 65SM8600AUA.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
A/V Furniture & Accessories
AUDIO Cu plug-in adapters eliminate long cable runs by sending up to 10 channels of audio over power lines already in your home.
At $2,499, the Hisense PL2 ultra-short throw projector has a lot in common with the previous PL1 but it can project a larger 150-inch...
Daily Deals
For Prime Day save $250 off the Platin Milan Soundbar system that delivers 10 channels of wireless Dolby Atmos surround sound.
At $2,999, Triangle's CAPELLA wireless speakers offer a lot of flexibility with support for HDMI ARC, WiSA, Bluetooth, and room calibration.
The Pyramid is a compact hi-fi system with Bluetooth wireless built-in that's designed to deliver warm, clean sound that limits ear fatigue.
At $2,499, the Optoma UHZ55 replaces the UHZ50 laser projector designed for home entertaiment and gaming. New WiSA support simplifies wireless speaker setup.
Platin Audio’s Milan Soundbar connects to your TV via HDMI-eARC but uses WiSA Technology to provide wireless subwoofer and surround channels.
Daily Deals
Looking for real discrete immersive surround sound without speaker wires? Check out this limited time deal on Platin's 5.1.2 wireless speaker system.
