Pioneer VSX-921 A/V Receiver
7.1-Channel A/V Receiver Featuring HDMI (3D, ARC) Connectivity and Compatibility with iPod, iPhone, iPad
Pioneer has introduced the VSX-921 7.1-channel A/V Receiver with enhanced 1080p up-scaling using Anchor Bay video processing, priced at $449. The VSX-921 converts analog video sources to HDMI for one-wire high definition convenience. For lower resolution video, advanced video processing lets you upscale your picture to digital 1080p to best match the native resolution of your HDTV.
The VSX-921 is compatible with iPod, iPhone and iPad devices and are specifically designed to enhance the experience you get from them. The receiver comes with a USB/video cable to access all music, videos, streaming content, and photos stored on your Apple devices.
Since the iPod, iPhone, or iPad charges automatically when connected, it's the ultimate plug-and-play integration with your home theater. You can enjoy music, videos and movies, downloaded TV shows from iTunes, photos, web content such as YouTube and much more. And because the iPhone device's wireless and network features remain fully functional, music and movies will mute when you receive an incoming call. And you've got lots of control options–use the iPad or iPhone directly, or push a single button on the VSX-921's front panel to switch control to the included preset remote and an intuitive on-screen display complete with artist, track, play mode, and track time information.
Pioneer VSX-921 A/V Receiver with iPhone
The VSX-921 is fully ready for wireless Bluetooth audio from virtually any A2DP profile Bluetooth device, including smartphones, laptops, etc. With the Pioneer AS-BT200 Bluetooth adapter you can enjoy near cd-quality with Sound Retriever AIR technology, created specifically to enhance Bluetooth audio.
This receiver supports all the high-definition audio formats including Dolby TrueHD and DTS-HD Master and Dolby Pro Logic IIz. Pioneer's exclusive Multi-Channel Acoustic Calibration system (MCACC) provides a near studio-quality, multi-channel listening experience customized specifically to your listening environment. An included microphone measures every speaker's connection, and notes its size, distance from the listening point, sound levels and timbre to calibrate and maximize performance.
Even compressed audio such as WMA, MP3 and AAC is enhanced with another Pioneer exclusive, Advanced Sound Retriever, by filling in areas where minute details were left out during the compression process. There's also an Auto Level Control that eliminates jarring volume changes between your favorite songs, albums and audio sources by equalizing volume differences between portable audio tracks or television programming.
The VSX-921, and all of Pioneer's newest receivers support the latest HDMI 1.4a specification for 3D video content. Additional HDMI conveniences include Audio Return Channel and HDMI Standby Through.
Pioneer VSX-921 A/V Receiver - Back
Amplification
  • 110W x 7 (1 kHz, THD 0.05% @ 8 ohms)
  • 80W x 7 (20 Hz — 20 kHz, THD 0.08% @ 8 ohms FTC)
Audio
  • Dolby TrueHD / Dolby Pro Logic IIz / Dolby Digital EX / Dolby Digital Plus
  • DTS-HD Master Audio / DTS-ES / DTS Neo:6
  • Digital Core Engine with Texas Instruments Aureus DSP
  • 192 kHz/24-bit Digital to Analog Converter
  • 96 kHz/24-bit Analog to Digital Converter
  • Auto MCACC Room Calibration
  • iPod Digital Audio
Video
  • Anchor Bay 1080p Video Scaler
  • Video Conversion to HDMI
Connectivity
  • HDMI Inputs (4 In / 1 Out)
  • Front USB / AV Inputs
  • Bluetooth Port (Optional AS-BT200 or AS-BT100 adapter required)
  • Component Video Inputs (2 In / 1 Out)
  • Digital Inputs (1 Coaxial, 2 Optical)
  • Analog AV Inputs (4 AV, 2 Audio)
  • Surround Back or Front Height Pre-Out
  • Subwoofer Pre-Out
  • Sirius Satellite ready
  • Large Speaker Terminals x 7 (FL / FR / C / SL / SR / B Speaker)
  • Assignable Speaker Terminals
    • Surround Back / Front Height
    • Surround Back / B Speaker
Convenience
  • Compatible with iPod, iPhone, iPad Front USB Input
  • Charges iPod, iPhone, iPad
    • Combination USB / Composite Video Cable Supplied
    • iPod touch, iPhone, iPad Stored and Streaming Audio & Video
    • Memory Audio Playback (MP3/WMA/AAC)
  • On-Screen Display
  • Bluetooth Ready
  • 30 Preset AM / FM Tuner
  • Auto Power Down
  • HDMI Standby Through
  • HDMI CEC
  • Auto Surround
  • Sleep Timer
  • Preset Remote Control
MSRP: $449
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
