Pioneer VSX-830 & VSX-1130 A/V Receivers
Pioneer VSX-1130 A/V Receiver Front
Pioneer announced two budget home theater receivers that support today’s high quality audio and video formats. The $399 VSX-830 5.2-channel (80-watts x 5) A/V Receiver features built-in Wi-Fi, Bluetooth, HDCP 2.2, HDMI 2.0, DSD file playback, subwoofer EQ and more. The $599 VSX-1130 7.2-channel (100-watts x 7) Receiver adds Dolby Atmos, more power and connectivity plus MCACC Pro audio processing.
Wi-Fi / Bluetooth Built-in – Incorporating built-in Wi-Fi supporting both the 5GHz and the 2.4GHz bands on the VSX-830 and VSX-1130 enables wireless music streaming from a home network or connected device including Apple’s AirPlay, Pandora, vTuner and Spotify. Conveniently, both models let users easily stream music via Bluetooth from devices such as smartphones, tablets, and laptops.
Pioneer VSX-830 A/V Receiver
VSX-830
Pioneer VSX-1130 A/V Receiver Back
VSX-1130
Dolby Atmos – Launched late in 2014, the amazing effects of Dolby Atmos in 5.1.2 can be experienced in the upper model VSX-1130.  Sounds come alive and surround the listener from all directions, including overhead, to fill any home theater with astonishing clarity, power, detail, and depth. Pioneer’s VSX-1130 receiver will be able to decode and play back Dolby Atmos content for consumers to enjoy in their compatible home theaters.  Combined with Pioneer’s new line of Dolby Atmos-enabled Elite speakers, users will have access to the ultimate immersive home theater experience without having to install overhead speakers.
HDMI 2.0 – Pioneer is the first AV manufacturer to incorporate HDMI 2.0 into its line of receivers, bringing the latest advances in consumer entertainment into the home. Version 2.0 of the HDMI specification offers a significant increase in signal bandwidth, now up to 18Gbps. The increased bandwidth provides support for new features such as 4K60p 4:4:4 24-bit color support. The 4:4:4 color support offers viewers the highest quality color reproduction available in content today when images are displayed on compatible 4K televisions screens. The ability to pass through a very high bandwidth signal without downgrading the image means that Pioneer receivers will serve as the perfect entertainment hub.
HDCP 2.2 – HDCP 2.2 is the next advancement in copy protection, ensuring a secure connection between a source and display. Each Pioneer model in the line-up is HDCP 2.2 compliant offering compatibility with current and future 4K content, ensuring that consumers who upgrade their systems will still work with Pioneer’s 2015 products.
Music Enthusiast – Offering a diversified listening experience, the receivers have access to today’s most popular Internet radio music services including Spotify, PANDORA and vTuner. In addition, Pioneer incorporates the seamless connectivity standards of HTC Connect that enables wireless high quality music files to be shared between compatible HTC One smartphones and Pioneer receivers.
Pioneer VSX-830 A/V Receiver Back
VSX-830
VSX-1130
SABRE Premier Audio DAC – The VSX-1130 incorporates the ES9006S DAC (192kHz/24-bit) to bring true professional digital audio into the home for unparalleled audio performance. The advanced DAC produces outstanding sound quality with warm, more natural sound reproduction, as well as a linear response resulting in audio with substantially less jitter.
MCACC Pro – The VSX-1130 includes MCACC Pro fully supporting the surround format of Dolby Atmos (5.1.2) with an acoustic calibration system that precisely compensates for differences in speaker size, distance, and level as well as the room’s layout including ceiling height, and changes equalizer settings for an excellent audio response. MCACC Pro works with both Pioneer’s Dolby Atmos-enabled Elite speakers and in-ceiling speakers.  MCACC Pro also features dual subwoofer output as well as 4-band subwoofer EQ for increased sound quality in the low frequency range.
Advanced MCACC with Subwoofer EQ – Pioneer developed its MCACC technology more than 10 years ago with the help of professional recording studios. Advanced MCACC built into the new models helps create the optimum acoustic environment for movies and music. The VSX-830 uses a setup microphone (included) and a subwoofer EQ to compensate for differences in speaker sizes, output levels, and distances from the user’s listening position automatically.
4K Ultra HD 60P Video Up-Scaling – Both VSX-830 and VSX-1130 receivers support the next generation 4K Ultra HD resolution standard to help provide the highest quality video image available, with the ability to pass through 4K video signals of up to 60 frames per second to any HDMI 2.0-equipped 4K display. It can also upscale 1080p/60 signal before delivery to make them suitable on compatible 4K Ultra HD displays.
Multi-Channel High Resolution Music Playback – Strengthening a commitment to high-resolution music playback beyond two channels, Pioneer added playback support for 192kHz 24-Bit 5.0- and 5.1-channel WAV files (only via USB) and for 96kHz 24-Bit 5.0- and 5.1-channel FLAC files. (up to 48kHz via wireless network). The receivers also support 2-channel high-resolution music files including AIFF, WAV, FLAC, DSD (2.8 MHz), DSD (5.6MHz) (VSX-1130 only), Apple Lossless as well as MP3, WMA and AAC, offering broad support for the most common high-resolution music.  Gapless playback for many of these file formats is supported as well. In addition, Pioneer’s MCACC room calibration works with high-resolution music playback.
Start-up Navi – Pioneer created a dedicated app that helps easily set up the AV receivers using an iPod touch, iPhone, iPad or Android device while connected to a home network. The process with the wizard makes network set-up with the receivers smooth and effortless. In conjunction with the Wiring Navi, the Start-up Navi app lets the user do all the initial settings of the receiver.
iControlAV5 Application – Pioneer developed iControlAV5, a new app enabling wireless control over the features and functionalities of 2011, 2012, 2013, 2014 and 2015 line of the receivers from the convenience of various portable digital devices. The app incorporates multiple controls from basic volume adjustments and input selection to advanced features such as equalizer adjustments and management of audio settings and modes. The app is available for free on the App Store for iPhone, iPad and iPod touch. The app is also available in Google for Android devices.
AVNavigator Built-In – The VSX-830 and VSX-1130 features AVNavigator built-in, eliminating the need to upload the software to a computer or laptop.  Simply connect the receiver to a home network and launch the web browser. AVNavigator features Pioneer’s Wiring Navi application, providing an interactive guide walking the user through the entire receiver setup process including speaker arrangement, sound optimization, connecting sources, MCACC calibration, renaming inputs, and more. AVNavigator also includes an Interactive Operation Guide application (VSX-1130 only) providing a linked two-way operation guide that gives users a way to learn about the receiver’s features (i.e. a push of the standard surround button on the front of the receiver takes the user directly to the portion of the manual that explains the standard surround feature).
Price and Availability (April 2015)
Pioneer VSX-830 → $399
Pioneer VSX-1130 → $599
3 Comments
3 Comments
  1. romel martelino
    March 25, 2015 at 4:43 am
    Hi im interested with the vsx 830, I just would like to know if I can make use of the 5.2 channel for stereo music?
    can I selectively turn on or of this channels in pairs? like 1 pair for the Dining, 1 pair for the Kitchen and 1 pair for the Den?
    • Cesar
      April 29, 2015 at 7:01 pm
      go for the VSX-1130-K it have Multi-Zone Audio and Video
      • Limech
        May 18, 2015 at 2:35 pm
        Actually, I’ve had nothing but problems with the VSX-1130-K.
        The menu system doesn’t start halfl the time and couldn’t get any of the network features to work using a simple wired connection. Unit gets IP from router ok but no connectivity. Same cable works well with other units.
        I does its basic jobs ok, but all the advanced stuff are DOA.
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Experience the full impact of Super Bowl LIX in your living room with both a big picture and big sound.
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
The backbone of a home theater or surround sound system, today's best AVRs are packed with features and performance (updated for 2024)
Select Onkyo, Integra and Pioneer A/V receivers add support for Dirac Live Bass Control, Amazon Music HD, TIDAL MAX, Source-based Tone Mapping and Google...
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Denon's budget friendly Dolby Atmos AV receiver offers excellent connectivity and sound quality for under $600.
After a five year hiatus, Sony is back with new A/V receivers optimized for home theater and immersive surround sound.
