Pioneer’s VSX-535 and VSX-835 AVRs Deliver Affordable Home Theater Solutions For Those On a Budget
Priced under $500, Pioneer’s refreshed entry-level 5.2-channel and 7.2 channel A/V Receivers add support for 4K/120 and 8K resolution.
Pioneer VSX-835 A/V Receiver (2024 model)
TV and Projector technology keeps getting better. 4K displays have become the default resolution and other visual aspects, such as brightness and HDR quality have improved greatly. Combined with extra-large screen sizes, there is a TV available to meet just about everyone’s needs.
However, although TVs and projectors can display big, bright images, they don’t deliver the sound quality to match. In our article: How To Improve Your TV’s Sound Don’t Settle For Less we discussed several ways to improve TV sound quality, and one option is to use a setup consisting of an Audio/Video Receiver (aka AVR) and your choice of speakers.
Pioneer VSX-535 A/V Receiver Front
Pioneer VSX-535
Pioneer VSX-835 A/V Receiver Front
Pioneer VSX-835
Pioneer VSX-535 & VSX-835
With that in mind, Pioneer has announced two new AVRs that might fill the bill without emptying your wallet, the VSX-535 ($379) and VSX-835 ($479).
Both receivers are designed to provide solid basics needed for a home theater setup but also include some advanced features not normally seen in their price range.
Flexible Speaker Setup
The VSX-535 can be configured with a 5.1 or 5.2-channel speaker setup. This means that you can have a setup with left, center, right, left surround, right surround, and either one or two subwoofers.
You can also configure the VSX-535 to run with a 3.2.2 channel configuration for Dolby Atmos. This means you can have a setup with left, center, right, left height, right height, and up to two subwoofer channels.
For the VSX-835 you can use a 7.1 or 7.2-channel speaker setup. This means that you can have a setup with left, center, right, left surround, right surround, left back, right back, and either one or two subwoofers. However, you can also configure the VSX-835 to run with a 5.2.2 channel configuration for Dolby Atmos. This means you can have a setup with left, center, right, left surround, right surround, left height, right height, and up to two subwoofer channels.
Video Capability
On the video side, 4K@120Hz/8K@60Hz Ultra HD resolution pass through is supported as well as HDR (High Dynamic Range) including HDR10, HLG, and Dolby Vision. The BT.2020 wide color gamut and 4:4:4 color space are also supported.
HDMI
The VSX-535 and VSX-835 provide four HDMI inputs. One HDMI output (ARC/eARC enabled) is provided that can pass 4K/60p and HDR video to a compatible TV or projector, and all HDMI connections are HDCP 2.2 compliant.
IMAX® Enhanced Certification (VSX-835)
In addition to core 4K/8K passthrough, HDR, and Wide Color Gamut support, IMAX Enhanced Mode is included in the VSX-835. This means that with compatible content this mode supports IMAX elevated color, brightness, contrast, and audio fidelity standards.
DTS:X and DTS Virtual:X (VSX-835)
The VSX-835 DTS:X automatically adapts audio to existing channels and speaker setups, so no specific speaker layout is required. Elevating this further, DTS Virtual:X adds nuanced, three-dimensional sound without height or rear speakers. Dolby Atmos Height Virtualizer also allows you to experience immersive sound without the additional speakers. So, no matter which format your media uses, you’ll get the enveloping sound experience.
Dolby Atmos Music
In addition to Dolby Atmos and Dolby Surround for movies and TV, Dolby Atmos Music allows creators to produce and mix with spatial audio elements for a more captivating experience. Pioneer AVRs are some of the first to play Dolby Atmos content via HDMI input from streaming devices.
Advanced Sound Retriever
This feature is designed to maximize the sound quality of digitally compressed audio sources (such as WMA, AAC, and MP3) to original lossless quality by creating new signals to restore the minor details left out during the compression process.
MCACC Auto Room Tuning Software
MCACC (Multi-Channel Acoustic Calibration system) auto room tuning uses a custom microphone to automatically compensate for differences in speaker size, level, and distance and equalizes response that better matches the speakers with room acoustics.
Bluetooth
Whatever audio is playing on your phone, tablet, or PC app can be streamed to the receiver with Bluetooth wireless technology. Once the receiver has paired with and remembered your device, it will start playback automatically whenever it detects an incoming Bluetooth audio stream.
Pioneer VSX-535 A/V Receiver Rear
Pioneer VSX-535
Pioneer VSX-835 A/V Receiver Rear
Pioneer VSX-835
Comparison
VSX-535VSX-835
$379$479
Number of Channels5.2 (configurable to 3.2.2)7.2 (configurable to 5.2.2)
Power Output150w (1kHz, 10% THD, 1ch @ 6 ohms)
80w (20-20kHz, 0.08% THD, 2ch @ 8 ohms – FTC)
165w (1kHz, 10% THD, 1ch @ 6 ohms)
Amplifier ClassClass ABClass AB
HDMI ConnectionsVer 2.1, 4 In / 1 Out (eARC)Ver 2.1, 4 In / 1 Out (eARC)
Resolution Compatibility8K/4K Ultra HD8K/4K Ultra HD
HDRDolby Vision, HDR10+, HLG,  Dynamic HDRDolby Vision, HDR10+, HLG, Dynamic HDR
QFT (Quick Frame Transport)YesYes
VRR (Variable Refresh Rate)YesYes
ALLM  (Auto Low Latency Mode)YesYes
DSC (Display Stream Compression)YesYes
SBTM (Source Based Tone Mapping)YesYes
Audio Inputs4 HDMI,
3 RCA,
1 Opt,
1 Coax
4 HDMI,
3 RCA,
1 Opt,
1 Coax
Audio OutputsZone B Stereo RCA Lineout,
2 Preout subwoofer
2 Preout Subwoofer,
Power Zone B
Room CorrectionMCACC Auto Room TuningMCACC Auto Room Tuning
DolbyDolby Atmos, Dolby Atmos Height Virtualizer, Dolby Surround, Dolby Atmos MusicDolby Atmos, Dolby Atmos Height Virtualizer, Dolby Surround, Dolby Atmos Music
DTSDTS:X, DTS Virtual:X, Neural:X
IMAX EnhancedYes
BluetoothYesYes
Phase ControlYesYes
Advanced Sound RetrieverYesYes
Pricing & Availability
Tip: Pioneer’s prior generation AVRs may be on sale for less while supplies last.
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Experience the full impact of Super Bowl LIX in your living room with both a big picture and big sound.
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
The backbone of a home theater or surround sound system, today's best AVRs are packed with features and performance (updated for 2024)
Select Onkyo, Integra and Pioneer A/V receivers add support for Dirac Live Bass Control, Amazon Music HD, TIDAL MAX, Source-based Tone Mapping and Google...
At $249, the Amazon Fire TV Soundbar Plus features 3.1 channels, but is expandable to 5.1 with optional wireless subwoofer and speakers.
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Denon's budget friendly Dolby Atmos AV receiver offers excellent connectivity and sound quality for under $600.
