Car Subwoofers
Pioneer TS-WX1210A and TS-WX1010A Car Subwoofers Install Easy
Two new sealed enclosure powered car subwoofers (2018 models) come in 10- or 12-inch sizes with 300-watts of power at a competitive price.
Pioneer-TS-WX1210A
Sealed enclosure powered car subwoofers come in 10- or 12-inch sizes with 300-watts of power
Pioneer Electronics introduced the new TS-WX1210A (12-inch) and TS-WX1010A (10-inch) sealed enclosure powered car subwoofers designed to improve the sound in almost any vehicle. Both reasonably priced subs are built with high bandwidth, high output and low distortion class D amplifier mated to high sensitivity woofers specifically optimized for use in small, sealed enclosures. The main difference is that the larger subwoofer is powered by an 18% more powerful amplifier for $20 more.
User adjustable controls include a variable low pass filter (50Hz to 125Hz), phase control (Normal/Reverse) and variable bass boost (0 to +12 dB gain with 40Hz to 100Hz center frequency) providing enhanced control of subwoofer output. To expand system flexibility and user control, input gain can be adjusted using the included wired remote bass control knob or via the input gain control mounted on the enclosure side panel.
The innovative trapezoid shape of the enclosure is designed for high rigidity and to reduce internal standing waves, while also increasing installation flexibility. The subwoofers can be installed freely in the cabin or under seats and can be re-positioned with the subwoofer firing rear, front or upwards for optimal bass tuning. The enclosure is fully carpeted, creating a non-slip, durable and scratch resistant surface.
Specifications
TS-WX1210A
  • 12-inch subwoofer
  • Built-In 350 Watts Output Class-D Amplifier
  • 1,300 Watts Max Power. (350 Watts Nom.)
  • Variable Bass Boost (0 to +12 dB, 40Hz to 100Hz)
  • 20-3/4″ x 11″ x 15″ (W x D x H)
  • Frequency Response: 20Hz – 125Hz
  • Sensitivity: 114dB
  • Wired remote bass control and gain control on side panel
TS-WX1010A
  • 10-inch subwoofer
  • Built-In 300 Watts Output Class-D Amplifier
  • 1,100 Watts Max Power. (300 Watts Nom.)
  • 17-3/4″ x 9-3/8″ x 13-1/2″ (W x D x H)
  • Sensitivity: 112dB
Each powered subwoofer is engineered with the primary components, amplifier, woofer and enclosure to achieve superior bass as a complete system. Both feature speaker level or RCA signal inputs, wired remote controls, and high efficiency class D amplifiers, simplifying integration and installation and allowing these products to fit a wide range of user needs, both for OEM and aftermarket audio systems.
Price and Availability
  • Pioneer TS-WX1210A – $260 MSRP
  • Pioneer TS-WX1010A – $240 MSRP
Triangle Garden 7 Outdoor Speaker Gray Lifestyle
Available in green or gray, Triangle’s GARDEN 7 outdoor speaker delivers 360-degree sound, IP66 weatherproofing, and LED lighting at a reasonable price.
Hisense PT1 UST Projector Top Angle Hisense PT1 UST Projector Top Angle
Hisense PT1 Triple Laser Cinema UST projector delivers 4K, Dolby Vision, WiSA-ready audio, and Google TV for ultimate home theater performance.
TCL Q10M TV Front and Back Angle TCL Q10M TV Front and Back Angle
TCL's first RGB MiniLED TV line will debut in China in 85-inch, 98-inch and 115-inch screen sizes. No word on U.S. availability.
dCS Varese CD/SACD Transport Angle dCS Varese CD/SACD Transport Angle
CD Players
Only for Varèse owners: dCS’s new Transport delivers reference-level CD and SACD playback with ultra-low vibration and ACTUS bit-perfect transmission.
SoundPeats H3 with Hear the Difference on Charging Case SoundPeats H3 with Hear the Difference on Charging Case
The SOUNDPEATS H3 true wireless earbuds launch at $129 with Snapdragon Sound, LDAC, aptX Lossless, 55dB hybrid ANC, and app-based EQ in a crowded...
TEAC PD-507T CD Transport Open TEAC PD-507T CD Transport Open
CD Players
TEAC's Reference 500 Series PD-507T CD Transport is engineered for audiophiles pairing external DACs with a growing CD resurgence.
Vinyl Music Lover Gift Guide 2025
A new turntable, phono stage, cartridge or speaker could be the upgrade you've been looking for or the perfect gift for any vinyl lover.
Premium Audio Company and Pioneer Corporation end their home audio partnership, leaving PAC with Klipsch, Onkyo, Integra, Magnat, and HECO.
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Select Onkyo, Integra and Pioneer A/V receivers add support for Dirac Live Bass Control, Amazon Music HD, TIDAL MAX, Source-based Tone Mapping and Google...
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Priced under $500, Pioneer's refreshed entry-level 5.2-channel and 7.2 channel A/V Receivers add support for 4K/120 and 8K resolution.
Auro 3D, Auro Scene and Auro CX enable spatial audio through A/V receivers, smart speakers and music streaming.
Pioneer-branded TVs are back, but not in the way you think. Find out how Xumo and Best Buy are involved.
Pioneer Elite is back and this A/V receiver packs in everything that you need for your home theater setup.
