Pioneer SC-1222 and SC-1522 A/V Receivers Announced
IB_S_BASIC_COPYRIGHT =
Pioneer Electronics announced the high-end SC-1222 (7.2-channel) and SC-1522 (9.2-channel) A/V receivers, which integrate Class D3 digital amplification, multi-room setup options, multiple HDMI inputs and PC Setup control, as well as the latest technologies including Apple's AirPlay, DLNA 1.5, Windows 7 compatibility, Internet radio and Advanced MCACC auto room calibration.
Pioneer's Class D3 amplifier, built into the SC receivers, generates immense power without sacrificing sound quality and performance. The exclusive class D technology requires less energy than competitive models yet produces more simultaneous power output, and is designed to maximize the audio potential of uncompressed sources such as Blu-ray Disc titles and high-definition audio content distributed on the Internet.
Pioneer SC-1522
SC-1522
The amplifier section also uses a Direct Signal Path Design, configured with all of its internal components to have the shortest audio signal path possible, eliminating EMI filters, feedback loops, and current limiters that were necessary on previous designs. This results in a reduction of ringing distortion and noise, especially in the high frequency audio band. The receivers can produce up to 140 Watts per channel of power with great detail and high dynamic range.
Connectivity Options
Apple's AirPlay, DLNA 1.5 and Bluetooth connectivity are built into both models for wireless access and connection, with the ability to play high resolution FLAC and WAV music files of up to 192kHz/24-Bits. Both receivers offer endless music entertainment with vTuner, PANDORA Internet radio and access to subscription-based SiriusXM Radio. Pioneer's Air Jam App, available at no charge from the Apple App Store on iPhone, iPad, and iPod touch or the iTunes store, at www.apple.com/iTunes/, allows connection to personal sources with its ability to pair up to four devices simultaneously via Bluetooth and create group playlists (optional AS-BT200 Bluetooth adapter required).
  • High Resolution Music Playback — The SC-1222 offers DSD (SACD DFF Files) music file playback via the front USB connection and the SC-1522 offers the 192kHz/32-bit asynchronous USB DAC for ultra-high quality music file playback from a USB3-connected PC or Mac.
  • MHL-Compatibility Device Connectivity — The SC-1522 features a front Mobile High Definition Link (MHL) connection for compatible smartphones as additional sources for audio and video entertainment. The front-panel HDMI/MHL terminal delivers content with up to 1080p video and 7.1-channel HD audio resolution.
Pioneer SC-1222 - Back
SC-1222
Pioneer SC-1522 - Back
SC-1522
Video Enhancement Capabilities
To enhance the video performance from connected sources, both receivers convert all analog signals to digital HDMI and upscale both analog and digital signals to 1080p resolution. The models also use Pioneer's Advanced Video Adjust to optimize video signals by the type of display connected and the Stream Smoother feature to enhance the picture quality of any source downloaded from the Internet via other devices. The incorporated Marvell Qdeo processor produces true 1080p/24fps video. A 4K Pass Through built in to the SC-1522 ensures consumers have the most up-to-date technology to take advantage of advanced digital formats.
Customizable Benefits
Users have full customizable options for their home theater experience with as many as ten different configurations (SC-1522) to create a full 5.1-channel setup with the ability to use the remaining channels for additional zones. Both models offer entertainment options for up to three zones, with Zone 2 providing composite video output and the ability to handle network and USB content, and Zone 3 offering analog audio input sources. The SC-1522 gives users the option of a dedicated Zone 2 subwoofer output in addition to the two dedicated subwoofer outputs for the main zone.
Both models are compatible with home automation systems from Control4, Crestron and Savant. Additionally, most home theater system needs can be tailored with the ability to control the receivers directly from portable devices running Pioneer's iControlAV2012 App.
To help make custom installation more convenient, the Advanced PC Setup feature in the SC-1522 lets installers pre-configure connection settings on a Windows-based personal computer before the actual installation process, as well as perform read and rewrite functions to reset and adjust the receiver from a remote location. Do-it-yourselfers can use Wiring Navi for Windows-based PCs and the iPad, an interactive guide for wiring connections, and the Interactive Manual application that provides a linked two-way manual to dynamically learn about the receiver's features.
AV Processing
Pioneer SC receivers utilize proprietary technologies that include Advanced MCACC for accurate automatic room calibration, Auto Phase Control Plus for real time phase matching to analyze the audio input every 30 seconds, PQLS Bit-Stream to help eliminate distortion caused by digital bit-stream timing errors, and Virtual Speaker Modes for simulating sound coming from various areas in a room without actual additional speakers connected. The SC-1522 has been certified with THX Select 2 Plus to ensure it delivers the highest fidelity home entertainment experience.
Portable Device Control
Pioneer's iControlAV2012 App, available at no charge from the App Store on iPhone, iPad, and iPod touch or www.apple.com/itunes/, enables control of power on and off, volume and sound mode settings, and the ability for users to choose and control content from Pandora internet radio, other Internet radio stations, and music files from network-attached storage (NAS) devices on a home network.
The app also includes Sound Explorer, which gives users the ability to set and adjust numerous sound enhancements such as PQLS Jitter reduction, equalizer, standing wave compensation, phase control and auto phase control plus, tone controls, Advanced Sound Retriever (ASR), digital noise reduction, dialog enhancement, X-curve, Hi-Bit 24 and Virtual Modes. See more A/V receivers.
Price and Availability
Pioneer SC-1222 (7.2-channel) A/V Receiver → $1,099
Pioneer SC-1522 (9.2-channel) THX Select 2 Plus A/V Receiver → $1,599
Marantz AV 30 and AMP 30 Promo Shot
Marantz brings the cost of A/V separates down to a more affordable price point with the AV 30 preamp/processor and AMP 30 multi-channel power...
Eversolo SE100 Passive Bookshelf Speakers Lifestyle Eversolo SE100 Passive Bookshelf Speakers Lifestyle
Eversolo’s SE100 passive bookshelf speakers promise big sound from a compact cabinet for $399 a pair, designed for real rooms and modern hi-fi systems.
Edifier M90 Wireless Speakers Lifestyle Gaming in White Edifier M90 Wireless Speakers Lifestyle Gaming in White
Edifier’s M90 is a "cross-scenario, multi-purpose" active speaker, performing equally well in TV and home entertainment setups as well as in PC, desktop, and...
Sylvox Cinema Pro 110-inch Helio QLED Outdoor TV by pool Sylvox Cinema Pro 110-inch Helio QLED Outdoor TV by pool
Sylvox debuts the world’s first frameless outdoor TV at CES 2026, plus a 110-inch 4K QLED model built to survive sun, rain, sports nights,...
Brane Party Pro Portable Speaker at CES 2026 Brane Party Pro Portable Speaker at CES 2026
Brane Audio debuts RAD2 at CES 2026, previewing the Party Pro prototype and a radical new approach to deep bass that could reshape portable...
Audio-Technica AT-LP7X Turntable Audio-Technica AT-LP7X Turntable
Audio-Technica’s AT-LP7X is a $999 fully manual belt-drive turntable with precise speed control, adjustable tonearm geometry, and built-in MM/MC phono support.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Head Units
Pioneer brings Dolby Atmos to Apple CarPlay with its SPHERA in-dash receiver, opening immersive in-car audio to existing vehicles without factory systems.
Premium Audio Company and Pioneer Corporation end their home audio partnership, leaving PAC with Klipsch, Onkyo, Integra, Magnat, and HECO.
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Select Onkyo, Integra and Pioneer A/V receivers add support for Dirac Live Bass Control, Amazon Music HD, TIDAL MAX, Source-based Tone Mapping and Google...
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Priced under $500, Pioneer's refreshed entry-level 5.2-channel and 7.2 channel A/V Receivers add support for 4K/120 and 8K resolution.
Auro 3D, Auro Scene and Auro CX enable spatial audio through A/V receivers, smart speakers and music streaming.
Pioneer-branded TVs are back, but not in the way you think. Find out how Xumo and Best Buy are involved.
