Pioneer S-DJ80X, S-DJ60X, S-DJ50X Active DJ Speakers
Pioneer S-DJ80X Active DJ Speaker
Pioneer today introduced a new line of affordable active DJ speakers designed for aspiring DJs. The DJ speakers are offered in four models, S-DJ80X, S-DJ60X, S-DJ50X and S-DJ50X-W (white) with 8-inch, 6-inch or 5-inch drivers, respectively. Each speaker includes three types of inputs, and built-in equalization, useful for DJs who want to achieve the highest accuracy in sound reproduction.
For maximum audio performance, increased bass output and reduced unwanted resonance, each speaker utilizes a highly rigid medium density fiberboard (MDF) for the construction of its enclosure and bass reflex ducts. Additionally, to optimize sound quality and increase reliability, Pioneer uses woofers made with aramid fiber cones and soft dome tweeters infused in magnetic fluid.
  • Groove Technology: To improve airflow through the port of the enclosure, Pioneer engineered the port hole with grooves to help direct the sound waves smoothly. The technique decreases standing waves from the mouth of the port, resulting in smooth bass and midbass output, with more impact.
  • Convex Diffuser: Matching the bass output of the speakers, the soft dome tweeters are set in the center of a convex diffuser optimizing output and dispersing the sound energy in both left and right directions for wider imaging. For a cool cosmetic look, the diffuser also illuminates in white when the speakers are powered on.
  • Class AB bi-amp: Driving the speakers is a highly efficient Class AB amplifier in a bi-amp configuration to power the tweeters and woofers separately.
  • EQ Controls: The speakers also enable users to adjust high-pass level output via the built-in equalizer from the back of the speaker. The equalizer adjusts the high frequency range in one decibel increments (-2dB to +1dB), tailoring the audio output to the user’s listening preference.
Inputs and Extras
All speaker models feature three types of inputs (XLR, TRS and RCA) for connection to different devices such as DJ equipment, computers, and portable devices. For convenience and power conservation, the speakers also include an Auto Standby mode that automatically turns itself off when there is no input signal sensed after 25 minutes and powers back on when signal input is detected. For more information see: http://www.pioneerelectronics.com/PUSA/DJ/Speakers
Price and Availability
The new Pioneer DJ speakers will be available mid September 2013 at the following prices:
  • Pioneer S-DJ80X (8-inch, black) $249
  • Pioneer S-DJ60X (6-inch, black) $199
  • Pioneer S-DJ50X (5-inch, black) $149
  • Pioneer S-DJ50X-W (5-inch, white) $149
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Select Onkyo, Integra and Pioneer A/V receivers add support for Dirac Live Bass Control, Amazon Music HD, TIDAL MAX, Source-based Tone Mapping and Google...
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Priced under $500, Pioneer's refreshed entry-level 5.2-channel and 7.2 channel A/V Receivers add support for 4K/120 and 8K resolution.
Auro 3D, Auro Scene and Auro CX enable spatial audio through A/V receivers, smart speakers and music streaming.
HDTV 4K & 8K TV
Pioneer-branded TVs are back, but not in the way you think. Find out how Xumo and Best Buy are involved.
Pioneer Elite is back and this A/V receiver packs in everything that you need for your home theater setup.
Dirac Live Bass Control is coming to select Onkyo, Integra, and Pioneer Elite AVRs. The bad news is that it isn't free.
