Loudspeakers
Pioneer S-DJ08 and S-DJ05 Active Reference Speakers
Pioneer today introduced its first line of active reference monitoring speakers, S-DJ08 and S-DJ05, designed for DJing and music production. The two speaker models feature excellent sound quality, audio parameter control, built-in linear equalization and four switchable inputs, useful for DJs and producers who need to achieve the highest accuracy in musical reproduction. In addition, both speaker models offer users the ability to change settings such as sound characteristics and audio inputs via a unique manual controller.
Audio Quality
The compact speakers achieve a larger than normal listening area due to the use of a curved waveguide enclosure that directs the soft-dome tweeter's sound in a wider pattern for better imaging and staging. This means more listeners across a larger area of a room can hear the higher frequencies than with traditional designs. Additionally, the Bass Reflex enclosure extends the lower frequency range to provide more mid-bass and bass output. In order to reproduce the highest quality audio possible, the speakers are also equipped with strong 10 cm high-force magnets (S-DJ08) for better control of the subwoofers, a low resonance chimney-style heat sink and a bi-amp circuit that drives the tweeter and woofer separately.
Whether the speakers are utilized for DJing or producing music, the built-in linear equalizer provides further fine-tuning of sound for all listeners' tastes. The linear equalizer allows users to adjust the low and high bands from -6 dB to +6 dB, helping to enhance the tonal quality of instruments while producing music or recreate the low frequency sound of a club while DJing for a more realistic experience, important for critical listeners.
Control
Unique to Pioneer's DJ speakers, the included control accessory allows users to simultaneously operate the volume, power and four switchable input channels of both speakers. The dial style control knob also engages the equalizer and muting of both speakers.
Inputs and Extras
Both S-DJ08 and S-DJ05 speakers feature four types of inputs (XLR, TRS and two sets of RCA) that let users connect various devices simultaneously, such as a computer, DJ equipment, portable device, etc. The various inputs eliminate the need to change cable connections so the speakers can be utilized with a broad variety of sources.
The speakers also feature an environmentally-friendly Auto Standby feature that automatically detects input signals and switches the standby mode when input is not detected within 60 minutes. For additional functionality, bottom screw holes were implemented for use with commercially available stands.
The S-DJ08 and S-DJ05 will be available in January 2011.
S-DJ08 S-DJ05
Type Bi-amp 2-way powered speakers Bi-amp 2-way powered speakers
Tweeter 2.5 cm soft dome tweeter 2.5 cm soft dome tweeter
Woofer 8 inches 5 inches
Frequency Characteristics 43 Hz to 26 kHz (-10 dB) 50 Hz to 25 kHz (-10 dB)
Balanced input terminals XLR x 1
TRS (1/4 inch PHONE) x 1
XLR x 1
Unbalanced input terminals RCA x 2 RCA x 2
Maximum external dimensions (W x H x D) 9.84 in × 15.39 in × 14.61 in
(including heat sink)
7.28 in × 11.85 in × 10.16 in
Weight (for pair) 59.52 lbs (pair) 29.54 lbs (pair)
Accessories Controller × 1
Link cable x 1
Power cables x 2
Rubber feet x 8
Controller x 1
Link cable x 1
Power cables x 2
Rubber feet x 8
MSRP $1,199/pair $899/pair
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
