Car Amplifiers
Pioneer PRS-D800 Car Amplifier
Pioneer Electronics announced the reference quality PRS-D800 Class D 2-Channel Full-range amplifier, which features design elements and superior componentry from Pioneer's Stage 4 ultra high-end car listening system, bringing superior sound quality to a broader range of consumers and vehicles.
The PRS-D800 is a Full-range Class D, bridgeable 2-channel amplifier. The product is unique due to its high power, high sound quality, compact size, and the fact its chassis has been optimized for use as a part of a modular or building block amplifier system. The PRS-D800 is only 10-inches long by 4-1/8 inches wide by 2-inches tall, and has been designed to fit side by side or even stacked with other PRS-D800 amplifiers. Producing a substantial 125 watts per channel into 4 ohms stereo or 300 watts into 4 ohms bridged mono, the applications for this amplifier can be by itself or with multiple units.
High power output and small size aren't the only special features of the PRS-D800. To complement the reference level sound quality of the DEH-80PRS receiver, the PRS-D800 amplifier employs high performance internal components.
Features
  • A high-slew rate operational amp is used to reduce the high-frequency distortion inherent to many Class D full range designs.
  • Handpicked, matched electrolytic capacitors to obtain consistent frequency response and high dynamic range.
  • Oxygen-free copper wire inductors for low direct current resistance and low loss that results in strong, tight bass response and clean mid and high frequency output.
  • Chassis construction that features Pioneer's Total Vibration Control (TVC) concept that utilizes anti-vibration materials and advanced structural engineering to eliminate audible distortion caused by microscopic component resonances.
  • The PRS-D800 has a rated frequency response from 10 Hz to 30 kHz with total harmonic distortion (THD) of .004% (1 kHz) and a signal-to-noise ratio of greater than 105 dB.
Price and Availability
The Pioneer PRS-D800 will be available in April 2012 for $300.
1 Comment
1 Comment
  1. Martin
    July 3, 2012 at 5:30 am
    Nice one Post about Pioneer PRS-D800 Car Amplifier.
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Select Onkyo, Integra and Pioneer A/V receivers add support for Dirac Live Bass Control, Amazon Music HD, TIDAL MAX, Source-based Tone Mapping and Google...
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Priced under $500, Pioneer's refreshed entry-level 5.2-channel and 7.2 channel A/V Receivers add support for 4K/120 and 8K resolution.
Auro 3D, Auro Scene and Auro CX enable spatial audio through A/V receivers, smart speakers and music streaming.
HDTV 4K & 8K TV
Pioneer-branded TVs are back, but not in the way you think. Find out how Xumo and Best Buy are involved.
Pioneer Elite is back and this A/V receiver packs in everything that you need for your home theater setup.
Dirac Live Bass Control is coming to select Onkyo, Integra, and Pioneer Elite AVRs. The bad news is that it isn't free.
