Pioneer HDJ-C70 On-Ear DJ Headphones
Pioneer HDJ-C70 Headphones
Pioneer today introduced the $240 HDJ-C70 professional on-ear headphones intended for DJs who prefer a headset that is lightweight, extremely flexible, and can produce audio with more impactful bass and clear mid and high frequencies. The new HDJ-C70 model sets itself apart from other Pioneer HDJ offerings with the use of smaller, more compact ear cups, rotatable arms, interchangeable parts, and a minimalistic cosmetic look.
Sound Quality
The HDJ-C70 utilizes large 40mm drivers specially tuned to produce the lower bass frequency region in music. The combination of large 40mm drivers, copper-clad aluminum wire (CCAW) voice coils, neodymium magnets, and 2,000 mW input capacity helps to generate clean and clear audio output with increased bass response.
Sound Isolation
The new headphones are also designed to help minimize loud background noise, often found in loud environments such as a DJ booth, by utilizing a special sound-isolation “air chamber” integrated into the housing of the earpiece. The innovative air chamber also helps to isolate low and mid frequencies resulting in better defined mid-bass/mid-range sound output.
Comfort and Fit
The headband of the HDJ-C70 is made of a polyamide resin for maximum flexibility, to accommodate the constant pulling and twisting of the headphones by users. The ear cup housing also utilizes a ridged rubber ring for improved grip of the headphones and reduced chances of slipping.
For ultra-comfortable wear and to fit different head sizes the ear cups of the HDJ-C70 are designed to move vertically along the slider arms, offering a total of 15 different positions. Furthermore, the slider arms can be rotated up to 90 degrees in each direction, providing the greatest flexibility for different styles of DJing.
The model incorporates soft, extremely comfortable low-resilience urethane memory foam ear pads to create a nice seal around the ears, which also helps in reducing external sounds. The urethane memory pads are wrapped in soft black leather for maximum feel and extended comfort.
Interchangeable Parts
Furthermore, the HDJ-C70 features interchangeable parts for greater longevity. The headband, earpads, housing, cushion and cables can be removed and replaced (parts sold separately). The headphones are pre-installed with a 1.6m straight cord that can also be swapped with a 1.0m coiled cord (included). A compact carrying pouch for added protection and convenience comes with the unit.
Price and Availability
The Pioneer HDJ-C70 headphones will available in October 2014 for $239.
Specifications:
Form Fully enclosed dynamic stereo headphones
Frequency range 7 ~ 32,000 Hz
Impedance 40 Ω
Output sound pressure level 100 dB
Maximum output sound pressure level 120 dB
Maximum input 2,000 mW
Unit aperture
φ 40 mm dynamic type
Connection cord
5.1 feet stereo cable, 3.25 feet coiled cable (9.8 feet when extended)
Plug
φ 3.5 mm stereo mini plug
Weight 6.9 ounces (not including cord)
Accessories ¼-inch stereo adapter plug (screw-type), carry case, screwdriver for cord replacement
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Select Onkyo, Integra and Pioneer A/V receivers add support for Dirac Live Bass Control, Amazon Music HD, TIDAL MAX, Source-based Tone Mapping and Google...
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Priced under $500, Pioneer's refreshed entry-level 5.2-channel and 7.2 channel A/V Receivers add support for 4K/120 and 8K resolution.
Auro 3D, Auro Scene and Auro CX enable spatial audio through A/V receivers, smart speakers and music streaming.
HDTV 4K & 8K TV
Pioneer-branded TVs are back, but not in the way you think. Find out how Xumo and Best Buy are involved.
Pioneer Elite is back and this A/V receiver packs in everything that you need for your home theater setup.
Dirac Live Bass Control is coming to select Onkyo, Integra, and Pioneer Elite AVRs. The bad news is that it isn't free.
