Pioneer HDJ-500T-K Headphones
Pioneer has introduced the HDJ-500T-K multi-functional entry level DJ headphones that can be used for DJing, leisure music listening and now hands-free calling. The new HDJ-500T-K includes two interchangeable cords: a coiled cord for DJ purposes and a straight cord with an integrated microphone that enables users to answer incoming calls when connected to a smartphone.
Versatility
The HDJ-500T-K DJ headphones include two interchangeable cords: a coiled cord and a 1.2 meter straight cord with a microphone and phone answer button. The traditional 1.2 meter coiled cord (extends to 3m) is ideal for regular DJ performances, while the 1 meter straight cord is perfect for leisure listening when connected to a smartphone music device, and can also answer incoming calls with a simple touch of a button.
For maximum flexibility during performances, the HDJ-500T-K features a rotating arm structure that allows the user to rotate the right earpiece forward and back by as much as 60 degrees. At that position, the flexible headband maintains enough side pressure to allow the DJ to listen to audio on just one side of the headphones.
The Sound Difference
The HDJ-500T-K adapts the same great sound quality found in Pioneer's current HDJ-500 line of headphones. It provides clear audio reproduction, enhancing the critical low and mid frequency ranges that are essential for remixing. With a 40 mm diameter driver, thick 19 µm (micrometers) diaphragm and a copper clad aluminum wire (CCAW) voice coil, the headphone can efficiently reproduce the lower frequency audio range such as snare and kick drum sounds, which can be easily distinguished to make matching the tempo of tracks easier, even for novice DJs.
Refined Design
The HDJ-500T-K DJ headphones offer similar styling and performance design cues as Pioneer's top-of-the-line HDJ-2000 headphones. Designed with maximum comfort and reliability in mind, the HDJ-500T-K uses comfortable urethane pads for the ears that allow the headphones to mold around the user's head and ears for a snug and slip-resistant fit. Furthermore, the urethane pads are wrapped in high quality leather, providing greater comfort and extended wear. The main structure of the headphones is crafted with magnesium alloy for light weight and durability, making them ideal for travel and long periods of use.
Specifications
Style: Fully enclosed dynamic stereo headphones
Frequency Range: 5Hz–28,000Hz
Impedance: 45Ω
Max Input: 2000 mW
Output Sound Level: 105 dB
Driver Unit: 40 mm dia. dome type
Plug: 3.5 mm dia. 3P mini-plug (gold-plated, screw-in)
3.5 mm dia. 3P mini-plug (gold-plated) for straight cord
Weight: 6.8 ounces (without cord)
Included Cords: 1.2 m side mount coil cord (extends to 3 m)
1 m straight cord with microphone
6.3 mm dia. 3P plug adapter (gold-plated, screw-in)
Price and Availability
The Pioneer HDJ-500T-K DJ headphones in black are available in May for $145.
QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Topping E50 II DAC on Desktop Topping E50 II DAC on Desktop
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
AZLA TRINITY Earphones USB-C Version AZLA TRINITY Earphones USB-C Version
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
WiiM Sound Lite Smart Speaker in white WiiM Sound Lite Smart Speaker in white
WiiM's original smart speaker sheds features to hit a lower price point ($229) for those who can live without a touch display and voice...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Premium Audio Company and Pioneer Corporation end their home audio partnership, leaving PAC with Klipsch, Onkyo, Integra, Magnat, and HECO.
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Select Onkyo, Integra and Pioneer A/V receivers add support for Dirac Live Bass Control, Amazon Music HD, TIDAL MAX, Source-based Tone Mapping and Google...
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Priced under $500, Pioneer's refreshed entry-level 5.2-channel and 7.2 channel A/V Receivers add support for 4K/120 and 8K resolution.
Auro 3D, Auro Scene and Auro CX enable spatial audio through A/V receivers, smart speakers and music streaming.
Pioneer-branded TVs are back, but not in the way you think. Find out how Xumo and Best Buy are involved.
Pioneer Elite is back and this A/V receiver packs in everything that you need for your home theater setup.
