Pioneer Elite VSX-31 A/V Receiver
7.1-Channel 3D Ready Elite A/V Receiver
  • Made for iPhone® Certified
  • iControlAV App for iPhone / iPod® Touch free on the App Store
  • HDMI® (V.1.4a with 3D) 5 Inputs (Including 1 Front Input) / 1 Output
  • Anchor Bay® Video Scaler
  • THX® Select2 Plus Processing & Certification
  • Ethernet Input for Access to Thousands of Internet Radio Stations
  • 2 Zone Multi-zone & Source (Analog Audio & Video Out for Zone 2)
Suggested Price: $650.00
The VSX-31 “Made for iPhone” certification, allows you to enjoy music with iTunes® album art, movies, downloaded TV shows from iTunes, photos, and more. An included USB/composite video cable makes connecting your iPhone to share your favorite media easy–and your iPhone charges automatically when connected. This included cable also works with most generations of iPod Classic, Nano, and iPod touch.
Pioneer's iControlAV (a free download from Apple's App Store) gives you total control over your home theater sound. With controls for master and per-zone volume, sound fields, and more, you've got a simple but powerful way to adjust your home theater sound any way you like.
Pioneer Elite VSX-31 A/V Receiver - Rear
In addition to connections for all your home theater components, a front HDMI input lets you conveniently connect high-definition devices like an HD camcorder to view your videos in all their glory in your home theater. A front USB port lets you connect your digital camera or portable media player to display a slideshow of JPEG photos on your HDTV, or play MP3, WAV, or WMA music files with full ID3 tag and album art support. Elite receivers will display up to 32 album art thumbnails on your TV, and you can scroll through them with the included remote. And your options don't stop with your portable devices. When connected to a home network, the VSX-31 is your portal for thousands of Internet radio stations — all just a few clicks of the remote away.
Where the VSX-31 truly shines is with custom control options. Full custom feature-sets including 2-zone audio and video as well as partnerships with 3rd party controllers like Control4, Crestron and AMX ensure compatibility with the latest home automation technologies.
Product Sheet (pdf)
Owners Manual (pdf)
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
