Pioneer Elite SC-95, SC-97, SC-99 A/V Receivers
Pioneer Elite SC-99 A/V Receiver - Front with Remote
Pioneer today announced the release of their top-of-the-line Elite A/V receivers: the SC-99 ($2,500), SC-97 ($2,000) and SC-95 ($1,600).  Feature-rich and packed with the sort of audio and video horsepower that is the hallmark of the Elite series, the new receivers are Dolby Atmos-enabled and compatible with DTS:X so owners can submerse themselves in 360 degrees of surround-sound. There is very little that separate these high-end products from each other. They all look the same and have the same remote.  There is a small wattage difference, but mainly the most expensive SC-99 adds a USB DAC and beefier power supply, while both the SC-97 and SC-99 add Air Studios certification.
All three models are based upon Pioneer’s Multi-Channel Stereophonic Philosophy, which concept is all adjacent channels should be stereophonic, and are incorporated high power, accurate calibration and professional sound tuning design
Powerful Amps
All three receivers feature Class D3 amplifiers which enable high-power output across all channels simultaneously for deeper and more powerful sound: SC-99 9-channel 850W; SC-97 9-channel 810W, and SC-95 9-channel 760W.
Advanced Audio
Each unit features MCACC Pro automatic acoustic correction technology that corrects temporal reverb and phase characteristics. This is an ideal solution for object-based audio playback as it faithfully reproduces three dimensional audio mixes as they were originally intended. In addition, the dual subwoofer EQ correction feature enhances the ability to reproduce deep bass, producing the ideal sound field for multichannel playback.
A Full Band Phase Control feature measures and corrects the lag between low-pitched and high-pitched sounds and differing phase characteristics between channels, while the Auto Phase Control Plus feature provides real-time, fully automatic compensation for phase difference in low frequency effects.
Uncompromising Sound Design
No detail is overlooked as each AV receiver achieves high-fidelity playback through the use of dedicated audio components and specialized sound-quality tuning.
Low ESR custom capacitors, PLU MU capacitors created in conjunction with Rubicon Corp and the NJM4585 Op Amp by JRC all combine to create a high signal to noise ration with low distortion and high resolution across a wide bandwidth.
The employment of two SABRE32 Ultra DAC (ES9016S) units from ESS Technology produce world-class dynamic range, low jitter and low distortion ensuring the capabilities of the Class D3 amplifier are utilized to their fullest extent.
Finally, a thorough commitment to sound-quality measures even in the smallest details via the use of a new Anti-Standing Wave Insulators that are designed to inhibit not only vibration but standing wave occurring in the insulators. The employment of a Low Leakage Flux Power Transformer in the SC-99 reduces magnetic flux noise and boosts the signal-to-noise ratios.
Pioneer Elite SC-95 A/V Receiver - Back
Pioneer Elite SC-95
Pioneer Elite SC-97 A/V Receiver - Back
Pioneer Elite SC-97
Pioneer Elite SC-99 A/V Receiver - Back
Pioneer Elite SC-99
Certified by AIR Studios
The Elite SC-99 and SC-97 have been certified at London’s legendary AIR Studios whose work is respected worldwide for award-winning, motion picture soundtracks and peerless digital CD recordings. AIR Studios understands the artist’s craft, and like Pioneer, believes that faithfully reproducing what the artist originally created in the studio is the critical objective of the finest home theater system.
Astounding Visual Acuity
Each AV receivers supports 4K/60P/4:4:4/24-bit video signals, with HDCP 2.2 copyright protection and the latest High Dynamic Range (HDR) signals for connecting with the latest 4K Ultra HD displays and sources.  Super Resolution, a 4K Ultra HD technology derived from the development of the Elite BDP-88FD/85FD, has been incorporated into these AV Receivers, and allows 4K video signals to be even more detailed, natural and realistic.
Wirelessly Connect
All 2015 Elite models offer built-in Wi-Fi and Bluetooth wireless technology and are equipped with dual antennas that provide Dual Band Wi-Fi (2.4 GHz and 5 GHz) for greater network range and connection stability. Elite models support Wireless Direct and even in an environment without a network can be operated using the free iControlAV5 control app.
With AirPlay compatibility, these Elite AV Receivers let you enjoy effortless streaming music from iPhone, iPad or iPod touch.  In addition, the Elite AV Receiver is Windows 8.1 certified and supports DLNA 1.5 media streaming and HTC Connect.
Custom-Installation
These three new Elite AV Receivers offer both RS-232c interface and full IP control providing compatibility with the most popular home automation systems. For custom-installed home theater solutions, all models offer multi-zone AV capability: home theater in one room; HDZONE (HDMI) to a second room and analog music in a third room.
However you choose to use it, these receivers give you the features and flexibility that come with owning an Elite AV receiver. And because Pioneer is dedicated to custom installation, our relationships with custom-control providers like AMX, Control4, Crestron and other leading brands makes the Elite AV Receiver the perfect centerpiece for whole-house systems.
Worldwide Music
With Internet Radio, the Elite AV Receiver gives you a world of entertainment options. You can enjoy thousands of Internet radio stations around the world with vTuner, or access your favorite music from Pandora and Spotify, complete with on-screen album art and music information.
Price and Availability
Pioneer Elite SC-99: $2,500 (available now)
Pioneer Elite SC-97: $2,000
Pioneer Elite SC-95: $1,600
1 Comment
1 Comment
  1. jz
    October 31, 2015 at 8:29 pm
    Cannot wait for Audiocraft in Strongsville, Ohio to bring this receiver to my home and install. They are also wiring up my living room for surround sound, mounting surround speakers on the wall and doing initial setup. fun, fun, fun. Jerry Z
Pro-Ject Audio CD Box RS2 Tube Silver CD Player
CD Players
Pro-Ject’s CD Box RS2 Tube doubles down on Red Book CDs with a balanced tube stage—no SACD, no digital inputs, and a $2,300 price...
Backert Labs Optik Phono 1.1 Backert Labs Optik Phono 1.1
Backert Labs’ $11,500 Optik Phono 1.1 targets DS Audio optical cartridges and five-figure turntables—impressive at shows, uncompromising in design, and firmly not for casual...
2026 Samsung Music Studio Series Speakers 2026 Samsung Music Studio Series Speakers
Samsung will preview its 2026 audio lineup at CES, highlighting new Q Series soundbars, Music Studio Wi-Fi speakers, Q Symphony integration, and Sound Towers...
HumminGuru EZ Record Washer Package HumminGuru EZ Record Washer Package
HumminGuru’s EZ Vinyl Record Washer targets Spin-Clean with a more refined manual cleaner—effective, easy to use, and price will determine its appeal.
Hisense PX4-PRO UST Projector Hisense PX4-PRO UST Projector
Hisense previews the PX4-PRO UST projector ahead of CES 2026, promising 200-inch images, higher brightness and contrast, built-in Atmos audio, and a flexible alternative...
Hisense XR10 High-end Lifestyle 4K Laser Projector Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
The Case for Audio/Video Receivers (AVRs) While soundbars have evolved over the years and can provide a convenient solution to better TV sound, nothing beats a...
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
Find out everything the HEOS app can do to simplify and manage a whole-home audio system with Denon and Marantz gear.
The Anthem MRX SLM delivers high-end performance in an ultra-slim AVR built for CI installs and small rooms, though limited power and inputs may...
Phil Jones from Harman reveals what makes Denon and Marantz A/V receivers unique to help you decide which model is right for your home...
Compare Denon and Marantz AVRs for 2025—explore features, performance, and prices to find the best home theater receiver for your setup, from budget to...
Dirac Live Active Room Correction for select Denon and Marantz A/V Receivers and Preamp/Processors is now available for $299 extra.
The new Marantz CINEMA Series A/V Receivers have arrived at CEDIA 2022 and we're already taking the doors off of our media cabinet.
