Pioneer DJM-T1 Digital Mixer
Pioneer introduced the DJM-T1, a high performance 2-channel digital mixer featuring the TRAKTOR SCRATCH 2 DJ software. The DJM-T1 features the TRAKTOR software, high quality audio, improved fader durability and an internal USB soundcard that eliminates the need to connect an external controller or soundcard.
The DJM-T1 offers the same high sound quality design elements developed and featured throughout Pioneer's existing DJM-series mixers giving DJs the confidence that they're getting the highest performance and the best sound quality for their investment. The DJM-T1 allows setup in an instant so the DJ can get straight to performing.
Key Features:
  • TRAKTOR Series Control — The DJM-T1 is equipped with a controller function for the TRAKTOR series, allowing users to directly access TRAKTOR's software features without the need for an additional external controller or soundcard. To find tracks and mix smoothly without ever having to leave the mixer's control panel, controls for Browse (song selection) and Transport (play, fast forward, rewind, etc.) are conveniently located on the upper section of the mixer. Performance controls such as Effect, Loop, Hot, Cue, Sampler are conveniently located on the left and right side of the mixer, providing the same look of TRAKTOR's popular graphical user interface (GUI) for quick and accurate software operation. Each button on the mixer is designed to illuminate in sync with TRAKTOR, allowing the user to view the status of the software directly on the mixer and reducing the need to look up at the PC/Mac.
  • Scratch Control Capability — The DJM-T1 is a TRAKTOR SCRATCH CERTIFIED mixer allowing connectivity and operation with the TRAKTOR SCRATCH 2 software for ease of use. For DJs who prefer to use their own DJ turntables, the mixer comes with a CONTROL CD or CONTROL VINYL option, enabling it to be used as a TRAKTOR SCRATCH controller for scratching functions on their own equipment. In addition, the included TRAKTOR SCRATCH DUO 2 software let DJs start using the product right out of the box.
  • High Quality Faders — Pioneer integrated new channel faders and crossfaders that feature a slide construction supported by two metal shafts for the fader knobs. The new faders provide a smooth, consistent operation, with nearly three times the durability of previous generations of Pioneer mixers. The design also better protects the faders from the harmful effects of accidental liquid spills and/or dust that might otherwise collect inside these controls. The DJM-T1's crossfader utilizes a magnetic construction, exclusive to Pioneer, that offers extremely high durability, enabling it to withstand more than 10 million operations. The operational load, fader curve, and cut lag can also be adjusted to the user's personal preference.
  • Clean and Powerful Audio Outputs — The DJM-T1 inherits the high sound quality design features found in all of Pioneer's DJM series of products. The mixer features separated analog and digital circuitry to reduce noise. Analog signals are converted to digital in the shortest possible distance to reduce the chance of induced noise. To achieve clear and powerful audio outputs, Pioneer employed a high quality digital/analog converter for both the Master and Booth outputs.
  • Internal USB Soundcard — The DJM-T1 is equipped with an internal USB soundcard that enables the user to connect directly to a PC/Mac with a single USB cable. DJs can use the configuration utility tool installed on a PC/Mac to change the output signal from six points of the mixer based on the user's individual preference including DJing, recording, or production. The included TRAKTOR SCRATCH DUO 2 software enables them to easily record their performances from various output points with the ability to apply additional effects (i.e. Effect, Loop, etc.) to the original arrangements.
Additional Features:
  • Microphone and auxiliary inputs located on the front of the mixer
  • Improved grip with rubber knobs for ISOLATOR/EFFECT/LOOP volume controls
  • Multi-input selector for switching between CD/PHONO/USB inputs
  • Three-band isolator type equalizer for a wide range of level control from +6 dB to ∞ (cut) for HI/MID/LOW ranges individually
  • MIDI signal output enable fader/isolator operation data for transmitting to external devices
  • LFO CONTROL outputs MIDI signal that changes at beat-by-beat intervals for precision control
  • “P-LOCK Fader Cap” locking mechanism on channel fader and crossfader knobs designed to prevent fader caps from slipping.
  • Auto Standby automatically recognizes the current state of operation and input signal, switching the power to standby mode when no activity or input is detected for a period of time
  • Booth output volume control
Specifications
No. of channels 2 channels
Input terminals CDx2 (RCA), PHONO x2 (RCA), AUX x1 (RCA), MIC x1 (XLR & 1/4 inch PHONE x1)
Output terminals MASTER OUT x2 (RCA x1, XLR x1)
BOOTH OUT x1 (1/4 inch PHONE)
HEADPHONE MONITOR OUT x1 (1/4 inch PHONE x1)
Other terminals USB type B Port x1
Sampling rate 48 kHz
D/A converter 24-bit
A/D converter 24-bit
Frequency characteristics 20 Hz to 20 kHz
Total harmonic distortion Less than 0.004%
S/N ratio More than 106 dB (CD)
Headroom 19 dB
Power source 120 V AC (60 Hz)
Power consumption 23 W
Maximum dimensions 10.4 in (W) x 15.9 in (D) x 4.3 in (H)
Unit weight 13.5 lbs
Price and Availability
The DJM-T1 will be available in July with a suggested retail price of $1,899.
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Select Onkyo, Integra and Pioneer A/V receivers add support for Dirac Live Bass Control, Amazon Music HD, TIDAL MAX, Source-based Tone Mapping and Google...
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Priced under $500, Pioneer's refreshed entry-level 5.2-channel and 7.2 channel A/V Receivers add support for 4K/120 and 8K resolution.
Auro 3D, Auro Scene and Auro CX enable spatial audio through A/V receivers, smart speakers and music streaming.
HDTV 4K & 8K TV
Pioneer-branded TVs are back, but not in the way you think. Find out how Xumo and Best Buy are involved.
Pioneer Elite is back and this A/V receiver packs in everything that you need for your home theater setup.
Dirac Live Bass Control is coming to select Onkyo, Integra, and Pioneer Elite AVRs. The bad news is that it isn't free.
