Pioneer DJM-850 Performance DJ Mixer
Pioneer announced the DJM-850 performance DJ mixer featuring a built-in high-performance USB sound card, various functions for laptop-connected DJ performances, and the industry’s first BEAT COLOR FX function, which changes effects by linking the audio input of each channel.
Variety of Effects
Inheriting technology from their DJM-900nexus mixer, the DJM-850 follows Pioneer’s traditional mixer layout, featuring a variety of advanced sound effects that provide DJs with virtually limitless possibilities when mixing their music. Pioneer includes a new BEAT COLOR FX function, which changes effects by linking the audio input from each channel.
  • Sound Color FX — The Sound Color FX offers four types of effects (Filter, Crush, Noise and Gate) that can be linked to the input sound of each channel.
  • Beat Color FX — Users can quickly change between the new Beat Color FX and Sound Color FX to suit each tune for further remixing and sound capabilities. By activating the Beat Color FX, users are able to manipulate the Sound Color FX and Beat Effect simultaneously, resulting in more creative effects that complement the beat of the music.
  • Beat Effect — The Beat Effect function presents 13 different types of effects (Delay, Echo, Up Echo (new), Spiral, Reverb, Trans, Filter, Flanger, Phaser, Robot, Slip Roll, Roll, and Reverse Roll) that can be combined to produce up to 100 other original effects.
Sound Quality
The design of the DJM-850 combines broad functionality and high quality components to achieve great sound quality:
  • 24bit/96kHz Built-in USB Sound Card — An integrated high performance USB sound card enables up to four inputs/outputs simultaneously with no deterioration in sound quality.
    • The sound card supports three different sampling rates (96kHz/48kHz/44.1kHz) and the ASIO/Core Audio standards that can also be used for music recording and production.
    • The USB port on top of the mixer provides quick connections to use DJ software via laptop. The signal output path from the mixer can be easily modified using its setup utility tool3 via a computer.
  • Sound Quality — The use of high quality components such as a 32-bit digital-to-analog output converter and a 32-bit digital signal processor, separate analog and digital circuitry, and extremely short audio transmission paths results in clear and powerful audio output.
TRAKTOR SCRATCH 2 Certified
The DJM-850 offers compatibility to the Scratch Control (DVS) with Native Instrument’s TRAKTOR SCRATCH PRO 2/DUO 2 software. Using the timecode disc bundled with the software and a PC, the DJM-850 is ready for scratch control (DVS) with a CDJ player or Vinyl turntable.
Additional Features
The DJM-850 is equipped with additional features that add to the versatility of the mixer:
  • MIDI Signal – Operation information of the mixer’s knobs and buttons can be transmitted as a MIDI signal for a “Full Ensemble MIDI” function to control other connected devices.
  • Switching 3-Band EQ/Isolator — Each channel of the mixer is equipped with a switchable 3-band EQ (+6dB to -26dB) and 3-band isolator (+6dB to -∞dB)
  • High Performance Channel Faders — The slide mechanism supports the fader knobs with two metal shafts for both durability and smooth operation. Furthermore, the new mechanism’s design minimizes the negative effects of moisture and dust particles on the mixer’s performance.
  • P-LOCK Fader Cap — Keeps the fader channel and crossfader knobs (caps) locked, preventing them from physically slipping off during heavy use.
  • Scratch Control — Scratch control is possible by using the time code disc bundled with DJ software supporting DVS (Digital Vinyl System) from CDJ players and vinyl turntables.
  • Auto Standby — Automatically senses active operation and the presence of input signals, switching to standby mode when inputs are not detected for a long period.
Price and Availability
The Pioneer DJM-850 will be available in black or silver colors in March 2012 for $1,999.
Specifications
No. of channels Audio: 4, Mic: 2
Inputs CD/LINE x 4 (RCA), LINE x 2 (RCA), PHONO x 2 (RCA)
MIC x 2 (XLR & 1/4 inch PHONE combined use x 1, 1/4 inch PHONE x 1)
Outputs MASTER OUT x 2 (RCA x 1, XLR x 1)
BOOTH OUT x 1 (1/4 inch PHONE)
HEADPHONE MONITOR OUT x 1 (top side 1/4 inch PHONE)
REC OUT x 1 (RCA)
DIGITAL OUT x 1 (COAXIAL)
Other ports SEND X 1 (1/4 inch PHONE), RETURN x 1 (1/4 inch PHONE)
MIDI OUT x 1 (5P DIN), USB x 1 (top side B port), CONTROL x 4 (3.5 mm MINI JACK)
Sampling rate 96kHz/48kHz/44.1kHz
D/A converter 32 bit
A/D converter 24 bit
Frequency response 20 Hz – 20 kHz
Total harmonic distortion 0.004% or less
S/N ratio Min. 106 dB (LINE)
Head-room 19 dB
Power use 120 V AC (60 Hz)
Electricity consumption 30 W
Max. external dimensions 12.6″ (W) x 15.0″ (D) x 4.25″ (H)
Weight 17 lbs.
Vertere DG-X Turntable Red
With a precision main bearing, cutting-edge motor drive, and advanced Groove Runner X Tonearm, the DG-X delivers unparalleled sound clarity and resonance elimination. Explore...
Campfire Audio Axion IEM Connected USB-C with Controller Campfire Audio Axion IEM Connected USB-C with Controller
Earbuds & In-Ear Headphones
Offering premium sound quality, USB-C connectivity with a DAC, and seamless integration with iPhones and Android smartphones, the Axion IEMs are Campfire Audio's most...
Rotel DX-5 Integrated Amplifier Silver Front Angle View Lifestyle Rotel DX-5 Integrated Amplifier Silver Front Angle View Lifestyle
At $1,499, the Rotel DX-5 is a compact sized 25-watt per channel stereo integrated amplifier with Bluetooth, HDMI-ARC and Roon.
Wattson Audio Madison Power Amplifier Front Wattson Audio Madison Power Amplifier Front
Discover the new Madison Power Amplifier from Wattson Audio — a Swiss-engineered Class A/B amp delivering rich harmonics, ultra-low distortion, and dynamic performance in...
WiiM Voice Remote 2 with components lifestyle WiiM Voice Remote 2 with components lifestyle
With WiiM's continuing quest to improve the music listening experience, the upgraded Voice Remote 2 improves control for WiiM devices.
Sharp TIVO TV Lifestyle Man View Sharp TIVO TV Lifestyle Man View
HDTV 4K & 8K TV
Would you buy a 55-inch Sharp 4K TV with built-in TiVo for $299.99? Let's take a look at what it offers.
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Select Onkyo, Integra and Pioneer A/V receivers add support for Dirac Live Bass Control, Amazon Music HD, TIDAL MAX, Source-based Tone Mapping and Google...
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Priced under $500, Pioneer's refreshed entry-level 5.2-channel and 7.2 channel A/V Receivers add support for 4K/120 and 8K resolution.
Auro 3D, Auro Scene and Auro CX enable spatial audio through A/V receivers, smart speakers and music streaming.
HDTV 4K & 8K TV
Pioneer-branded TVs are back, but not in the way you think. Find out how Xumo and Best Buy are involved.
Pioneer Elite is back and this A/V receiver packs in everything that you need for your home theater setup.
Dirac Live Bass Control is coming to select Onkyo, Integra, and Pioneer Elite AVRs. The bad news is that it isn't free.
