Earbuds & In-Ear Headphones
Pioneer DJE-1500 and DJE-2000 In-Ear Headphones
Pioneer DJE-2000 In-Ear DJ Headphones
Pioneer just announced the DJE-1500 and DJE-2000 enclosed inner-ear headphones, designed and sound-tuned for DJs as well as leisure music listening. Both models have unique design features including large high quality 9.4 millimeter drivers, replaceable and detachable cables, and interchangeable earphone tips that dampen external noise.
The more expensive DJE-2000 (pictured above) is designed with a “hybrid” 2-way driver system for producing clear and more precise audio quality throughout the entire frequency spectrum. With the use of rare and powerful magnets for its speakers, the larger 9.4 mm driver located in the back of the earphone produces low bass frequencies with impact, while the front driver efficiently generates critical mid and high frequencies so key instrumental sounds DJs pay close attention to, such as snare drums and cymbals, are more pronounced.
Pioneer DJE-1500 In-Ear DJ Headphones
DJE-1500
The lower priced DJE-1500 utilizes a large 9.4 mm driver and CCAW voice coil reinforced by a powerful magnet for efficient production of a wide frequency range for different types of music listening. The diaphragm of the speaker is made of a ceramic powder coating composite designed to reduce internal vibration that can cause distortion to be induced into the original music content.
Both inner-ear headphones include a detachable MMCX connector for maximum versatility. The cable is applied with a special textile coating that improves durability and reduces tangling and twisting.
Price and Availability (April 2014)
Pioneer DJE-1500 → $189
Pioneer DJE-2000 → $359
Networking
In-Wall Speakers
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Select Onkyo, Integra and Pioneer A/V receivers add support for Dirac Live Bass Control, Amazon Music HD, TIDAL MAX, Source-based Tone Mapping and Google...
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Priced under $500, Pioneer's refreshed entry-level 5.2-channel and 7.2 channel A/V Receivers add support for 4K/120 and 8K resolution.
Auro 3D, Auro Scene and Auro CX enable spatial audio through A/V receivers, smart speakers and music streaming.
HDTV 4K & 8K TV
Pioneer-branded TVs are back, but not in the way you think. Find out how Xumo and Best Buy are involved.
Pioneer Elite is back and this A/V receiver packs in everything that you need for your home theater setup.
Dirac Live Bass Control is coming to select Onkyo, Integra, and Pioneer Elite AVRs. The bad news is that it isn't free.
