Pioneer DDJ-WeGO DJ Controller
Pioneer DDJ-WeGO
Pioneer’s versatile entry-level DJ controller, the DDJ-WeGO, currently bundled with the “Virtual DJ Limited Edition” software by Atomix Productions, now supports Serato DJ Intro and Algoriddim’s djay DJ software — downloadable at no cost. Serato DJ Intro offers the “all familiar” Serato user interface and mixing and scratching functionalities, allowing users the freedom to manage and create non-stop mixes. The combined DDJ-WeGO and Serato DJ Intro software gives users access to large and colorful waveforms on a laptop monitor, and helpful illumination and multi-color LDF jog lights directly on the controller to help improve a DJ’s mixing and scratching capability and enhance the DJ performance. The djay software, available exclusively for Mac, utilizes the user’s iTunes music library to simplify the music mixing experience and provides basic DJ functions such as scratching and mixing, an Auto Mix feature for seamless playback of music without interruption, and an intuitive graphical user interface (GUI) that rotates the album artwork of the music being played.
Pioneer DDJ-WeGO - top
For additional flexibility and more advanced features that can be utilized with the DDJ-WeGO, users can also upgrade to Serato DJ, a paid version of the software. With this software, users can record their sets and mix up to four decks at a time, increasing the ability to perform more complex music mixing.
Pioneer’s DDJ-WeGO DJ controllers make it easy for beginners to learn how to mix with built-in effects and features:
  • Jog FX – Allows users to combine multiple effects and control them simultaneously using the Jog wheel.
  • Pulse Control – Provides users visual prompts with a variety of colored lights on the Jog platters:
    • Mix Pulse – The mix pulse mode shows the difference in pitch of songs currently playing through the light of the Jog wheel. As the pitch of songs begin to match, the intensity of the light increases, allowing the user to check visually that the beats are in sync. In conjunction with the music, the pulse of lights helps to improve beat matching skills Jog wheel. As the pitch of songs begin to match, the intensity of the light increases, allowing the user to check visually that the beats are in sync. In conjunction with the music, the pulse of lights helps to improve beat matching skills.
    • Launch Pulse – Triggers a red light on the Jog wheel to signify that music has been loaded successfully.
    • FX Pulse – The effect being applied to the currently playing song will not only be heard, but will also be represented visually via the light movements on the Jog wheel.
  • USB Power – The DDJ-WeGO utilizes power from USB connections found on most computers, eliminating the need for an external power supply.
  • Other features
    • “Plug and Play” functionality allows a DJ performance to start anytime and anywhere when the user plugs in a DDJ-WeGO to a computer via a USB cable and launches Serato DJ Intro.
    • Five available colors: white, black, red, green, and violet.
    • Built-in audio ports for high quality sound input and output.
    • Built-in sound card for expanded music storage and portability.
    • Compact in size and weighs less than four pounds for easy transportation.
Pioneer DDJ-WeGO - colors
Price and Availability
Pioneer’s DDJ-WeGO controller is available with a suggested retail price of $399.
[youtube id=”yUFjZgknoTg” width=”610″ height=”373″]
[youtube id=”QONj2LYAGO8″ width=”610″ height=”373″]
Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Select Onkyo, Integra and Pioneer A/V receivers add support for Dirac Live Bass Control, Amazon Music HD, TIDAL MAX, Source-based Tone Mapping and Google...
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Priced under $500, Pioneer's refreshed entry-level 5.2-channel and 7.2 channel A/V Receivers add support for 4K/120 and 8K resolution.
Auro 3D, Auro Scene and Auro CX enable spatial audio through A/V receivers, smart speakers and music streaming.
HDTV 4K & 8K TV
Pioneer-branded TVs are back, but not in the way you think. Find out how Xumo and Best Buy are involved.
Pioneer Elite is back and this A/V receiver packs in everything that you need for your home theater setup.
Dirac Live Bass Control is coming to select Onkyo, Integra, and Pioneer Elite AVRs. The bad news is that it isn't free.
