Pioneer DAS-RCA020R, DGC020R, XLR030R Audio Cables
Pioneer introduced the DAS-RCA020R RCA analog, DAS-DGC020R digital coaxial and DAS-XLR030R XLR reference quality audio cables. Ideal for use with Pioneer and other DJ equipment in the market, the new cables are designed to achieve high noise resistance, provide increased dynamic range, and offer high reliability and durability.
The Pioneer cables feature high quality materials and an advanced construction process that significantly suppresses noise and obtains a high S/N (signal-to-noise) ratio.
High Purity Copper — Each analog RCA cable is constructed using 6N-Cu (99.9999%) high-grade copper to establish the best connection with the least amount of resistance.
4-Core Twisted Wire — The XLR cables use a 4-Core twisted wire for balanced audio transmission.
Braided Copper Shielding — Each cable uses braided copper shielding to resist any electrical and/or static noise from entering through the cables.
Cable Construction — The cables also feature high pliability construction and neoprene rubber to keep the shielding in place for maximum suppression of noise. Netting is used around each cable for extra protection against damage to the outer insulator.
Collet Chuck RCA Plugs — To ensure proper connection and minimize accidental disconnection, the RCA cables utilize Collet chuck plugs to tighten and lock them in place.
Neutrik XLR Plugs — Used in the professional entertainment industry, Neutrik plugs are featured in the XLR cables for their durability and reliability.
Black Nickel Plating — All plug covers have been coated with black nickel plating that is highly rigid and resistant to damage.
Price and Availability
The new Pioneer cables will be available November 2011 at the following prices:
  • Pioneer DAS-RCA020R RCA analog (pair) → $259
  • Pioneer DAS-DGC020R digital coaxial → $179
  • Pioneer DAS-XLR030R XLR (pair) → $299
Specifications
RCA analog cable Digital coaxial cable XLR cable
Conductor 6N-Cu (99.9999%),1-core shielded 6N-Cu (99.9999%),1-core shielded 4-core twisted wire shield
Plug RCA pin plug RCA pin plug XLR male – XLR female
Length 2m, RCA analog includes LR pair 2m 3m/LR pair
Country of origin Japan Japan Japan
See more about: Cables, Audio, New Pioneer Products
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Select Onkyo, Integra and Pioneer A/V receivers add support for Dirac Live Bass Control, Amazon Music HD, TIDAL MAX, Source-based Tone Mapping and Google...
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Priced under $500, Pioneer's refreshed entry-level 5.2-channel and 7.2 channel A/V Receivers add support for 4K/120 and 8K resolution.
Auro 3D, Auro Scene and Auro CX enable spatial audio through A/V receivers, smart speakers and music streaming.
HDTV 4K & 8K TV
Pioneer-branded TVs are back, but not in the way you think. Find out how Xumo and Best Buy are involved.
Pioneer Elite is back and this A/V receiver packs in everything that you need for your home theater setup.
Dirac Live Bass Control is coming to select Onkyo, Integra, and Pioneer Elite AVRs. The bad news is that it isn't free.
