Pioneer BDR-XD04 Portable Blu-ray/CD/DVD Burner
Pioneer Electronics introduced the smallest and lightest BD/DVD/CD portable burner supporting BDXL currently available. The ultra-compact clamshell type drive can read and write to all BDXL disc formats including BD-R triple-layer 100GB media, BD-R quad-layer 128GB media, and BD-RE triple-layer 100GB media, as well as conventional Blu-ray discs (single-layer 25GB media and dual-layer 50GB media). The portable device, measuring only 5.2″ (W) X .55″ (H) X 5.2″ (D) and weighing a mere 8.46 ounces, also features PowerRead, PureRead2+, Auto Quiet mode and the ability to be powered directly via USB.
The BDR-XD04 can write up to 6x on BD-R and BD-R dual-layer (DL) media. One BD-R DL disc can hold the same amount of data as 10 DVDs (single-layer). The drive can write up to 4x on BD-R triple-layer (TL) and quad-layer (QL) media. One QL disc can hold the same amount of data as 27 DVDs (single-layer). The drive is also backward compatible to read and write to most DVD and CD recordable media.
The BDR-XD04 also includes CyberLink software, enabling users to watch standard Blu-ray and Blu-ray 3D titles, and author high-definition Blu-ray Disc content or standard-definition DVD content.
BDR-XD04 Features
  • PowerRead — The BDR-XD04 can provide smoother movie playback when a disc has fingerprints or minor surface scratches through the use of its PowerRead feature. When the drive is not able to read through these obstructed areas of a disc, it will quickly move forward to the next available data point, resulting in smoother Blu-ray and DVD movie playback.
  • PureRead2+ — Click or pop sounds that might normally occur due to minor scratches and fingerprints on CDs can be prevented on some discs with the drive’s PureRead2+ technology, which allows the drive to dynamically adjust its optical playback settings through the use of a unique algorithm.
  • Auto Quiet Mode — The drive also features an Auto Quiet mode that minimizes its operating noise based on how it is being used. The rotation speed changes to a quieter (slower) speed when watching Blu-ray and DVD titles or listening to conventional audio CDs.
  • Direct USB Power — Designed for simple and easy integration, the BDR-XD04 can be powered directly through most USB PC connections without AC power. For additional convenience, when a host computer’s USB port does not supply enough current, the BDR-XD04 provides an AC adapter terminal (optional DCA-001 AC power supply required). In addition, the device supports USB boot startup for reading bootable recovery CDs.
  • Manual Eject Lever — The BDR-XD04 incorporates a manual eject lever which lets the user eject a loaded disc when power to the device is not available.
  • Bundled Software — The BDR-XD04 is bundled with the following CyberLink software: PowerDVD 10 BD3D, PowerDirector 9 and Power2Go 7.
Price and Availability
The Pioneer BDR-XD04 will be available mid January 2012 for $149.99.
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Select Onkyo, Integra and Pioneer A/V receivers add support for Dirac Live Bass Control, Amazon Music HD, TIDAL MAX, Source-based Tone Mapping and Google...
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Priced under $500, Pioneer's refreshed entry-level 5.2-channel and 7.2 channel A/V Receivers add support for 4K/120 and 8K resolution.
Auro 3D, Auro Scene and Auro CX enable spatial audio through A/V receivers, smart speakers and music streaming.
HDTV 4K & 8K TV
Pioneer-branded TVs are back, but not in the way you think. Find out how Xumo and Best Buy are involved.
Pioneer Elite is back and this A/V receiver packs in everything that you need for your home theater setup.
Dirac Live Bass Control is coming to select Onkyo, Integra, and Pioneer Elite AVRs. The bad news is that it isn't free.
