Pioneer Andrew Jones Designed Home Theater Speaker System Announced
For 2012, Pioneer Electronics introduced a second generation Andrew Jones Designed home theater speakers, which start at $520 for a complete 5.1 package. The new system include bookshelf speakers, floorstanding speakers, a center channel speaker and a subwoofer for both 7.1-channel home theater and 2-channel music listening. Andrew redesigned the speakers for higher accuracy and smoother response to better handle everything from the most subtle music passages to the demands of multichannel movie soundtracks.
New woofers for the bookshelf and floorstanding speakers were redesigned to feature many improvements including a vented pole piece, increased sensitivity, and a new structured surface cone. The structured surface woofer (SSW) provides both enhanced cone strength for better bass dynamics while also smoothing the response for more accurate midrange presentation.
The tweeters were also completely modified using oversized magnets and new domes for enhanced efficiency and response. A new custom-designed wave guide is used to control sound direction, optimizing on- and off-axis response to produce a more consistent sound throughout the listening space.
The new speakers continue the same high-value philosophy as their predecessors by using a sophisticated crossover network with six high-quality components to generate more precise frequency division and driver matching, establishing a more realistic audio output. This approach differs from other speakers in the market in the same price range, which often use fewer components to cut costs.
Additionally, the new line maintains exceptional build quality through the use of the same RF molded cabinet construction technique used in the previous models. The enclosure reduces vibration and ringing, adding to improved sound reproduction.
The new line of speakers feature a detachable grill, rounded at the top and bottom. Pioneer also reduced the size of the SP-C22 center channel speaker for additional set-up flexibility, allowing it to fit in more spaces while maintaining performance. The floorstanding speakers were made three inches taller in order to obtain better high frequency dispersion at a seated ear-level so listeners can enjoy better imaging and staging.
About Andrew Jones
Andrew Jones has been designing speakers for 30 years and has worked for some of the world's finest loudspeaker companies. Jones serves dual roles as the director of engineering for Technical Audio Devices (TAD), a leading manufacturer of quality loudspeakers for professional and general consumer markets, as well as chief speaker engineer for Pioneer, designing both the best and the best value speaker products.
Price, Availability and Specifications
Pioneer's 2012 Andrew Jones speakers will be available in July 2012 at the following prices:
SP-BS22-LR SP-C22 SP-FS52 SW-8MK2
Speaker Type Bookshelf Center Speaker Floor-standing Subwoofer
Cabinet Shape Curved Curved Curved Square
Tweeter Size and Type 1″ Soft Dome 1″ Soft Dome 1″ Soft Dome n/a
Woofer Size and Type 4″ SSW Dual 4″ SSW” Triple 5 1/4″ SSW” 8″ Paper
Crossover 6 element 6 element 8 element
Speaker Terminals Gold 5-Way Gold 5-Way Gold 5-Way
Frequency Range 55 Hz- 20 kHz 55 Hz- 20 kHz 40 Hz- 20 kHz 38 Hz- 150 kHz
Nominal Impedance 6 Ohms 6 Ohms 6 Ohms
Max Input Power 80 Watts 90 Watts 130 Watts
Sensitivity (2.83 Volts) 84dB 88dB 87dB
Crossover Frequency 3 kHz 3 kHz 250 Hz & 3 kHz
Magnetically Shielded No Yes No No
Dimensions (WxHxD) 7 1/8″x 12 9/16″x 8 7/16″ 18 1/8″x 7 1/8″x 8 7/16″ 8 7/8″ x 35 3/16″ x 10 5/8″ 12 3/16″x 14 3/16″x 12 3/16″
Weight 9 lbs 2 oz 13 lbs 7 oz 25 lbs 13 oz 20 lbs 4 oz
SRP $129.99 $99.99 $129.99 (each) $159.99
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Select Onkyo, Integra and Pioneer A/V receivers add support for Dirac Live Bass Control, Amazon Music HD, TIDAL MAX, Source-based Tone Mapping and Google...
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Priced under $500, Pioneer's refreshed entry-level 5.2-channel and 7.2 channel A/V Receivers add support for 4K/120 and 8K resolution.
Auro 3D, Auro Scene and Auro CX enable spatial audio through A/V receivers, smart speakers and music streaming.
HDTV 4K & 8K TV
Pioneer-branded TVs are back, but not in the way you think. Find out how Xumo and Best Buy are involved.
Pioneer Elite is back and this A/V receiver packs in everything that you need for your home theater setup.
Dirac Live Bass Control is coming to select Onkyo, Integra, and Pioneer Elite AVRs. The bad news is that it isn't free.
